Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Cyclonebox
Old 03-23-2009, 14:25   #1
Cyclonebox
Cyclonebox's Avatar
Member: 903342
Sonork: 100.83919
*** Cyclone Box - Download - Installation - First Steps ***
(Updated 06.11.2009 - ASIC 3168 Full Included - New firmware 1.0A)
1. Download final installer from http://www.cyclonebox.com/downloads/...xInstaller.exe and Install it. While installing agree to install box drivers, etc.
2. Download the Update from http://www.cyclonebox.com/downloads/...te26102009.exe and Install it.
3. Connect box to PC. PC should detect new device - "Cyclone Bootloader". Simply do automatic driver installation, till installer installed them in Win32 INF already.
4. Run Start -> Programs -> Cyclone Box -> Cyclone Box
At bottom, you should see "Connected [Bootloader Mode]". That means your box was detected by software, and you can proceed with box registration - needed step to activate your box.
5. Run Box Registration Wizard, click Prepare Box.
Select your reseller from list, and fill all needed data.
If you see "Box registration status: Registered OK" that means all passed ok. You can proceed with box activation.
6. Run Box Maintenance Wizard, and click Maintenance box. In 1-2 minutes your box will be initialized.
**** VERY IMPORTANT : During box upgrade, please DON'T disconnect your box, even if software may act as hang ! We use ciphering on few layers during upgrade, and if you have slower PC, decrypting RSA and other ciphers, may take quite more time !! And then, if you disconnect your box, it will not be upgraded. It is no problem, because it will not be damaged, but You will lose YOUR time and OURS time, asking for next update credit !!
7. Your box is registered and activated. Now your security card needs be initialized. To initialize security card, box needs be activated! Run Security Card Manager. Read your card, and click Fill Credits. Box should change its mode to Cyclone Box and Windows should install new drivers again (same steps as for Bootloader). On bottom of screen you should see "Connected [Main Mode]".
How to activate Super DCT4 in my box?
It is very simple. Go to "Credits" module (same as you are using for calculating ASK/RPL), and click big "Activate SUPER DCT4" button. In seconds you should see similiar message:
Started Super DCT4 Activation at 03:45:20
Handling device: [Cyclone Team], [Cyclone Box]
Service Tag: 4F67674F5428157448CEACEB547BC575
Cyclone Server (1.0.0.483), Cyclone Box Team 2008, 2009 - Ready.
Super DCT4 Activated Successfully! Credits Left: 950
Please, replug your box from USB now, and use Maintenance Function to upgrade it again.
After next upgrade, box will be activated for Super DCT4 Functions!
As message says, replug your box and re-upgrade it again. After re-upgrade your box is SUPER-DCT4-READY
8. All is done. You can run DCT4/WD2/BB5 tool and check if necessary selftests will be passsed, so you can enjoy using your Cyclone Box One note: security card having 1000 credits at initialization. Each card operation tooks those credits, so after some time you need to reinitialize card (when counter reachs 0). This operation is of course free and realtime, using server.
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918
Initializing box...
Box Firmware: Cyclone Nokia Application v1.0A, (Nov  6 2009 01:26:23, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application, Flags: NoFlags
Box Serial Number: C0000005
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Initializing security card...
Card Serial Number: D0000001
Card Firmware Revision: 0108
Card is activated
Box is activated
Started box selftests procedure
USB Voltage    4,99v    PASSED
MCU Voltage    3,30v    PASSED
Core Voltage    1,79v    PASSED
VBAT Voltage    0,01v    PASSED
VBAT Voltage    4,73v    PASSED
Box VPP disabled
VPP Voltage    0,02v    PASSED
Internal Box VPP Enabled
VPP Voltage    4,88v    PASSED
Box VPP disabled
VPP Voltage    0,00v    PASSED
External Box VPP Enabled
VPP Voltage    0,04v    FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Remember to check the Version of the software and the firmware of your Cyclone box
Enjoy your box!
