05-27-2009, 17:22 | #1 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1014821 Status: Offline Sonork: 100.1603462 Thanks Meter: 66 | LG GB102 Successfully Unlocked with infinity i have selected kp100 as model and ke 500 cable phone unlocked 100% with method 2 after unlock u have to reset phone with 2945#*# to get network this is the log : COM5 [VCP0] selected module v1.65 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +0 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090527-181117.B1E.bin loading data... data loaded imei: 35399903xxxxxxxxxxx reading eeprom-security_35399903xxxxxxxxxxxxx... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35399903xxxxxxxxxxxxx_20090527-181117.B1E.bin reading eeprom-complete_35399903xxxxxxxxxxxxxxx... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35399903xxxxxxxxxxxxxx_20090527-181119.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 16 sec Remove/Install battery now ! |
The Following 36 Users Say Thank You to unlocklogs.com For This Useful Post: |
05-28-2009, 08:48 | #2 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | thank you for ur good test report please if you can read full flash & uplaod some where then share here! br! |
The Following 3 Users Say Thank You to zinoubinabil For This Useful Post: |
05-29-2009, 22:40 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, send files to [email protected] |
05-30-2009, 11:30 | #8 (permalink) | |
Member: 1014821 Status: Offline Sonork: 100.1603462 Thanks Meter: 66 | Quote:
br, unlocklogs | |
The Following 2 Users Say Thank You to unlocklogs.com For This Useful Post: |
06-03-2009, 17:16 | #9 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | Today I unlocked On GB102 as KP100 Modul COM4 [VCP0] selected module v1.65 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +0 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090603-160444.B1E.bin loading data... data loaded imei: 35399903067962100 reading eeprom-security_35399903067962100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35399903067962100_20090603-160445.B1E.bin reading eeprom-complete_35399903067962100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35399903067962100_20090603-160451.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 29 sec Remove/Install battery now ! ******************************** Thank you infinity-team, i made a lot of money with your Star Box to [email protected] the extracted File From Phone By Infinity please download it From HERE |
The Following 3 Users Say Thank You to KhalIman For This Useful Post: |
06-03-2009, 18:11 | #10 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Sousse /trockadero/TUNISIA
Member: 193003 Status: Offline Thanks Meter: 46 | solution tested and work perferctly thanks to infinty team and to unlocklog.com..for sharing COM4 [VCP0] selected module v1.65 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +0 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090603-190404.B1E.bin loading data... data loaded imei: 35399903115661100 reading eeprom-security_35399903115661100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35399903115661100_20090603-190408.B1E.bin reading eeprom-complete_35399903115661100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35399903115661100_20090603-190415.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 32 sec Remove/Install battery now ! |
The Following User Says Thank You to HaNiNi Gsm For This Useful Post: |
06-15-2009, 12:40 | #15 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Tested and work like a charm: COM2 [VCP0] selected module v1.65 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +0 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090615-113233.B1E.bin loading data... data loaded imei: 35399903055645600 reading eeprom-security_35399903055645600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35399903055645600_20090615-113233.B1E.bin reading eeprom-complete_35399903055645600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35399903055645600_20090615-113235.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to .:==di@bila==:. For This Useful Post: |
KE 970 LG shine successful flash with infinity! | kmaxmax | Infinity-Box | 11 | 11-11-2009 19:58 |
vodafone 125 & LG KP100 success unlock by infinity | raffy_84 | Infinity-Box | 5 | 10-20-2008 15:17 |
Huawei T128 Successfully Unlock With Infinity , Again A Great Work Team. | amit_varietymob | Infinity-Box | 8 | 08-30-2008 07:08 |
Spice S535 Successfully Unlocked With Infinity | amit_varietymob | Infinity-Box | 8 | 06-24-2008 19:23 |
Siemens CFX 65 is successfully unlocked with Infinity | mcandre | Infinity-Box | 4 | 12-04-2007 12:52 |
