Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > LG > LG Hardware Repair Section
Old 09-25-2009, 07:35   #1
ZubairArain
ZubairArain's Avatar
Member: 751908
Sonork: ZubairArain
KG195 "Waring: Invalid Charger"
LG KG195 warning "Warning: Invalid Charger" when connect charger. Any solution from anyone. plz urgent.
ZubairArain
The Following 3 Users Say Thank You to ZubairArain For This Useful Post:
Old 10-08-2009, 22:08   #2
rkhurramnazajk
Member: 1130822
ZubairArain
check baterry terminal centeral pin
The Following 2 Users Say Thank You to rkhurramnazajk For This Useful Post:
Old 10-13-2009, 05:59   #3
bruightmobile
Member: 1087294
change original battery or original charger
insha ***** ur problem solved
don't forget to say thanks
The Following 3 Users Say Thank You to bruightmobile For This Useful Post:
Old 11-04-2009, 16:21   #4
Faisa Farooq
Member: 299534
how to solve ''invalid charger''
1st.check the battery
2nd.check battery terminal
3rd.check charger's voltage often charger send increase voltage then start this problem so search a ok and geniune charger and check it.........
i try this and set will be ok
please don't forget for thanks
The Following 2 Users Say Thank You to Faisa Farooq For This Useful Post:
Old 11-07-2009, 07:39   #5
sihraja
Member: 906272
check centrel pin but problem is not solved
The Following User Says Thank You to sihraja For This Useful Post:
Old 11-07-2009, 07:42   #6
sihraja
Member: 906272
Check central pin but problem is not solved.
Old 11-10-2009, 11:25   #7
chalia
Member: 642374
just use nokia orginal charger and lg pin sirrrrrrrrrrrrrrrrrrr
Old 11-11-2009, 08:40   #8
guljee786
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Wink
ZubairArain
Bro check this..
this solution when charging are increasing from chargrer if u make this jumper ur problem ill b solve
Guljee
Old 11-12-2009, 17:20   #9
zaka_53
Member: 562003
goooooooooooooooood brother
Page generated in 2.03999 seconds with 6 queries
