09-16-2009, 11:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Problems in Unlock 5800, N85, N96 Ver 30.0.11 and 31.0.8 Is happening always more often people opening threads for problems in unlock of rapido SL2 like the 5800 with firmware 30.0.11 or 31.0.8 This version of firmware, if we try to unlock using the NCK codes gives you error BB5 Unlock Failed -> Failed to get Lock Key (6, 5) The only mode we have at the moment to unlock it is via downgrade. Not all the models can be unlocked using this system!! before you start is better to check if it can be done or not: how to? Just read the PM and make the simlock RPL using the function "create RPL frm PM": if the simlock_key_data are 3 lines, it can be done. If are 8 lines no chances. The steps for a safe Downgrade, unlock ad re-update are simple but must be done in the exact sequence. A) made all the back-ups (Tab Common/info "READ PM", tab BB5/Security "CREATE RPL FROM PHONE" and tab BB5/Security "READ ALL CERTS") plus a Simlock rpl using the function "create RPL from PM" and selecting the PM back-up. B) Dowload the firmware versions you need for the job 21.0.25 for the downgrade and 30.0.11 or 31.0.8 (Depending the actual version of the mobile) for the re-upgrade and this recovery kit which must be unzipped in the common firmware folder as E71 (normally c:\Program files\Nokia\Phoenix\Products\RM-346). C) Downgrade the mobile to the version 21.0.25 using the files related to the original product code of the mobile D) In the tab bb5/security Thick "plain RPL" and write the Security RPL you made doing "create RPL from PM" E) Unlock the mobile using the NCK codes (Keep a copy of the calculate codes in a side) F) flash the mobile with the erase file 5800_Erase_256MB_kashi4gul with "Skip APE" Thicked. G) flash the mobile as E71 v300 product code 0559569 with "skip APE" thicked ONLY COR and PPM. the mobile now should be readable and you can see the infos with damaged imei as you are working on a RM-346; if you can't read the infos or the mobile just vibrate if you try to power it on manually flash it using the RM-356 ENO file included in the recovery package (Skip APE Thicked) and flash again the MCU E71 in the mobile (Skip APE Thicked) H) write the full PM you have from the original back-up I) flash it again with the 5800 firmware V30 or 31 was in origin in the mobile J) write back the FULL RPL Back-up if you now read the infos in the mobile the logs will be perfect with the mobile locked again as before K) go in the tab BB5 security and click on sx4 auth.. the mobile should get the sx4 auth without any problem L) go in the tab common/info, SX4 bypass NOT THICKED and click on write PM selecting full PM back-up you made in origin M) go in the tab bb5/security and in the area NCK input via Fbus the unlock code calculated #pw+..+7# Job done.. you can connect the battery back and test the mobile Note : procedure revised to be sure the mobile is 100% without watch dog problems Note 2 : for the N85 the procedure is the same, just after the point "E", once you got the unlocking code, go directly to the step 1 of this post : http://forum.gsmhosting.com/vbb/show...&postcount=127 Note 3 : for the N96 the procedure is the same, just after the point "E", once you got the unlocking code, go directly to the step 1 of this post : http://forum.gsmhosting.com/vbb/show...1&postcount=81 BR Alex Last edited by moulnisky; 01-20-2010 at 20:52. |
The Following 114 Users Say Thank You to moulnisky For This Useful Post: |
09-16-2009, 22:53 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | After this unlock producere phone will not restart after 5-10 min? Because use mt box with rapido rpl, phone always restart! |
09-16-2009, 23:12 | #4 (permalink) | |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
BR Alex | |
09-17-2009, 13:37 | #5 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Spain Age: 51
Member: 13716 Status: Offline Thanks Meter: 8 | Hi, I downgrade to v25, write bak rpl, and unlock.... see log: Code: MCU Version V ICPR72_09w20.5 MCU Date 16-06-09 Product RM-356 Manufacturer (c) Nokia IMEI 354183025283447 Mastercode 5445644022 IMEI Spare 3A45810352824304 IMEI SV 3345810352824344F3000000 PSN CZB492346 Product Code 0559051 Basic Product Code 0578897 PSD 0000000000000000 LPSN 0 WLAN MAC 00247D390D8A APE SW V 30.0.011 APE Variant V 30.0.011V 30.0.011 V 30.0.011 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP ICPR72_09w19_1 Simlock Server SIMLOCK SERVER Simlock Key 2140300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21403F Scanning avaiable products... Processing C:\Archivos de programa\Nokia\Phoenix\Products\... Found 61 products, Filtering BB5 Products - wait... 1 Products left after filtering. Ready. Retrieving Variants for Product RM-356 - wait... 60 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK RPL backup thread finished, continuing... Backing up simlock... MCU Version V ICPR72_09w20.5 MCU Date 16-06-09 Product RM-356 Manufacturer (c) Nokia IMEI 354183025283447 Mastercode 5445644022 Simlock backup OK, saved to RM-356_354183025283447_17092009_141954.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing RM-356_21.0.025_prd.core.C00 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM-356_21.0.025_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.875s Writing all blocks... Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*ENO Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 124.828s Restarting MCU... Processing RM-356_21.0.025_prd.core.C00 (APE)... Processing RM-356_21.0.025_prd.rofs2.V09 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM-356_21.0.025_prd.rofs2.V09, Type: Flash Image, Algo: XSR 1.5, BB5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x06560000-0x0915FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.234s Writing all blocks... Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 44.625s Restarting MCU... Processing RM-356_21.0.025_prd.rofs2.V09 (APE)... Processing RM-356_21.0.025_C01_prd.rofs3.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM-356_21.0.025_C01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x09160000-0x09E5FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.78s Writing all blocks... Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 1.844s Restarting MCU... Processing RM-356_21.0.025_C01_prd.rofs3.fpsx (APE)... Processing RM356_20.0.010_008_xxx_U01.uda.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RM356_20.0.010_008_xxx_U01.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x09E60000-0x0F71FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.468s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 7.188s Restarting MCU... Processing RM356_20.0.010_008_xxx_U01.uda.fpsx (APE)... All images processed OK! Processing post flash tasks... Reading info... MCU Version V ICPR72_09w06.2 MCU Date 03-03-09 Product RM-356 Manufacturer (c) Nokia IMEI 354183025283447 Mastercode 5445644022 IMEI Spare 3A45810352824304 IMEI SV 3345810352824344F1000000 CNT v 20.0.010_008_xxx_U01, 21-01-09, vanilla, RM356 PSN CZB492346 Product Code 0559051 Basic Product Code 0578897 PSD 0000000000000000 LPSN 0 WLAN MAC 00247D390D8A APE SW V 21.0.025 APE Variant V 21.0.025V 21.0.025 V 21.0.025 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP tube_ICPR72_09w06_p1 Failed to read info -> Failed to read SP info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Processing FLASHBUS Part... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! MCU Version V ICPR72_09w06.2 MCU Date 03-03-09 Product RM-356 Manufacturer (c) Nokia IMEI 354183025283447 Mastercode 5445644022 IMEI Spare 3A45810352824304 IMEI SV 3345810352824344F1000000 CNT v 20.0.010_008_xxx_U01, 21-01-09, vanilla, RM356 Product Code 0559051 Basic Product Code 0578897 PSD 0000000000000000 LPSN 0 WLAN MAC 00247D390D8A APE SW V 21.0.025 APE Variant V 21.0.025V 21.0.025 V 21.0.025 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 0559 RFIC 17141715 DSP tube_ICPR72_09w06_p1 Failed to read info -> Failed to read SP info BB5 Unlock Started... MCU Version V ICPR72_09w06.2 MCU Date 03-03-09 Product RM-356 Manufacturer (c) Nokia IMEI 354183025283447 Mastercode 5445644022 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 2140300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1080011815710052F573870A13F922C3A4DFA78C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... BB5 Unlock Failed -> Failed to get Lock Key (6, 5) Last edited by acyl2000; 11-09-2009 at 11:26. Reason: wrap [code] |
The Following User Says Thank You to ja_palma For This Useful Post: |
09-17-2009, 16:58 | #7 (permalink) |
Member: 13716 Status: Offline Thanks Meter: 8 | I did and I get the same error before flashing: "Failed to read info -> Failed to read SP info" when read info phone, before unlocking same error: "BB5 Unlock Failed -> Failed to get Lock Key (6, 5)".... thanx in advance |
09-17-2009, 17:14 | #9 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | The mobile is on retevision movil spain and looks like it has been unbranded in the past. Can you tell me please what is the product code on the lable under the battery? BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
09-17-2009, 17:23 | #10 (permalink) |
Member: 13716 Status: Offline Thanks Meter: 8 | yes, retevision spain.... I spoke with the client and confirmed to me that has changed the product code to 0559051 for unbranded and upgrade the phone via usb with nokia updater. The original product code under the battery is 0576022. i can do? flash again with firmware v25 with product code original? thanxxx |
09-17-2009, 17:53 | #12 (permalink) |
Member: 13716 Status: Offline Thanks Meter: 8 | Thanx.... I have to change the product code for the original before flash? My nokia datapackage v25.0.025 does not include the product code 0576022, I downgrade it once again to a lower version of firmware which include my product code? thanx in advance |
09-17-2009, 17:59 | #13 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | may be is a better solution too or you can look using navfirm for the files you need http://rapidshare.com/files/23592893...rm-0.1-bin.zip BR Alex File list : RM-356_21.0.025_prd.core.C00 RM-356_21.0.025_prd.rofs2.V09 RM-356_21.0.025.228.02.rofs3.fpx RM-356_21.0.025_018_xxx_U01.uda.fpsx Last edited by moulnisky; 09-17-2009 at 18:07. |
The Following 5 Users Say Thank You to moulnisky For This Useful Post: |
09-17-2009, 18:50 | #14 (permalink) |
Member: 13716 Status: Offline Thanks Meter: 8 | I use navifirm to update 0576022 variant in v25 firmware, change product code to original, flash with original product code and write back rpl, now simlock is ok, unlock using the NCK codes and sinlock continue ok, I have to upgrade obligatorily again to v30.0.11? phone should work with firmware v25? My datapackage v30.0.11 does no include product code 0576022 and I don´t found it in navifirm. thanx in advance |
09-17-2009, 18:55 | #15 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Now you can change the product code and upgrade it back... yes.. is better you upgrade it again to prevent the mobile going in watch dog as the structure of the PM308 wouldn't fit the firmware .25 and could give you problem about the superdongle. Keep written on a piece of paper the unlock code used BR Alex |
Nokia 5800 XM RM-356 firmware 30 and 31.0.101 - service manual | pitone02 | Nokia Base Band 5 ( BB-5 ) | 1 | 11-06-2009 23:03 |
Anybody unlocked N96 ver 30. without WD problem | harim_1981 | Genie Universal | 3 | 10-06-2009 05:52 |
Anybody unlocked N96 ver 30. without WD problem | harim_1981 | Genie Universal | 0 | 09-30-2009 17:08 |
Problems in Unlock 5800 - refuses password | johnete | Cyclonebox | 14 | 09-30-2009 13:16 |
n96 problem in unlocking | ..::Mobile Smoker::.. | Genie Universal | 3 | 03-20-2009 13:35 |
