Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG
Old 02-01-2009, 20:42   #1 (permalink)
Member: 371870
Thanks Meter: 349
Tutorial (step by step) How to flash LG KP500 - cookie
In this tutorial you will see how to flash lg cookie with new firmware.
1.) BACKUP
- First off all you should make a backup of your phone files (contacts, messages ...) because after flashing, all the files saved on the phone will be erased. I recommend that you use LG PC SuiteII.
- Dont forget to unplug your phone.
2.)DOWNLOAD GSMULTI AND FIRMWARE
FIRMWARE LG KP500 KP500AT-00-V10n-DEC-17-2008 (v10N) NEW!
http://www.filefactory.com/file/a03f...N_Firmware_rar
FLASHER LG - MultiGSM ver 3.0 + kp500 .dll file
http://www.filefactory.com/file/a03g...SMULTI_V30_rar
3.)INSTALL THE SOFTWARE AND DRIVERS - DRIVERS WORKS ONLY ON XP WINDOWS
(Don't connect your phone on computer yet)
Downloaded files should be un-ziped (I unziped them in one folder which i made it on desktop)
You got next files:
program
- SETUP_GSMULTI_V30
- KP500_081002.dll
firmware
- KP500AT-00-V10n-CIS-XXX-DEC-17-2008
- KP500AT-00-V10n-CIS-XXX-DEC-17-2008.bin.mbn
3.1.) Install GSMULTI (SETUP_GSMULTI_V30). The icon will shows on your desktop otherwise the program install on C disk, folder GSMULTI
- start GSMULTI
- select: Settings/Configuration
- put .dll file and firmware file in and choose USB then click OK and close program
3.2.)Install DRIVERS (INFINEON and TI_NEPTUNE)
Drivers to be found in install folder of GSMMULTI program. My path is C:\GSMULTI\UsbDrivers
- First install INFINEON
- Second TI_NEPTUNE
4.) PREPARE AND CONNECT YOUR PHONE
- Now u take a phone (shut it down) and remove, BATTERY, SIM CARD and MEMORY CARD then
- conect it with your USB cable to computer (I suggest that u connect only in one USB port on computer)
- wait about one minute that comuputer recognize new device
5.) USBMap PROGRAM
- Run program USBMap_V01 (which can be found in C:\GSMULTI)
- Select INFINEON and then click MAPPING START
-WAIT (about one minute) that USBMAP will find USB port where is the phone connected
- When the port will be found click on (select it) and press SAVE&EXIT
6.)MAIN PART
- FLASHING
- Run GSMULTI program (shourtcut is in your desktop)
- Check if settings/configuration are the same like we set it before (otherwise look step 3.1.)
- Now its everything ready to start flashing
- Check MODEL and SW VERSION and if that is correct just click START and wait until the program finished
- And voila, here we have a new firmware version
That's it.
The Following 333 Users Say Thank You to shauneco For This Useful Post:
Old 02-01-2009, 20:57   #2 (permalink)
Member: 322417
Thanks Meter: 940
No box Support this model if Work this will be gr8 Info
Regards
The Following 2 Users Say Thank You to Formingus For This Useful Post:
Old 02-02-2009, 05:22   #3 (permalink)
Member: 4600
Thanks Meter: 79
tested 100%.
flashed perfect.
br.
Old 02-02-2009, 07:47   #4 (permalink)
gurinder's Avatar
Member: 167191
Thanks Meter: 363
IF u use usb cable of KE500 then it will take 554sec for full flash, if u try to flash it with usb to serial cable then it will take 7500sec.
i tried with both and now posting proof of time consumin but its good that no box needed to flash this COOOOKKKKIIIIEEEEEE....
GURINDER
The Following 8 Users Say Thank You to gurinder For This Useful Post:
Old 02-02-2009, 07:56   #5 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
downloader not working check link pls......
Old 02-02-2009, 11:03   #6 (permalink)
Member: 371870
Thanks Meter: 349
They do work but restrict downloading if your a basic user.
Anyway more links now available:
Firmware Here
Flasher Here
The Following 16 Users Say Thank You to shauneco For This Useful Post:
Old 02-06-2009, 19:28   #7 (permalink)
:::..CyBoRg..:::'s Avatar
Member: 568876
Thanks Meter: 99
i have kp500 hang on logo... i try to flash with your file but on usb1 and says wait phone connecting... it's stocks almost 30 minutes already.... i'm waiting so long.... any idea on this?????
The Following User Says Thank You to :::..CyBoRg..::: For This Useful Post:
Old 02-07-2009, 02:44   #8 (permalink)
Member: 568876
Thanks Meter: 99
the phone flash successfully, thanks for the flasher and for the firmware.... it's works 1000%.....thanks to shauneco.....
The Following 3 Users Say Thank You to :::..CyBoRg..::: For This Useful Post:
Old 02-07-2009, 05:13   #9 (permalink)
dragories's Avatar
Member: 8450
Thanks Meter: 14
101% working thanks shauneco. $$$$
The Following User Says Thank You to dragories For This Useful Post:
Old 02-07-2009, 05:56   #10 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
Not Found
The requested document was not found on this server.
Web Server at gsmhosting.com
Other things to try:
Go to forum.*gsmhosting.*com/*vbb
Search forum.gsmhosting.com:
Old 02-07-2009, 07:14   #11 (permalink)
Member: 764493
Thanks Meter: 25
will this work on the KF350 ice cream?
Old 02-07-2009, 07:26   #12 (permalink)
Member: 764493
Thanks Meter: 25
ignore this, multiposted because of bad internet
Old 02-07-2009, 07:34   #13 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
Not Found
flasher: http://rs284.rapidshare.com/files/19...SMULTI_V30.zip
flash files :http://rapidshare.com/files/19283630...mware.zip.html
The Following 6 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 02-11-2009, 17:48   #14 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 89
Witch languages contain this firmware?
Old 02-12-2009, 22:27   #15 (permalink)
Member: 751249
Sonork: 151515999
Thanks Meter: 18
link only for premium member....
please another link
The Following 2 Users Say Thank You to p0er08 For This Useful Post:
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f177/tutorial-step-step-how-flash-lg-kp500-cookie-675647/
Posted By For Type Date
I need lg kp500 downloder This thread Trackback: 09-26-2011 16:25
how to unlock lg kp500 samalik Infinity-Box 3 03-13-2010 15:55
How to flash lg kp500 Naz66 FuriousGold 3 10-30-2009 02:57
how to unlock lg kp500 patelfaizu Infinity-Box 4 07-15-2009 12:37
help me?how to flash LG kp500? peter829 FuriouS II 1 05-19-2009 03:48
how to flash LG kg800 step by step........ 081372002070 HWK 4 04-08-2008 08:30
Page generated in 4.55619 seconds with 10 queries
