![]() ![]() Join Date: Feb 2002
Member: 9505 Status: Offline Thanks: 0
for Universal team
hello
I have a rm-437 e63-1 broken remained in the process of liberation. TBB5ReadInfoThread 2.8.1.2191 started at: 2009/11/18 12:55:46 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing phone... Output power at Line1 3,99V is in range of: 4,00V ±10,0% Phone powered. Reading Info... Soft Version: V ICPR71_08w44.1 Date: 30-10-08 Type: RM-437 (E63-1) Pack: (c) Nokia Product code: 0583838 Product code: 0561985 WLAN MAC: 0023B4CFE73A Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I / WCDMA VIII Original IMEI: 356836-02-******** Production serial: M7J116013 HW Version: 0802 DSP Version: Sofie_ICPR71_08w41 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [01000407031E] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21401F Block: 2; Lock: 1; State: Closed; Data: 21401F Security code: 12345 -------------------------------------------------------------------------------- TBB5ReadInfoThread 2.8.1.2191 finished at: 2009/11/18 12:56:22 Done. TBB5PatchUnlockThread 2.8.1.2191 started at: 2009/11/18 12:56:23 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Reading Info... Soft Version: V ICPR71_08w44.1 Date: 30-10-08 Type: RM-437 (E63-1) Pack: (c) Nokia Product code: 0583838 Product code: 0561985 WLAN MAC: 0023B4CFE73A Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I / WCDMA VIII Original IMEI: 356836-02-******** Production serial: M7J116013 HW Version: 0802 DSP Version: Sofie_ICPR71_08w41 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [01000407031E] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21401F Block: 2; Lock: 1; State: Closed; Data: 21401F Security code: 12345 Reading PM... MCU BB5SL2 Version: 1.022, and up to date. SMCU BB5SL2 Version: 1.22, and up to date. Input power: 4,84V OK. Output power at Line1 3,99V is in range of: 4,00V ±10,0% Asic ID: 000000010000022600010006400C192101031103 EM Asic ID: 00000296 EM Asic ID: 00000B22 Public ID: 1CB00113E0418B522457915FB55DEC9756E6F22E Asic Mode ID: 00 Hash: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 Flashing file: BB5 [BB5 ALGORITHM] MCU File: PatchUnlock 0 kB Speed: [3000k, 3250k, 3250k, 98k] Baud. Supported Hardwares: [400C192101031103] Input power: 4,86V OK. Output power at Line1 3,99V is in range of: 4,00V ±10,0% Calculating code... Connecting to server: US2 Credits: 5 Credits Left: 5 Boot Loader: RAPIDOv11_2nd.fg 15 kB Version: 1.30.0 Supported Hardwares: [0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105] Asic ID: 000000010000022600010006400C192101031103 EM Asic ID: 00000296 EM Asic ID: 00000B22 Public ID: 1CB00113E0418B522457915FB55DEC9756E6F22E Asic Mode ID: 00 Hash: 9A28E119033B91D14D22838C86D0D53C ROM ID: 4B9B75103E691FF8 Initializing phone... Output power at Line1 3,99V is in range of: 4,00V ±10,0% Phone powered. Reading Info... Soft Version: V ICPR71_08w44.1 Date: 30-10-08 Type: RM-437 (E63-1) Pack: (c) Nokia Product code: 0583838 Product code: 0561985 WLAN MAC: 0023B4CFE73A Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I / WCDMA VIII Original IMEI: 356836-02-******** Production serial: M7J116013 HW Version: 0802 DSP Version: Sofie_ICPR71_08w41 LCD Version: APE ADSP Version: 256 SIMLock service: SIMLOCK SERVER [01000407031E] Profile bits: 0000000000000000 Simlock config: 2140100000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Closed; Data: 21401F Block: 2; Lock: 1; State: Closed; Data: 21401F Security code: 12345 Writing PM... Initializing phone... Output power at Line1 3,99V is in range of: 4,00V ±10,0% Initializing phone... Output power at Line1 3,99V is in range of: 4,00V ±10,0% Initializing phone... Output power at Line1 3,99V is in range of: 4,00V ±10,0% Initializing phone... Output power at Line1 3,99V is in range of: 4,00V ±10,0% -------------------------------------------------------------------------------- TBB5PatchUnlockThread 2.8.1.2191 finished at: 2009/11/18 13:00:05 Terminated with error: 00010071.00015018.00019320 MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBQYV1QI] I used the repair function with credits and has not repaired, but the credits if I have discounted the the phone connects via fbus not only by usb. requires an urgent solution to repair the phone. What happens to the credits granted?. Wait for an answer. greetings hommeron@msn.com |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 643472 Status: Offline Sonork: 100.96901
Hello,
Is your phone is locked or broken SIMLock ? As I see in logs phone is locked so you've to unlock it using simlock repair button and It costs you 75cradits. Hope this helps. BR, Ali |
hello
I have used the repair function, cost me 75 credits, and not repaired. connects the FBUS telofono not only connects via USB thanks for your interest |
![]() ![]() ![]() ![]() Join Date: Mar 2009
Member: 986273 Status: Offline Sonork: 0345-8726777
#5 | ||
BR, Ali |
hello
I have already tried the power adapter connected, but still not connecting the phone by FBUS greetings |
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004
Member: 87357 Status: Offline Sonork: 100.1574043
yes
not connected by FBUS |
hello
I have to flash with USB version 200.21.012, but not settled greetings |
