Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 01-20-2010, 07:40   #1 (permalink)
::.::RAMJAN::.::'s Avatar
Member: 258172
Thanks Meter: 10,367
Nokia N900 Flash/Updating the firmware !!
Nokia N900 Flash/Updating the firmware, Not support any third party software!
1. Download and install Flasher (maemo_flasher-3.5_2.5.2.2.exe).
2. Download the firmware file and Save to 'c:\Program Files\maemo\flasher-3.5\'
3. Open the command prompt. Start + Run. Type cmd and press Enter.
4. Change directory to the flasher program.
cd "c:\Program Files\maemo\flasher-3.5"
5. Connect USB cable while pressing 'u' key (details on the wiki)
6. Run the command on windows is
flasher-3.5.exe -F RX-51_2009SE_1.2009.42-11_PR_COMBINED_MR0_ARM.bin -f -R
Orginal link
Here logs i have repiar done software problem
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\RAMJAN>cd "c:\Program Files\maemo\flasher-3.5"
C:\Program Files\maemo\flasher-3.5>flasher-3.5.exe -F RX-51_2009SE_1.2009.42-11_
flasher v2.5.2 (Sep 24 2009)
SW version in image: RX-51_2009SE_1.2009.42-11_PR_MR0
Image 'kernel', size 1700 kB
Version 2.6.28-20094102.3+0m5
Image 'rootfs', size 149376 kB
Version RX-51_2009SE_1.2009.42-11_PR_MR0
Image 'cmt-2nd', size 81408 bytes
Version 8.2.2009.34.3-2+0m5
Image 'cmt-algo', size 519808 bytes
Image 'cmt-mcusw', size 5786 kB
Image '2nd', size 14720 bytes
Valid for RX-51: 2217, 2218, 2219, 2220, 2120
Version 1.4.13+0m5
Image 'xloader', size 14848 bytes
Version 1.4.13+0m5
Image 'secondary', size 109440 bytes
Version 1.4.13+0m5
Valid for RX-51: 2101, 2102, 2103
Version 1.4.13+0m5
Version 1.4.13+0m5
Version 1.4.13+0m5
Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2
113, 2114, 2115, 2116, 2117, 2118, 2119
Version 1.4.13+0m5
Version 1.4.13+0m5
Version 1.4.13+0m5
Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2
210, 2211, 2212, 2213, 2214, 2215, 2216
Version 1.4.13+0m5
Version 1.4.13+0m5
Version 1.4.13+0m5
Suitable USB device not found, waiting.
USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0
105.
Found device RX-51, hardware revision 2101
NOLO version 1.4.13
Version of 'sw-release': RX-51_2009SE_1.2009.42-11.003_PR_003
Sending xloader image (14 kB)...
100% (14 of 0 kB, avg. 14 kB/s)
Sending secondary image (106 kB)...
100% (106 of 0 kB, avg. 106 kB/s)
Flashing bootloader... done.
Sending cmt-2nd image (79 kB)...
100% (79 of 0 kB, avg. 79 kB/s)
Sending cmt-algo image (507 kB)...
100% (507 of 0 kB, avg. 507 kB/s)
Sending cmt-mcusw image (5786 kB)...
100% (5786 of 0 kB, avg. 5786 kB/s)
Flashing cmt-mcusw... done.
Sending kernel image (1700 kB)...
100% (1700 of 0 kB, avg. 1700 kB/s)
Flashing kernel... done.
Sending and flashing rootfs image (149376 kB)...
100% (149376 of 0 kB, avg. 149376 kB/s)
Finishing flashing... done
CMT flashed successfully
Regards
::.::RAMJAN::.::
The Following 78 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 01-20-2010, 08:02   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
can flash dead phones?
Old 01-20-2010, 10:41   #3 (permalink)
MaHmUt1982's Avatar
Member: 152266
Thanks Meter: 329
Yes bro u can ...write flash with this procedr ...
wbr;
MAHMUT1982
Old 01-20-2010, 16:49   #4 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
tested on Win 7 perfectly
Old 01-20-2010, 20:46   #5 (permalink)
Member: 644684
Thanks Meter: 8
hi rajman after flash n900 with flasher maemo 3.5 restart while playing game.The way I Vergennes with several different i test.
But the problem restart the continued genial.
do you find a solution to this problem you restart ?
Old 01-21-2010, 08:03   #6 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
already have 2 topics about this
days ago
http://forum.gsmhosting.com/vbb/show...highlight=N900
what's new in this ?
The Following 8 Users Say Thank You to .:SUBRATA:. For This Useful Post:
Old 01-21-2010, 08:11   #7 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
Originally Posted by .:subrata:. View Post
need change the topic to-----
successfull flash n900
Old 01-21-2010, 08:34   #8 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
Regards
::.::RAMJAN::.::
wrong info, just see the pic below, can be flashed with Phoenix, even cracked.
The Following 13 Users Say Thank You to nasirahmed For This Useful Post:
Old 01-21-2010, 08:36   #9 (permalink)
Member: 319447
Thanks Meter: 4,949
ouch ! what a burn
Old 01-21-2010, 08:41   #10 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
Havnt seen Flashed Phone Mate, You just Loaded File.
Old 01-21-2010, 09:06   #11 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
So what you think, Phoenix has a model listed but unsupported ? Also loads firmware from product folder like others ?
Old 01-21-2010, 10:13   #12 (permalink)
Member: 377080
Thanks Meter: 7
If any body test this method, Please report it.
Thanks rajman
Old 01-26-2010, 14:49   #13 (permalink)
Member: 217318
Thanks Meter: 2
with me done
SW version in image: RX-51_2009SE_1.2009.42-11.003_PR_003
Image 'rootfs', size 149248 kB
Version RX-51_2009SE_1.2009.42-11.003_PR_003
Version 1.4.13+0m5
Version 1.4.13+0m5
Version 1.4.13+0m5
105.
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_2.2009.51-1.003_PR_003
Sending and flashing rootfs image (149248 kB)...
100% (149248 of 0 kB, avg. 149248 kB/s)
The Following 2 Users Say Thank You to ellio For This Useful Post:
Old 01-26-2010, 17:00   #14 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
lol what a n00bz0r reply ...
like we're talking about some box in development ...
all the products that phoenix show ... ALWAYS can be flashed,
dead usb ... normal mode .. whatever ...
it's phucking ORIGINAL ... not some bad copy
b.r.
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 01-27-2010, 06:49   #15 (permalink)
trustunna's Avatar
Member: 63279
Thanks Meter: 8
Hello mates
Pls somebody should upload files; as the above link is not working for now.
Thanx
Nokia N900 Flash file needed ! zakiyyboss Infinity-Box 7 06-21-2011 14:48
nokia n900 flashing done with maemo_flashe ...:::JamalMustafa:::... Nokia Windows & MeaMo/MeeGo based 0 03-21-2010 17:01
Need nokia n900 flashing videos invisible990200 Nokia Windows & MeaMo/MeeGo based 1 02-20-2010 14:36
update the firmware of the ufs to version 2.0.8 or 208 without hwk? raoul plus Nokia Base Band 5 ( BB-5 ) 2 12-29-2008 20:45
LG3G cannot be flashed after updating the firmware preshaust FuriousGold 1 01-15-2008 09:59
Page generated in 0.26250 seconds with 11 queries
