Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 08-14-2009, 15:56   #1 (permalink)
Member: 1087454
Thanks Meter: 538
Exclamation ZTE MF626 unlock Free
How to Unlock a ZTE MF626 3G Wireless Modem
Download Unlocked Firmware for it here:
http://web.portal.globe.com.ph/visib...OBE_PHV1.2.exe
Remember to remove SIM card before running the updates.
If you are with Telstra & want the SIM balance & re-charge utility, go to
http://www.zte.com.au/main/Product_D..._downloads.htm
to download the "Upgrade Tool"
http://www.zte.com.au/downloads/soft...M02_Uptool.zip
It will be still be unlocked after running the update.
If you want generic connection software go to the 3 site.
http://three.cachefly.net/Software/M...0Broadband.zip
installation of 3 mobile broadband connection manager for Australia which apparently works with UK settings (and other sims)
unplug modem
uninstall globe/telstra/or other connection software
reboot
install aussie 3 connection manager
plug modem in and let it detect the drivers (if any fail, point it at C:\Program Files\3 Mobile Broadband\drivers)
load dash and add your settings
I unlocked 2 ZTE MF626's using this procedure, I don't claim to be original author of this, also found how to unlock a ZTE MF627, still looking 'how to unlock a ZTE MF636'.
The Following 42 Users Say Thank You to possum22 For This Useful Post:
Old 08-14-2009, 16:01   #2 (permalink)
Member: 1087454
Thanks Meter: 538
Other settings:
o2 Contract SIM:
Config Name = O2
Dial Number= *99#
user = faster
pass= password
APN= mobile.o2.co.uk
DNS servers= 193.113.200.195
3 SIM:
Internet
APN: three.co.uk
IP address: Leave blank
Username: Leave Blank
Password: Leave blank
or try the following;
APN: 3internet
dial number is *99#
password: leave blank
username leave blank
BT Mobile SIM:
Internet
APN: btmobile.bt.com
IP address: 212.183.137.12
Username: bt
Password: bt
URL: http://wap.btmw.net
o2 SIM:
APN: mobile.o2.co.uk
Username: mobileweb
Password: password
Primary DNS: 192.113.200.200
Secondary DNS: 192.113.200.201
SMTP gateway (for email): smtp.o2.co.uk
Orange SIM:
APN: orangeinternet
Username: Leave blank
Primary DNS: 193.035.131.194
SMTP gateway (for email): smtp.orange.co.uk
T-Mobile SIM:
APN: general.t-mobile.uk
Username: user
Password: pass
Primary DNS: Set automatically
SMTP gateway (for email): smtp.t-email.co.uk
Vodafone SIM:
APN: internet
Username: web
Password: web
Primary DNS: 158.043.240.004
SMTP gateway (for email): smtp.vodafone.net
The Following 5 Users Say Thank You to possum22 For This Useful Post:
Old 08-14-2009, 16:17   #3 (permalink)
quickgsm's Avatar
Member: 414755
Sonork: quickgsm
Thanks Meter: 389
good work nice job man !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The Following User Says Thank You to quickgsm For This Useful Post:
Old 08-14-2009, 16:47   #4 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
will it work for MF622 ?
Old 08-15-2009, 02:10   #5 (permalink)
Member: 1087454
Thanks Meter: 538
I wouldn't think so, might brick it!
The Following User Says Thank You to possum22 For This Useful Post:
Old 08-15-2009, 04:25   #6 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 788
.:Here is ZTE MF627:. unlock solution
http://forums.moneysavingexpert.com/...html?t=1703797
Dont forget to give THANKS
The Following 16 Users Say Thank You to srkhan For This Useful Post:
Old 08-15-2009, 23:11   #7 (permalink)
Member: 317043
Thanks Meter: 25
This solution already' tried before, with new version of mf627 it doesn't work, also dc-unlocker they have problem. On new version of mf627 it hides 1 drive.
The Following 4 Users Say Thank You to darkinside For This Useful Post:
Old 08-17-2009, 11:41   #8 (permalink)
Member: 718578
One question.
When I load program from this address: http://web.portal.globe.com.ph/visib...OBE_PHV1.2.exe I can't click on DOWNLOAD button, so I can't update MF626 modem. I am using T-Mobile ZTE MF626 and signal is low now so I would like to unlock it and use on other network.
Anyone to help?
Old 08-20-2009, 10:37   #9 (permalink)
Member: 1087454
Thanks Meter: 538
It doesn't work the newer '3 AU' version of ZTE MF627 I got (about 4 months old).
The flash update program doesn't detect it, it doesn't have a diagnostic port like Telstra MF626's have, apparently the newer MF626's sold by T-mobile, don't have it either!
Old 08-20-2009, 18:42   #10 (permalink)
Member: 658542
Thanks Meter: 6
will it work with the MF622 usb modem?
Old 08-23-2009, 23:11   #11 (permalink)
Member: 1087454
Thanks Meter: 538
Old 08-23-2009, 23:16   #12 (permalink)
Member: 1087454
Thanks Meter: 538
Unhappy
Originally Posted by ZeLjkO_PG View Post
One question.
Anyone to help?
Must be like the new version of the MF627 from '3'.
Old 08-24-2009, 07:35   #13 (permalink)
Member: 317043
Thanks Meter: 25
The new model zte mf627 (626) with firmware: BD_3GHAP673A4V1.0.0B05; unlock or upgrade is not possible because it has a hidden drive, diagnostic port doesn't appear, in the precedent model yes.
The Following 3 Users Say Thank You to darkinside For This Useful Post:
Old 08-31-2009, 09:37   #14 (permalink)
motursa's Avatar
Member: 112034
Thanks Meter: 59
I have a ZTE MF626, and continued throughout the procedure and to unlocked, but does not work with Original SIM, just find other networks, but does not work with the original SIM, anyone know how I can do to return to work? find only 850mhz and 900MHz networks, I need 1900MHz network
Old 09-02-2009, 19:58   #15 (permalink)
Member: 1087454
Thanks Meter: 538
What network are you on?
Do they have firmware updates for my modem or try www.zte.com. your country code for updates.
ZTE MF626 Ho To Unlock DaWizard VygisToolbox 3 08-21-2010 07:36
zte mf626 unlock ruffmeup Phone Unlocking Codes & Maps 0 03-13-2010 15:43
ZTE MF626 Modem Unlock Done ... Free Tools Sydney_Unlocker GSM / HSDPA Modems and Routers 0 11-01-2009 07:11
ZTE MF626 unlocking? heinz57g KULANKENDI Server 15 01-22-2009 13:36
ZTE C335 Unlocker FREE For All!!!!!! abeq Various CDMA/TDMA Cell Phones 11 11-08-2008 14:49
Page generated in 0.29989 seconds with 9 queries
