03-22-2009, 17:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks Meter: 1,592 | Multi protocol phoenix service software version 2009.04.11.37849 released! Version history: Version 1 20.03.09 Initial version Multi protocol (including support for CDMA, GSM, TDMA and WCDMA) Phoenix Service Software version 2009.04.11.37849 has been released. Note: Please do not use this version when updating RM-247 (N96) product SW. This Phoenix Service Software installation package includes following SW components: - Phoenix Service Software 2009.04.11.37849 - DK2 Dongle Driver v 7.14.0.25 - Nokia Connectivity Cable USB Driver v 7.1.8.0 (for Win2000 driver version 6.85.15.0) - Flash Update Package 09_11_04 - FLS-x Dongle Driver v 2.09.26 - FPS-11 version 5.10.0 HW & tool requirements: Please see General Service Bulletin SB-209. Supported Operating Systems and user rights: - Windows 2000 Service Pack 4 or higher - Windows XP Service Pack 1 or higher - When installing Phoenix into Win2000 or XP you must have local admin rights. - When using Phoenix in Win2000 or XP, user must have power user rights. After installing Phoenix Service Software, please install latest product specific data package or SW bundles; do not use old data packages or SW bundles. If you want to use FPS-11, please download separate FPS-11 driver package. If you are installing this version of Phoenix on a new Imaged PC, and you are using FLS-4S or FLS-5 during the install, then install the FLS-X drivers first. Changes/improvements made from previous version 2008.44.6.36625: New products supported: - RM-455, RM-516, RM-561, RM-509, RM-510, RM-511, RM-514, RM-515, RM-470, RM-503, RM-544, RM-518 - Complete list of supported models is available from Phoenix menu “File” –> “Open Product” New features: - Automatic device log file collection enabled, this function has no impact to field services - Nokia Connectivity Cable USB Driver updated - Flash Update Package - > Please make sure you update your prommer from “Prommer Maintenance” - FLS-x Drivers updated Error corrections & changes: - Improvements to auto tuning - Stability improvements to USB flashing - Changes to image download configuration Known errors & limitations: - Please do not use this Phoenix version when updating the SW for N96 (RM-247) products. The flash algorithm files in flash update package 09_11_04 will cause APE CCC corruption. For more details, please see Service Bulletin RM-247 SB-015. New flash update package will be released shortly. - Software downgrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept. - Flashing with FLS-5, SS-46 and product specific adapter is not reliable for all BB 5.0 products - USB flashing for N96 is not stable - Tucson add on package will be released soon to improve Tucson stability - Flash Update Package File installation path may be wrong. If you experience problems when updating FPS-x prommers, please check that Phoenix “Prommer maintenance” is looking for the files from the correct location which is “C:\Program Files\Common Files\Nokia\Tss\Flash”. If not, Phoenix will show error “Update via ini – file failed”. In this case, select “Update” from that Phoenix “Prommer maintenance” – UI, browse to correct directory and select “fpsxupd.ini” for all other prommers except the FPS-8. - Multi Flash has limited capabilities, launch Multiflash UI first and then connect phones one by one, do not attempt to service more than 5 phones at the time. Installation: If you have Phoenix Service SW version 2007.4.6.170 or older you must uninstall it before installing this release. 1. Download phoenix_service_sw_2009_4_11_37849.exe – application file from Genie FTP to your computer (e.g. C:\TEMP) 2. Close all other programs 3. Run phoenix_service_sw_2009_4_11_37849.exe and follow instructions on the screen to install Phoenix Service Software. 4. Connect a dongle (PK-1, PKD-1, FLS-4S, FLS-5) when message appears on the screen 5. If you are prompted to update any existing driver or file versions, select “yes” 6. Depending on the operating system PC may require rebooting 7. Allow Windows to register Phoenix components 8. Open Phoenix and update your prommer with the latest software included in this installation package 9. Use the latest available product specific data packages or flash bundles with new multi protocol Phoenix. Best Regards Alan Tan |
