Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Motorola > Motorola Hardware Repair Section
Motorola Hardware Repair Section here all threads Related to Motorola Hardware Servicing and Repairing.
Old 09-28-2009, 13:14   #1
bedel
Member: 321176
W5 Key Pad Problem
Hello, Motorola W5 Has problems with the Key Pad, The key #8 Constant Appears in the Screen and Becomes as crazy, please Our Guy's has Solution for this Problem.
Thank Bed.
The Following User Says Thank You to bedel For This Useful Post:
Old 10-24-2009, 18:49   #2
freakrazy
Member: 1027041
friend i am colombian so my english is not good,,,sorrry,,,,,,,,but you now trai with the flex??????????
Old 11-03-2009, 06:02   #3
dairymilkpapy
Member: 1152475
Sonork: 642658
My final solution was to take the upper [COLOR=blue ! important][COLOR=blue ! important]LCD [COLOR=blue ! important]screen[/COLOR][/COLOR][/COLOR] part of the housing apart and **** out around the side buttons, but I tried a lot of other tricks before I fixed my keypad. You will need a T4 driver and a small plastic card or prybar (and good finger nails) to open the case. Just ****ing around the keys with compressed air did not help. I had to open the case up, let the prssure off the side keys and and bow the dirt out with compressed air. I then wiped out everything with alcohol on a Qtip just to make sure everything was clean.
Hope this helps.
thailand holiday deals
*******s online
Old 11-09-2009, 14:39   #4
bedel
Member: 321176
Hope this helps.
*******s online
Thank, "dairymilkpapy" I Have experience for Cell phone Hardware Repair the Phone is Very Clean Hey "freakrazy" what are you talking about Flex you refered at 'Flex Firmware' or 'Flex Cable' if are flex cable forged because key pad are integrade on PCB same unit but if you talk about Flex Firmware please explain more, also I are Cuban can sent PM in Spanish.
Thank in Advance.
Bed.
Old 11-09-2009, 14:41   #5
bedel
Member: 321176
W5 Keypad Problem
Hope this helps.
*******s online
Thank in Advance.
Bed.
Page generated in 1.09538 seconds with 6 queries
