![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2003
Member: 19633 Status: Offline Thanks: 12
Alkatel 311 no display
Lcd is Ok. Contakts is ok too. I had reflash phone and hotair it, but same - No display
Any solution, pleas! Whot part of circuit answering for LCD?Thenks. |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004
Member: 57035 Status: Offline Thanks: 24
If you are sure that the contacts are ok and hardware the phone is ok? before trying to look for LCD circuit try the LURKER LCD option in extended menu ! THERE ARE TWO TYPES OF LCD !
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2003
Member: 25150 Status: Offline Thanks: 0
i also have two of this 311 with same lcd problem some one pls explain better on how to solve this problem
thanks |
there are 2 types of lcd on 311 ... so if the phone is ok (HARDWARE) then you can change between those 2 types of LCD with software ...LCD CHANGER ... this option is on LURKER SOFTWARE BY WRAY ... on extended menu ... If the software doesn't solve the problem, then you can open the phone and try check the contacts and the circuits ... HOW CAN I EXPLAIN BETTER ????? SOLVED LOTS OF THEM WITH SOFTWARE !
![]() ![]() ![]() ![]() Join Date: May 2002
Member: 12274 Status: Offline Thanks: 7
try to change the caps near the lcd 100% work
![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002
Member: 13932 Status: Offline Thanks: 8
tested solution is..
rehot or replace two big capacotrs around joy stick... |
