Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Alcatel TCL > BF, BG, TH, BHx Series
BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here.
Old 06-08-2003, 00:54   #1
zthree3
Member: 30499
dead 511 and with wrong imei
ive got an alcatel 511.with wrays 5.5 it doesnt connect with henrich 1.82 it shows wrong imei.and with another alcatel using wrays5.5 it shows be a imei with letters hardware n phone version unknown cud sum1 plz help me urgently.thanx all
Old 06-08-2003, 01:52   #2
Porter
Porter's Avatar
Member: 19633
Can You read flash? if Yes, it seems a soft problem but in Youre case (wrong IMEI) maby not original flash uploaded (tech zone dameged) then no solution But if Tech is original - just use repaire flash.
if can`t read flash - it is HD problem. try rehot PCB
Old 06-08-2003, 15:05   #3
NSerN
NSerN's Avatar
Member: 8599
Read full flash with Wray and then use button "Repair Checks" and select you flash.
If TEH zone have bad CRC foget to repair phone!
If TEH good, do as wrote Porter - use repair flash or seach hardware problem.
Old 06-08-2003, 19:57   #4
zthree3
Member: 30499
how do i no if tech is damaged?cant i load another tech from a diferent phone?thanx
Old 06-09-2003, 09:28   #5
sm0lly
sm0lly's Avatar
Member: 23255
You must use only your ORIGINSL Tech-zone. If you made a backup before flashing, your ORIGINAL tech-zone was saved. If not... there is no solution.
ALWAYS make backup!!!
Old 06-09-2003, 13:04   #6
chip_2000
chip_2000's Avatar
Member: 22400
all easy
have origanal teh - succeful
no have original teh - no solution
Page generated in 0.09781 seconds with 6 queries
