![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2002
Member: 15162 Status: Offline Thanks: 5
Hi all
Can anyone help me i have 3 alcatel bf3 ,when connect charger it says :-charging not possible.I have flash it same problem .Is there any solution for it.Please let me know ASAP. Thanks in advance yash |
Any solution please???? ;(
seem that no one can help me _________
please at least reply and let me know . Cheers Djyash |
At last i find the solution for all the 3 phone. HEHEHEHEHE.
Cheers Djyash |
![]() ![]() ![]() ![]() Join Date: Jun 2002
Member: 13153 Status: Offline Thanks: 0
if the batery is empty and keeps blinking is software problem, you need to fix TEH checksum. If not, open the phone and change the little transistor on recharger plug input. If none works is the damn Power IC. Change it. If it is 15A or 255 you have to patch the firmware afterwards. Regards...............Wray |
![]() ![]() ![]() ![]() Join Date: Feb 2002
Member: 9736 Status: Offline Thanks: 0
Wray still the best Alcatel prof!
Regards, Migeni |
![]() ![]() ![]() ![]() ![]() Join Date: May 2003
Member: 28334 Status: Offline Thanks: 0
how can'i fix teh checksum wray!!!
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2003
Member: 25150 Status: Offline Thanks: 0
djyash,
pls how did you fix those problems, i have some my self, thnx, gibso. |
@Gilbso
I have solve the 3 phone by changing the battery .Buy original battery and your problem will be solve.If you want to be sure take the battery of the alcaltel which is saying charging impossible and insert it in a working phone ,you will see that it does the same problem (charging impossible). Hope this simple solution can solve your problem Cheers Djyash |
![]() ![]() Join Date: Apr 2003
Member: 26933 Status: Offline Thanks: 0
Was the same problem. I opened both battery and found that in nonoriginal was resistor at 10kOmh and in origina 100kOm, i changed it and now nonoriginal work very good!
![]() Join Date: Sep 2003
Member: 39575 Status: Offline Thanks: 0
@ djyash mail me on e-mail and i will tell you about.
docsasha@mail.ru
#12 | |
About what you will tell me.If you have anything please post it on the forum so as everyone can read it. Cheers Djyash |
Member: 14640 Status: Offline Thanks: 0
Check also charger voltage. New series have very bad manufacture.
As wray said problem in checksumm in new versions you must do it by your hand. Flash have 8 blocks with headers which consist of 16 bytes last 2 bytes is checksum. You must adding all bytes in block whithout ff bytes in end of block. This is problem but now no other reply to do this. Now I write program to new version but somebody do not want this.
