Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Alcatel TCL > BF, BG, TH, BHx Series
BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here.
Old 06-12-2003, 15:01   #1
alex3
alex3's Avatar
Member: 23408
bf4 blink but don't turn on
Hi guys any solution
Old 06-12-2003, 15:33   #2
shaaker
shaaker's Avatar
Member: 23695
Sonork: 100.64383
try this write full backup,and rewrite original teh zone and post working or not B.R
Old 06-12-2003, 17:00   #3
alex3
alex3's Avatar
Member: 23408
tested dont work
Old 06-13-2003, 02:49   #4
poweruser
Member: 31324
I have a BF4 with the same problem. Can someone link a working cable schematic so that I can make some tests? The one i found doesn't work for my phone.
Thank you
Old 06-13-2003, 02:56   #5
shaaker
shaaker's Avatar
Member: 23695
Sonork: 100.64383
http://www.tar.hu/shaaker/bfx_cable.zip
Old 06-13-2003, 10:59   #6
poweruser
Member: 31324
Thank you for the scheme, but the link doesn't work
Here the error I get with Henrich's software
ERROR - Phone don't answer correct R1
Any ideas?
Thank you
Old 06-14-2003, 10:18   #7
netroid
Member: 31446
try first connect with wray, disconnect and then connect with henrich. on some pc this is one way to make henrich software work.
Old 06-14-2003, 10:30   #8
Crew
Member: 1408
Re: bf4 blink but don't turn on
100% hardware problem
WBR
Crew
Old 06-14-2003, 11:05   #9
poweruser
Member: 31324
nothing to do, it doesn't work. When connected to the serial port it keeps blinking and then turning off. Wray doesn't connect, and even Henrich does not.
Technical assistance says it's "damaged software"...
Are you using a cable with MAX 232 and 1uF Capacitor? I've found some schemes with MAX 3232 (same as 232 but for low voltage applications) and 2uF capacitors..
Maybe the cable? (but why it sometimes recognizes the flash?)
Bye
Old 06-15-2003, 11:52   #10
gsmspace
Member: 4174
LIKE CREW SAID 100% hardware prb
solution 100% worcking for me
just open phone and rehot chips neer sim card connector
Old 06-16-2003, 02:43   #11
poweruser
Member: 31324
What do you mean for "rehot"? Sorry but I'm not English
The phone is already opened but those chips are covered (there's a metallic box covering them). Can you explain me how to reach those chips and what to do then?
Thank you
Old 06-16-2003, 17:09   #12
gsmspace
Member: 4174
remove metallic box and
tray to reflow them if not work and
if you are master of BGA soldring u can remove and resolder them back
Old 06-17-2003, 09:59   #13
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
When phone blinks don't touch software
it's 100% hardware common problem in 511
Old 06-17-2003, 13:25   #14
poweruser
Member: 31324
Ok, so I can try to do what gsmspace suggests, because the phone is always gone and the technical assistance says it's a "damaged software" problem and I have nothing to loose in trying to open it and resolder it
Is it so easy to remove metallic box?
I tried yesterday but it's very hard to remove. Is there a method or a particular tool for removing it?
Thank you guys for your support
Old 06-17-2003, 17:45   #15
chip_2000
chip_2000's Avatar
Member: 22400
contact me im help you!
Page generated in 0.11205 seconds with 6 queries
