07-20-2009, 03:26 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Pakistan
Member: 253546 Status: Offline Thanks Meter: 21 | Nokia N96 Restart on v30.033 Some times also on galley (listing music etc) Can any one else having the same problem? I have tried to downgrade it via Jaf and Mt but it can't be downgrade. Any idea what should i do? Best Regards |
07-20-2009, 03:43 | #2 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: SWEDEN-China-Thailand-Singapor
Member: 917893 Status: Offline Sonork: 100.1584763 Thanks Meter: 3,156 | Quote:
try reflash. is certs ok in it ? | |
07-22-2009, 07:02 | #5 (permalink) |
Member: 253546 Status: Offline Thanks Meter: 21 | I have tried to downgrade but n96 can not accept the lower/downgrade firmware it can not start on v20, starts and switch off on nokia logo, so i must use latest V30 |
08-07-2009, 07:59 | #6 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1067108 Status: Offline Thanks Meter: 4 | Same problem! I tried to downgrade to versione 20 and also to write a good pm taken on this forum, but phone continue to restarts 7, 8 times a day. Also when it is in stand-by mode. Someone has solved this problem? |
08-10-2009, 05:13 | #9 (permalink) |
No Life Poster Join Date: May 2007 Location: GSM WORLD
Member: 510122 Status: Offline Sonork: 100.1606547 Thanks Meter: 1,822 | This type problem creat superdata dongol crope........ try to check in Mx key and read info there you can see superdata dongol valid or invalid if superdatadongol data is invalid you must write RPL............. Br. amar181 |
08-14-2009, 00:17 | #11 (permalink) |
Junior Member Join Date: Nov 2007
Member: 630527 Status: Offline Thanks Meter: 0 | same problem pls help my phone restart fw30 ..... ipdc_err.txt on drive c:\ 01/01/2009 11:00:14 01/01/2009 11:00:14 01/01/2009 11:00:14 ------- Subsystem Ipdc Manager error ------- 01/01/2009 11:00:14 Emitting module: ager\Server\src\cipdcmanager.cpp line: 412 01/01/2009 11:00:14 Error code: 0 01/01/2009 11:00:14 Description: MBC version mismatch, doing full reset 01/01/2009 11:00:14 Additional info: (none) 01/01/2009 11:00:15 01/01/2009 11:00:15 01/01/2009 11:00:15 ------- Subsystem Ipdc Database error ------- 01/01/2009 11:00:15 Emitting module: abase\src\cipdcdatabasebasen.cpp line: 120 01/01/2009 11:00:15 Error code: -1 01/01/2009 11:00:15 Description: Database open failed 01/01/2009 11:00:15 Additional info: (none) |
10-22-2009, 12:41 | #12 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | Quote:
its watch dog timer problem the one & only one solution full rpl coz its pm field 120 & 308 is protected | |
10-25-2009, 12:10 | #15 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Quote:
!!! [+] 100% solution - n96 restart on nokia logo [+] !!! | Y.P.Y | Nokia Base Band 5 ( BB-5 ) | 21 | 07-29-2010 11:25 |
!!! [+] 100% solution - n96 restart on nokia logo - solution [+] !!! | Y.P.Y | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 07-07-2010 23:25 |
Nokia N96 Restart on v30.033 | farrukhayub | Nokia Base Band 5 ( BB-5 ) | 12 | 12-24-2009 13:13 |