The Following 17 Users Say Thank You to xpmobile For This Useful Post: |
05-15-2009, 03:23 | #2 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1009387 Status: Offline Thanks Meter: 14 | Multi-protocol phoenix service software v 2009_12_7_38366 Phoenix_Service_Software_2009_12_7_38366.exe MULTI PROTOCOL PHOENIX SERVICE SOFTWARE 2009.12.7.38366 Published 08/05/2009 Size 131.4 MB APAC - Service Software & Driver -> Phoenix & Bulletin File type -> . Phoenix Multi Protocol & Buletin, MULTI-PROTOCOL PHOENIX SERVICE SOFTWARE V 2009_12_7_38366 New version of Phoenix service software is available. This multi-protocol service software supports Nokia CDMA, GSM, TDMA, and WCDMA products. Service SW installation packages and Technical Bulletins are available from NOL. Main component versions in the release: · DK2 Driver Version 07.14.0.25 · Nokia Connectivity Cable USB Driver Version 7.1.16.0 (For Win2000 driver version 6.85.15.0) · Flash Update Package 009.018.010 · FLS-x Drivers Version 2.09.26 · FPS-11Version 5.10.0 New products supported: · RM-578, RM-579, RM-508, RM-547, RM-566, RX-51, RM-565, RM-546, RM-529, RM-530, RM- 491, RM-564, RM-562, RM-563 New features · New rf_losses.ini ver.40 for autotune function Error Corrections & changes · Improvements to N96 USB Flasing · Flash Update Package 09.18.10.8 with improve,ments to random “finalization failed” – problems for models with OMAP2420. · Corrections for Network Prommer Maintenance · Improvements for Tucson Product Code Change and BB5 Certificate Restoring with “Flash Phone” – option selected. · Improvements for connection manager when used with FLS-5 = Genie |
The Following 7 Users Say Thank You to CONTACTSERVICES For This Useful Post: |
05-23-2009, 04:03 | #5 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | please post another link here for phoenix software cuz FTp slow.... where could i find driver for genie clip or when i install phoenix software i will get all driver there ? |
05-23-2009, 08:26 | #6 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, FTP download speed is now around 1 MB/sec. Better speed you can get only from HTTP download from Microsoft.com Drivers on genie-universal.com BR Last edited by Bph&co; 05-23-2009 at 14:11. |
The Following User Says Thank You to Bph&co For This Useful Post: |
05-23-2009, 13:55 | #7 (permalink) |
Member: 455304 Status: Offline Thanks Meter: 417 | only driver i seeing on genie site... is FlS5 driver... is that the driver cuz everytime i connect genie to the pc note i already install Fls5 driver... but when i try to lunch a program from genie via pc it asking for driver... genie driver... |
05-23-2009, 14:13 | #8 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | [QUOTE=shawn4life;4495235but when i try to lunch a program from genie via pc it asking for driver... genie driver...[/QUOTE] And what is the name of that program ? |
06-26-2009, 22:12 | #12 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | I just got my Genie,i used to work with cracked Phoenix,today i got "Phoenix_Service_Software_2009_12_7_38366" from support.will it possible for me to go on using new phoenix with genie and normal usb interfaces? |
06-27-2009, 05:30 | #13 (permalink) |
No Life Poster Join Date: Sep 2005 Location: INDONESIA Age: 38
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | yes u can do it with genie. genie is full emulated FLS-5 device, just try little search which is most stable version, latest phoenix get much bugs with FLS-5 device even it's original ones. br, kevin168 |
06-27-2009, 06:01 | #14 (permalink) | |
Registered User Join Date: Apr 2008 Location: henubaan neg. occ.
Member: 757007 Status: Offline Sonork: bugsbro Thanks Meter: 4 | Quote:
hey bro can you upload this software so that i can use and test? | |
New Multi Protocol Phoenix Service Software Version 2007.4.6.170 | Shayesta197 | Nokia Base Band 5 ( BB-5 ) | 65 | 03-29-2011 12:31 |
Genie's FLS-5 new multi protocol phoenix service software version 2009.04.11.37849 | xpmobile | Service Products News & Updates | 0 | 03-22-2009 17:59 |
Multi Protocol Phoenix Service Software Version 2008.4.7.32837 | DeltaGSM | Nokia Base Band 5 ( BB-5 ) | 71 | 08-11-2008 20:14 |
Multi Protocol Phoenix Service Software Version 2007.20.4.28513 | alif30 | MT-BOX | 17 | 07-22-2007 14:29 |
New Multi Protocol Phoenix Service Software Version 2006.04.6.130 | mtmc | Phoenix Black Box | 46 | 04-10-2006 11:14 |
