Old 07-27-2003, 18:54   #1
bluetoothmaster
Member: 35694
QuickHowto Widcomm 1.4.1.4
Here is an quick translation how to install widcomm 1.4.1.4
First download Acer 1.3.2.7 and Dell 1.4.1.4 Software.
ftp://ftp.support.acer-euro.com/netw...bt500_1327.exe
http://support.ap.dell.com/ap/en/fil...611&location=2
Extract all Files.
Copy license.dat from Acer into extracted Dell-Directory.
Begin install
After Install, software ask for license.dat or licensekey, cancel this step.
Don“t click bluetooth-icon!!
Now we need an Hexeditor.
Open btsec.dll (into c:\windows\system32) with hexeditor.
Patch this bytes:
Offset 0x43EE old Value: 75 4E new Value: 9090
Offset 0x4402 old Value: 75 3A new Value: 9090
Offset 0x4408 old Value: 74 39 new Value: 9090
Save btsec.dll and try it out.
If you can“t edit btsec.dll kill btstac~1.exe before in taskmanager
Old 07-28-2003, 00:30   #2
BesTCooL
BesTCooL's Avatar
Member: 18442
Sonork: 111110
good info
Thnks, I have CSR bluetoth (1.3.2.7), can ż use this driver ?
Old 07-28-2003, 08:09   #3
zfrank
Administrator
zfrank's Avatar
Member: 3
Sonork: 100.44530
Yes, you can this driver.
But no need.
The newest feature is support of human-devices. If you use bluetooth-mouse or bluetooth-keyboard you can do this with software and in the same time you can connect your phone with this drivers.
No second bluetooth-stick is needed.
Old 07-28-2003, 08:22   #4
zfrank
Administrator
zfrank's Avatar
Member: 3
Sonork: 100.44530
It“s you own risk to use the software. Be carefull with copyright...
Old 07-29-2003, 15:54   #5
naibani
Member: 28168
is there a software to activate bluetooth in 7650????
Anyone please help me with this.
Nads
naibani@rediffmail.com
Old 07-29-2003, 16:04   #6
ritz_
Member: 35885
i tried downloading the acer drivers but the download doesn't start even after a long wait. i have widcomm, tdk and msi 1.3.2.7 drivers, would it be ok if i used them instead. and would it work with a billionton adaptor?
coming to my main problem... i have a billionton bluetooth adaptor and i've accidentally broken th cd that came with it. i bought a T610 last week and i've still not been able to connect to my phone after trying everything i could and now i am at my wits end
i'd be very greatful if anyone could pls tell me how do i install my bluetooth adaptor! i've tried running widcomm, msi and tdk drivers but nothing works. i don't even get a bluetooth icon in my taskbar which by the way should not be because of the hardware because plugging in the hardware comes later on. pls someone help me out here.
thanx.
Old 07-29-2003, 22:10   #7
vve
Member: 10397
Surely yes. I've tried this trick with MSI's "license.dat": everything works just fine! A lot of thanks to bluetoothmaster !
Don't miss this thing: "Don“t click bluetooth-icon!!". Additional warning: Don't try to save Advanced Configuration settings before you patch the "btsec.dll" file!!!
This may help: Uninstall any existing BT soft from your system, then check your \Windows\System directory for any copies of "wbtapi.dll" and "widcommsdk.dll" files. If any (or both) of them is still there - remove it! After this - install a fresh version of soft as usual.
Old 07-29-2003, 22:25   #8
sagarka
Member: 26606
can we use this software with n e bluetooth device
Old 07-29-2003, 23:55   #9
BesTCooL
BesTCooL's Avatar
Member: 18442
Sonork: 111110
I install this driver (I patched dll file) bu phone sending and file to computer but computer not see phone.
I try all way but same problem
Phone to computer OK
Computer to phone DONT WORKŻNG
Why?
2nd question. How bluetooth settings for PC suite or OPM (Oxygen Phone Manager) use?
Can I add Local or Client services which?
Old 07-30-2003, 17:53   #10
ritz_
Member: 35885
thanx for helping out guys... i really appreciate it.
i've come half way through but in dire need of your help again. i know its a pretty long post but pls go thru it and see if u can help me out. here's the story so far:
1) downloaded latest "dell 1.4" drivers and already had widomm
1.3.2.7 drivers.
2) copied license.dat from extracted widcomm directory to dell
directory.
3) after installation i was never asked for licence.dat or
licensekey.
4) edited btsec.dll as told with a hexeditor.
5) didn't click on the bluetooth icon.
and now my problem:
i have the bluetooth icon in my taskbar and even after i plug in my bluetooth adaptor nothing happens. in advanced configuration it says "bluetooth device is not connected".
i got this msg while installing the software that a new hardware is found - "usb controller".
in device manager i now have a "universal serial bus(usb)controller" with a yellow question mark and a exclamation sign under "other devices", i.e. that the device isn't installed properly.
and under "universal serial bus(usb) controllers" in the device manager there is no mention of any bluetooth device.
i'm going insane trying to get my bluetooth to work... someone pls help me out here.
thanx a lot.
Old 07-30-2003, 21:22   #11
vve
Member: 10397
@ritz_
First of all - what model of device do you have?
All of Billionton devices I've ever encountered had original CSR's VID=0A12, i.e. they should be detcted by software (see btwusb.inf) as "CSR USB Bluetooth Device".
As a first step, try to install your device manually - update driver for your "universal serial bus(usb)controller" forcing windows to search new driver in \Program Files\xxxx\Bluetooth Software\bin directory.
If this don't help, find an entry for your device in registry (HKEY_LOCAL_MACHINE\Enum\USB\...) and post corresponding VID and PID here.
Old 07-30-2003, 21:43   #12
zfrank
Administrator
zfrank's Avatar
Member: 3
Sonork: 100.44530
I think if ritz_ update driver manually it“s working.
To find vid/pid there is also an good tool available.
Look on this site: http://www.hhdsoftware.com/usbmon.html
This is good, to find out many datas about usb-adapters.
Old 07-30-2003, 23:13   #13
vve
Member: 10397
Yes, HHD tools are good...but they all have one (sometimes fatal) disadvantage - they don't work under Win98 !
Old 07-31-2003, 06:58   #14
sophauer
Member: 36044
Dear All,
I found a website,and contained a 1.4.1.6 version software..
Good news is,it worked for any Bluetooth hardware for USB.
and the bad news is...
this website was built by Chinese
here is the Link:
http://www.goalray.com/phpBB2/viewtopic.php?t=279
Old 07-31-2003, 07:47   #15
zfrank
Administrator
zfrank's Avatar
Member: 3
Sonork: 100.44530
I know about 1.4.1.6, normally this version is from dlink and the same release as the 1.4.1.4 from dell.
I download it now and look if the software is patched or originally
More in 1-2 hours
Thx for this info
[IMG] code is Off
Page generated in 0.10852 seconds with 6 queries