The Following 96 Users Say Thank You to Cyclonebox For This Useful Post:
.:Towhid:., 79mobile, accever2009, adigsm2006, alexander.tech, alfox, AngelsGsm, arenchen5, asadnow2k, asif123456789, assounaf, azez.sd, basitmemon786, biochemistali, blolyxx, brahim, bronce, Carlazos, cashgsm, cellsafemobile, cetech, cheong966, clickphone, Cobbysyms, cxacxa, dancameo2k, Darkangel80, dessertcell, digiphone, Dj King, dmaetrey, dr_moosavi, eddi®, engendro, fagamon, farshad2009, fayaz25, Feda, floyd2, geluo, globaltelecom, GPG_tiger, gsmTECHNICIAN, hassan_mu, hima010, hiphone, huja_2md, jay_mobile, jhovani666evil, kemakaza, lakmal1983, lath123, liberandocelula, LIEREN, lilong_lee, LPSV, luskao, mamepap, mammik, misterG, mobile_kraft, morton1984, m_amien, ndiaye, niks6678, nongmobile, obg1, oscarjr85, pablor1977, plopez, pritish_gsm, quickgsm, richiricherd, RIOPHONE, roberto gsm, roshantelecom&s, rustyinsight, saajith, saicotic, sam22001, SATHAKATHULLA, sayman, shahzaadbutt, shopthuy, simorgh, sunilmobile123, tamtam2007, tommy998, udai, usmank, vagala, vance lee, visit999, wsmobile, ysmayl, z3x-BX
Old 03-23-2009, 15:18   #2
dhawan_boss007
dhawan_boss007's Avatar
Member: 511520
hi cyclone box
plz post some succussfully done operation which show us
how to work ur box with nokia mobiles
like unlocking, flashing , repair rpl in dct4+, flash bb5 etc
B.R
BossDhawan
The Following 2 Users Say Thank You to dhawan_boss007 For This Useful Post:
Old 03-23-2009, 15:21   #3
Cyclonebox
Cyclonebox's Avatar
Member: 903342
Sonork: 100.83919
Originally Posted by dhawan_boss007 View Post
hi cyclone box
B.R
BossDhawan
Sure there is about 100-120 operations logs, let me upload them all but hosting not work well today
The Following User Says Thank You to Cyclonebox For This Useful Post:
Old 03-23-2009, 15:43   #4
dhawan_boss007
Member: 511520
thanks for reply me i m waiting for ur logs post
& need some screenshot
The Following User Says Thank You to dhawan_boss007 For This Useful Post:
Old 03-23-2009, 15:47   #5
Cyclonebox
Cyclonebox's Avatar
Member: 903342
Sonork: 100.83919
Check here
http://forum.gsmhosting.com/vbb/showthread.php?t=705415
The Following 6 Users Say Thank You to Cyclonebox For This Useful Post:
Old 03-23-2009, 16:17   #6
dhawan_boss007
Member: 511520
Smile
Originally Posted by Cyclonebox View Post
great brother
but what special in ur box as compare to other nokia service tool
Old 03-23-2009, 16:21   #7
dhawan_boss007
Member: 511520
Smile
plz send detail in fourm why we buy ur box ?
Old 03-23-2009, 18:50   #8
Mariozas
Mariozas's Avatar
Member: 665113
Sonork: 100.1583029
Exclamation
yeah, good point!
Please give us some good reasons why we should buy it? Most of us have plenty tools for nokia phones nowadays... I have 5 different tools that does all my needs for now... so whats so special with CycloneBox ?
(P.S. - Im one of the customers who is interested in your new product, so make a good comparison between your tool and others, advantages and disadvantages please...)
Thanks for an answer in advance!
The Following User Says Thank You to Mariozas For This Useful Post:
Old 03-23-2009, 20:05   #9
neo_49
Member: 325999
Cyclone Box, please uplaod some flash video.
REGARDS
The Following 2 Users Say Thank You to neo_49 For This Useful Post:
Old 03-23-2009, 20:33   #10
yousufbig
Member: 759917
Sonork: yousufbig
pliz gave me some flash video
The Following User Says Thank You to yousufbig For This Useful Post:
Old 03-23-2009, 20:34   #11
Cyclonebox
Cyclonebox's Avatar
Member: 903342
Sonork: 100.83919
Will sort later, now really many work @ other things
Old 03-23-2009, 21:15   #12
sharmin
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
yes simply ur team is too much busy now
but really need to know that , why we will buy this product ... what will we get or more benifited from this !!!
pls describe full feature and support of this box ...
The Following 2 Users Say Thank You to sharmin For This Useful Post:
Old 03-23-2009, 21:22   #13
HONEY
HONEY's Avatar
Member: 44158
Sonork: 100.64344
Features & benefit you can read in other threads where the descriptions are.. also you can have a look at official web.
About why to buy or support, its a new box and for sure there will be support for years, I don't think there is anyone who can tell you what all it will support in year 2010 or 2011..
BR.
Old 03-24-2009, 01:15   #14
mobileclinic_14
mobileclinic_14's Avatar
Member: 749969
Sonork: 100.1581886
Is it working better then any other nokia box like jaf and mt box..
why should we purchase your box..
whats new in this?
i post it for information ,,,
Old 03-24-2009, 04:50   #15
rk_grover77
rk_grover77's Avatar
Member: 142191
basicly everyone keen to know the extra features that other box in the market dont hv. because mostly hv 2 or 3 tools for nokia.
The Following User Says Thank You to rk_grover77 For This Useful Post:
Page generated in 0.10934 seconds with 6 queries
