HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
07-04-2009, 15:13 | #1 (permalink) |
Product Manager Join Date: Aug 2007 Location: Inside Java
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | Bypass T-Mobile G1 Google Activation by PhoneCareCenter You must have either RC29 or earlier, or Modded RC30.(RC29 is US firmware, RC7 is UK firmware) If U have higher Versions like (RC33 US firmware or RC8 UK firmware) then u Need to Downgrade. To Check Firmware Version Do the following without Sim <enter>reboot<enter> If Phone Reboots then u have version RC29 or Lower, Skip Upgrading/Flashing Procedure. (Flash your phone to RC29/RC7 or lower to be able to Exploit Root Access) Step 1- Format the SD card to FAT32 (Make Sure of this, otherwise it wont Work. Step 2- Unzip the RC29 or RC7 image file (DREAIMG.nbh) to the SD card & Rename it to (DREAIMG.NBH) Step 3- Switch Off the Device then Insert the SD card. Step 4- Now U have to Put your G1 in BootLoader Mode (Hold Down Camera Button, and press Power Button) DO NOT DO ANYTHING TO INTERRUPT THIS PROCESS. Step 5- Press Power button to Start Upgrade/Flashing Procedure. Step 6- Once its done, Reboot your G1. For Those with RC29 or Earlier Versions, Just Follow The Below Guide. You must have ADB installed on your Computer (Extract to C: Drive), Download & Install the USB drivers. U can Manually Install when Computer Asks for the Drivers once U Connect your G1. 1- Plug your G1 & Install Drivers. 2- Without Sim Card in Your G1, <enter>setprop persist.service.adb.enable 1<enter> Even though u dont see what u typing, but u are actually executing a Command on your G1 to Enable USB Debugging in Settings. 3- Once u Execute that Command USB Drivers will be Installed again, but this time will be recognised as ADB Interface. 4- Click Start>Run>cmd> to Command Prompt 5- Type c:\adb devices (If your Device is Connected u will see it) 6- Restart your G1 but now With Sim, to see the Activation Screen then Plug USB Cable & Type c:\adb devices (to make sure u are connected) 7- Type c:\adb shell (U will see a $ sign) Just Copy & Paste this into Command Prompt (am start -a android.intent.action.MAIN -n com.android.settings/.Settings) The Settings Screen will Appear, now Switch on Wi-Fi & Connect to the Internet. 8- Now u can either Login with your Existing or Create New Account with Google. PhoneCareCenter Monrovia-Liberia McnPro Team Good Luck "Get your Codes from allGSMUnlock Server, Contact AtrixJ (MY GOOD FRIEND)for Credits, Contact me if u have any problems with this Guide & Pls no $tupid Talk like its Not working. Tested on my Personal Phone like 10 times before I made this Guide. Took me 5 hours the First Time, now takes less than 10minutes." |
The Following 113 Users Say Thank You to PhoneCareCenter For This Useful Post: |
07-05-2009, 04:53 | #5 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @amanvir When U say Many Times, How Many Exactly????? Am Interested to know, cuz I havent Seen u're Guide. McnPro Team |
The Following 2 Users Say Thank You to PhoneCareCenter For This Useful Post: |
07-09-2009, 07:27 | #6 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Juarez "Most Violent City" Age: 49
Member: 221355 Status: Offline Thanks Meter: 25 | Could you make a video of this procedure? I understand most parts, but I get confused with some of the instructions. Thanks. |
The Following User Says Thank You to Zukison14 For This Useful Post: |
07-09-2009, 19:32 | #7 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 199538 Status: Offline Thanks Meter: 54 | I don't undestand exactly what's mean ENTER-REBOOT-ENTER without SIM ... what is that,, when phone On or OFF ??? ,, what key is reboot ... more details please ..... thanks ... i need to check my firmware for continuos working in desactivate this google activation.. waiting for your help and thanks |
