Member: 791869 Status: Offline Sonork: el de
how to unlock C5110
helps the phone unlock
![]() ![]() ![]() Join Date: Dec 2002
Member: 19254 Status: Offline Sonork: 100.72990
use nspro v5.5.7
Select C5510 then click GET INFO and fallow the software instructions. Then enter the codes manualy to unlock the phone |
#3 | |
![]() ![]() ![]() ![]() Join Date: Jun 2008
Member: 803622 Status: Offline Thanks: 350
when try to get info, follow all the procedure but when connect the phone the software just close it self. Please HELP sir, can not unlock C5510 model |
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Member: 177568 Status: Offline Thanks: 1
same here, I have been trying for the last 2 weeks. Nspro just crashes and closed when I click on get info...
![]() ![]() ![]() Join Date: Nov 2004
Member: 91045 Status: Offline Sonork: 100.1577222
Drivers INstalled properly ? from NSPRO folder ..
mostly i say Confliction (happend to me also) but solved |
![]() ![]() ![]() ![]() Join Date: Jul 2007
Member: 538861 Status: Offline Sonork: 100.1578309
I also had this problem, so I went into device manager and uninstall all handset drivers then replug the handset and re install them and it fixed my problem 100%
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2003
Member: 21365 Status: Offline Thanks: 1
Well...
..I menage to read codes BUT...phone freeze with other sim and with original working just fine...no way for me to enter unFreeze code (using Master code readed by NS)...any sogestion?
PS...I tried EVERY thing posted here, on Forum.... |
power on the phone with any unaccepted sim card inside.
when the phone show "phone freesed..." type in the master lock code then press OK (center) key Then the phone will ask for net lock code. Type in the net lock code and the phone will be unfreezed and unlocked. |
| The Following User Says Thank You to Elco For This Useful Post: |
