Old 11-08-2009, 06:31   #1
reaj
reaj's Avatar
Member: 631470
Arrow 1208 Show Nokia
1208 Water damage set.
I Flash It, Flash Ok But when I push the power switch mobile show Nokia.
Help pl.............................
Old 11-08-2009, 06:33   #2
RIZWANJAT
RIZWANJAT's Avatar
Member: 1050335
Sonork: 100.96902
..::Brother full erase and flash 4.11 version and write good pm and do unlock not solved so re hot FLASH IC::..
RIZWANJAT
Old 11-08-2009, 06:47   #3
imran zafar
imran zafar's Avatar
Member: 328187
Sonork: MBDin.fleeforum.com
its not a software problem''''
wash ur set upto 3 time with CTC and give
a little heat to CPU all will b ok....
The Following 2 Users Say Thank You to imran zafar For This Useful Post:
Old 11-08-2009, 07:02   #4
mobilecitycbk
mobilecitycbk's Avatar
Member: 475440
clean completely and rehot the pcb if not rehot cpu & flash with past
Old 11-08-2009, 07:08   #5
sumon.bd
sumon.bd's Avatar
Member: 445578
just rehot upp and uem will be ok 100%
Old 11-08-2009, 08:27   #6
reaj
reaj's Avatar
Member: 631470
Problem Solve. Clean the pcb and Remove Light Ic. No need to other.
Old 11-08-2009, 08:34   #7
romajess
Member: 1054255
Sonork: BISMILLAH.M.S.CENTER
Thanks for new salution.
Old 11-08-2009, 08:41   #8
Jocell_2
Member: 878992
so the phone must be without light?
may i make a little correction?
may be You mean REPLACE LIGHT IC???
Old 11-08-2009, 08:59   #9
reaj
reaj's Avatar
Member: 631470
Next Light problem....................... solve you. thanks to join us
Old 11-08-2009, 11:40   #10
jamohaki
Member: 83397
i have 1202 with same problem flash ok but when power on only hang at nokia, lights are not working phone was water damage.any solution please?
Old 11-08-2009, 12:39   #11
wase
Member: 871095
Sonork: 123
Bro try rehot cpu its work 100%
Old 11-08-2009, 12:53   #12
dil7689
Member: 1080396
Old 11-08-2009, 17:12   #13
mutunmobile
Member: 570193
broher cheng upp good luck
Old 11-08-2009, 19:54   #14
kalpesh naik
Member: 929232
Sonork: kalpesh
any one help me for nokia 5310 camera not working water damge handset
Old 11-11-2009, 05:05   #15
mobilecare_titt
Member: 714467
clean the pcb ,rehot upp if not ok means reboll upp,ur problem is solve otherwice change upp
Page generated in 0.08446 seconds with 6 queries
