06-06-2009, 11:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Genie BB5 RPL Realtime Logger Updates Main features: - Ability to repair damaged simlock data in BB5 phones - Realtime server operation or via ASK/RPL files - It can rebuild fully erased simlock after full erase - It can create default 'unlocked' RPL file - It can create locking RPL file from provided simlock.bin file - It can back up simlock from locked phone as simlock.bin - It can generate unlock codes when locking a phone - It can read simlock status - Generated RPL file from server is saved to a file as backup Limitations: - It will not repair missing certificates - It will not repair bad imei: 12345.... - It will not repair Secure Watchdog shutdown - It will not generate SuperDongle Key data How To Use: - Connect Genie to a PC via mini USB cable - Run log.smx in your device via the keypad - USB device will show in Windows(install drivers if first run) - Start BB5Logger.exe in Windows and press 'Connect' - Connect a phone to Genie via the adapter - Tick 'Use Server' and enter your UN/PW - Press 'Read', allow internet access from your Firewall - The RPL file will be saved in the program directory - Press 'Write', select RPL file and continue I have existing credits, how to upload to the server: - Connect Genie to PC via mini usb cable - Run log.amx - Install drivers if needed, run BB5Logger.exe - Press Connect - Think of a password and type it(at least 8 characters) - No need to enter User Name, as your device SN will be used for that - Make sure you have working Internet, press Credits, allow firewall access if requested - You should get server version and amount of credits transfered to server - When all done, you can connect by using your device SN as username and the chosen pass - Please note that the upload will work only once, then if you want top up, you should contact us for getting new credits and adding them to your existing account How much does it cost: - Calculating RPL file by our server will take away credits from your account. This will cost you different amount of money based on how much credits you have prepaid. More info about credits here Supported Models: - Rapido CPU: 5320, 5700, 6110, 6120c, 6121c, 6124c, 6210, 6220c, 6290, 6650 E51, E66, E71,E75, N76, N78, N81, N81 8Gb, N79, N85, N82, N95 8Gb, N96... - RAP3 CPU(hash BAF3...): 3120c, 3555, 3555b, 5310, 5310b, 5610, 5610b, 6267, 6263, 6300i, 6500s, 6500c, 6555, 7500, 7900, 8800Arte... - RAP3 CPU(hash 9DDB...): 3600c, 5220, 7210c, 7310, 6600s, 6600f, 7610s... How do I get real-time updates and server status - This forum is very slow most of the time, so you can check my tweet for the latest status of the server or if we have important announcements First Release: V 1.0.0.8 - 03 June 2009 - Windows program will save some parameters to ini file (form position, boot timeout value) and will be used on next load - Some improvements on the log.amx script regarding credits upload to server Downloads: Genie BB5 Logger release pack Runtime DLLs pack ---------------------------------------------------------------------------- Useful Links: Discussion thread about this software is here. The Beta testing period is over, but if you want to revisit the development of this software you can check here. Regards, B-phreaks Last edited by Bph&co; 08-05-2009 at 13:34. |
The Following 38 Users Say Thank You to Bph&co For This Useful Post: |
06-16-2009, 16:52 | #2 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | ---------------------------------------------------- V 1.0.0.9 - 16 June 2009 - Support for RAP3 phones with hash BAF3.... - Update button removed, please do not use older versions with this function How to update: 1. Run FTP.exe and update your card contents 2. Use charger and update your device firmware, you will get version 0.161 3. Run log.smx from Programs\Script How much: It will take 20 credits from your server account for each RPL. So, now the logger supports all BB5 phones except SL3 firmware and phones with hash 9DDB... WARNING: The server will make RPL for SL3 phones, but in old format. There is no way to detect SL3 firmware from RAP3 ID, so its your responsibility to check. If you do calculate SL3 RPLs, you will loose credits, please note we will not going to refund them ! Enjoy Last edited by Bph&co; 06-23-2009 at 13:00. |
The Following 22 Users Say Thank You to Bph&co For This Useful Post: |
06-17-2009, 18:15 | #3 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, New update today: ---------------------------------------------------- V 1.0.0.10 - 17 June 2009 - Support for Windows 7 Please download from same link. BR |
The Following 8 Users Say Thank You to Bph&co For This Useful Post: |
06-23-2009, 13:02 | #4 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, New update: ---------------------------------------------------- V 1.0.0.11 - 23 June 2009 - Major improvments on the program usability - Operations are split into separate Tabs, main Tab is the Logger, where you can read/write etc Options tab is for settings and server details - Ability added to check credits on the server (Check Credits button in Options Tab) - Improvments on Upload credits menu, now backup could be auto re-used for upload in case of server error. Also selected UN/PW will be printed on screen - Program will save username and password to the bb5logger.ini file if you keep the 'Use Server' box selected before closing. So on next start your details will be ready for use Please re-download from the link on the first post in this thread. BR |
The Following 18 Users Say Thank You to Bph&co For This Useful Post: |
07-20-2009, 11:08 | #5 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | 17th Jul 2009, 13:13 Update on the server, now is possible to generate RPL file for RAP3 phones with hash 9DDB... More info here. BR |
07-21-2009, 11:21 | #6 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | 21 July 2009 Update on the server, v 0.43 Due to some users using bad cables, we change the charging policy of the server as follows: - RPL calculation - 45 credits - Reading ask file for RAPIDO CPU phones - FREE - Reading ask file for RAP3 phones(hash BAF3...) - 5 credits - Reading ask file for RAP3 phones(hash 9DDB...) - 5 credits Enjoy |
The Following 43 Users Say Thank You to Bph&co For This Useful Post: |
Genie BB5 RPL Realtime Logger Discussion | Bph&co | Genie Universal | 151 | 02-04-2010 15:51 |
F.A.Q about Genie BB5 RPL Realtime Logger. | ..::Angel::.. | Genie Universal | 6 | 06-26-2009 21:03 |
Genie BB5 logger - RAP3 phones supported! | Bph&co | Service Products News & Updates | 0 | 06-16-2009 16:59 |
BB5 RPL Logger for Genie - Beta testers needed ;) | Bph&co | Genie Universal | 257 | 06-06-2009 11:08 |
BB5 RPL Logger for Genie Universal- Beta testers needed!!! | xpmobile | Service Products News & Updates | 0 | 04-21-2009 18:31 |