The Following User Says Thank You to humbedj For This Useful Post: |
07-10-2009, 01:17 | #8 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @Zukison14 Guide/Instructions are clear, wat exactly u dont understand?? Details of where u get stuck will be ok for me to help u. @humbedj When Phone is on and without sim, on the keyboard Press Enter> then Type R E B O O T> then press Enter. If phone Restarts then u're good to go, if not then u gotta follow Flashing Instructions before u Attempt the 2nd Instructions. Good Luck |
The Following 9 Users Say Thank You to PhoneCareCenter For This Useful Post: |
07-10-2009, 07:46 | #9 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 45
Member: 4021 Status: Offline Thanks Meter: 782 | hi there...im having problem with steps 6-8.... mine i think is a newer version coz it doesnt reboots if i try enter reboot enter now my problem is... when the first time i plug my android, it detects as usb storage.. so i updated d driver and it became, ADB under it is HTC DREAM.... i suppose that im doing it right coz when i go to CMD PROMPT and type ADB DEVICES... it responses and shows something like DAEMON has started... and now according to step 6.. i should reboot my phone with sim in it.... now here comes the problem... when i power on the android with sim in it, should i press the ANDROID LOGO so that it would continue to SET UP OF GOOGLE ACCOUNT?? before i connect the USB CABLE?? coz after rebooting the G1, it wont detect to command prompt ADB DEVICES anymore (BUT if i check my device manager still there is ADB DEVICE connected and in it is HTC DREAM)... it says NO DEVICES ATTACHED... no matter how i retry.... so i cant continue to step 7-8... please guide me... thanks alot!!! |
The Following 2 Users Say Thank You to ryumahon For This Useful Post: |
07-10-2009, 12:06 | #10 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @ryumahon Your G1 is a New Version, u have to follow Flashing Procedure so u can <enter>rebot<enter>. If u did that already, then Insert a Sim into the G1 & go to the Screen where u will be asked (New User/Existing User) then Plug your G1 and continue Step 6-8 (If it says Devices not Connected, just Retype it again Unplug then Replug your Device) Post your Result Good Luck |
07-10-2009, 13:21 | #11 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Quote:
The Following User Says Thank You to amanvir For This Useful Post: |
07-10-2009, 14:02 | #13 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | nice to see ur post . just one noob question . how to flash it ? where to get firmware ,rom etc? |
The Following User Says Thank You to Umair Rashid For This Useful Post: |
07-10-2009, 20:48 | #14 (permalink) |
No Life Poster Join Date: Dec 2004 Location: In Your Room Age: 47
Member: 97299 Status: Offline Thanks Meter: 43 | have formated the sd card fat 32 copyed DREAIMG.nbh to sd card renamed to DREAIMG.NBH powered off phone inserted sd card put phone in BootLoader Mode Looading checking then i gut that error 00028002 not allow any ideea ? |
The Following 2 Users Say Thank You to cover_one For This Useful Post: |
07-10-2009, 20:53 | #15 (permalink) |
Member: 574123 Status: Offline Sonork: 100.1581804 Thanks Meter: 1,839 | @cover_one Make sure u are using US Version for US Phones & UK Versions for UK.... Post Result Good Luck |
The Following 3 Users Say Thank You to PhoneCareCenter For This Useful Post: |
Bypass T-Mobile G1 Google Activation by PhoneCareCenter | PhoneCareCenter | HTC Android based | 20 | 08-01-2013 11:43 |
Bypass T-MOBILE MYTOUCH GOOGLE ACTIVATION SCREEN | kdaviator | Android based Phones / Tablets | 8 | 11-01-2011 14:29 |
Compatible USB Battery Cradle for T mobile HTC Dream G1 Google Android Phone | IPMART | ipmart WebShop | 0 | 05-08-2009 01:50 |
[22-10-08] T-Mobile G1 (Android) supported by IMEI | UnlockBase.com | UnlockBase | 1 | 10-24-2008 22:26 |
