Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SMTi Support Sections > SMTi
Old 06-22-2009, 13:37   #1 (permalink)
gsminfo's Avatar
Member: 23714
Thanks Meter: 18,769
SMTi HUAWEI MODEM Code Writer v 1.0 ( working without SMTi box )
HUAWEI MODEM Code Writer Ver. 1.0
- Working without SMTi box
- IMEI and SW Version detection
- Write unlocking code to HUAWEI USB MODEM
Download Links : RAPIDSHARE LINK / DIRECT LINK
Best Regards
Sagmaster Team
The Following 23 Users Say Thank You to gsminfo For This Useful Post:
Old 06-22-2009, 14:04   #2 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
thank's
so this prog work after get code from srver whith SMTI
so this prog for write unlock code just .
i now is show imie sn and sw version.
thak's.
lahdache
Old 06-22-2009, 14:21   #3 (permalink)
gsminfo's Avatar
Member: 23714
If you have some customers who need unlocking huawei modem
Please make code calculation by SMTi and send to customer code writer exe + code :-)
Really simple way for start remote unlocking all huawei usb modems NOW ! :-)
User start code writer exe make modem detection and write unlocking code to modem :-)
SMT
Old 09-17-2009, 20:38   #4 (permalink)
Member: 33296
Thanks Meter: 20
IMEI : 353142-03-905707-3
NCK : 57837129
FlashCode : 66876914
Found Phone, Phone Info:
- Manufacturer :huawei
- Model :E1550
- Revision :11.608.12.00.174
- Phone IMEI :353142039057073
Send Unlock Command... ERROR
Old 09-17-2009, 21:35   #5 (permalink)
Member: 624884
cannot detect usb port
Old 09-17-2009, 21:51   #6 (permalink)
Member: 33296
Thanks Meter: 20
if not detect usb port info not read ok, but read info ok
Old 09-18-2009, 21:28   #7 (permalink)
luqmaan's Avatar
Member: 617428
Thanks Meter: 52
Best Regards
Sagmaster Team
thanks if this works will try and then post result again
The Following 2 Users Say Thank You to luqmaan For This Useful Post:
Old 09-22-2009, 23:49   #8 (permalink)
Member: 1125370
Hello!
Thank you really useful piece of software.
I have a problem entering NCK code for Huawei E1550 (USB modem stick).
  - Model		:E1550
  - Phone IMEI	:xxxxxxxxxxxxxx14
Port was detected right.
Used to check it with DC Unlocker after using your tool:
Found modem         : E1550
Model               : Huawei E1550
IMEI                : **************14
Firmware            : 11.608.12.00.174
Dashboard version   : UTPS11.301.08.13.174_MAC11.301.06.08.174
Serial NR.          : ***************01
SIM Lock status     : Locked (customized firmware)
Wrong codes entered : 0 (unlock attempts left : 10)
Any ideas on that?
Will appreciate any help, thank you
Old 10-06-2009, 05:37   #9 (permalink)
Member: 347594
Thanks Meter: 1
Best Regards
Sagmaster Team
Dear gsminfo,
Send Unlock command.... ERROR
How to reset the counter block 10 attempt ?
Thank you for your help
The Following User Says Thank You to samjeff For This Useful Post:
Old 01-25-2010, 20:09   #10 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
error to write nck code with this
- Model :K3520
- Revision :11.314.17.31.00
- Phone IMEI :3534360343xxxxx
Old 01-26-2010, 07:57   #11 (permalink)
luqmaan's Avatar
Member: 617428
Thanks Meter: 52
have tried this but get the same error like everyone else unlock command error.
Old 01-26-2010, 08:38   #12 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
Originally Posted by samjeff View Post
Dear gsminfo,
http://www.unlockonline.org/Melorian-Logs.html
buy log , reset modem , insert code
Old 01-31-2010, 19:24   #13 (permalink)
Member: 1223664
Sonork: hydie4
Can someone tell me what I have to do next to get unlock code. Please
Old 02-22-2010, 13:13   #14 (permalink)
Member: 115083
Mode no..MF626 on t-Mobile is that unlockable modem?
Old 02-23-2010, 09:37   #15 (permalink)
gsminfo's Avatar
Member: 23714
zte not supported by SMTi
SMT
huawei modem unlock and use any sim worked rajdeepsaw Phone Unlocking Codes & Maps 1256 10-05-2011 11:03
SMTi Ver. 17.62 Real Time HUAWEI Modems Code Calculation by IMEI Already Started !!! gsminfo SMTi 26 06-03-2010 16:16
Huawei Modem Code Tool mohit_kripalu01 CDMA Modems , Routers , Aircard 7 08-20-2009 05:57
SMTi HUAWEI MODEM Code Writer Ver. 1.0 gsminfo Service Products News & Updates 0 06-22-2009 13:16
SMTi HUAWEI Modems unlocking by IMEI manual Step by Step ! Really simple and easy ! gsminfo Service Products News & Updates 0 05-18-2009 12:00
Page generated in 0.21603 seconds with 9 queries
