Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 12-11-2003, 23:51   #1 (permalink)
Member: 46164
Thanks Meter: 1
S/Me45i-v04: Flash Patches
One word from Rizapn:
"Hi All,
below is the modification that you can do with your S/ME45i_v04 full-flash to get "more" function/capability ..."
PRECAUTION :
1. Use it very carefull, it is only compatible with S/ME45 using S45iv04 firmware with CRC-Check disabled.
If you have 3618/6618i phone with c489 flash
you need address translation me45 -> 3618/6618i
(000000-1FFFFF) ->(000000-1FFFFF)
(200000-5FFFFF) ->(400000-7FFFFF)
for example:
07CC70 - 07CC70
55476B - 75476B
or you may use this (in Russian)
2. Check the original values before doing something or use
V-klay programm.
3.If yours are different then probably, we use a different firmware version, or you are on the wrong address. All addresses is based on its location in the full-flash file.
4. For fast modification, use partial flash, instead of full-flash. If the patching address is 0x183234 then you need to download your flash starting from address 0x180000 with size 0x10000.
Pictures for patches you can find here.
This is topic for patch only.
Use other topics for discussing..
Thread for discussing:
The Following User Says Thank You to patch_me For This Useful Post:
Old 12-12-2003, 02:24   #2 (permalink)
Member: 46164
Thanks Meter: 1
Now we have next patches
  • Increased FlexMemory to 393,51kb (by 13%)
  • Many Shortcuts patch
  • Speach Commando "Notes" -> "Dictating Machine" ,etc...
  • changes "Help" menu item into "SAT" menu item,etc...
  • Hide SIM Application Menu
  • Use Explorer without sim card:
  • Get AddressBook for phone without SIM card
  • Disable Aero Check
  • Disable "Do you want to copy all..." message at phone startup
  • delete RaceAce Splash Screen
  • Enabling "Band Selection" Menu (Until turn-off phone)
  • don't ask "yes/no" before activate handsfree-mode
  • activate handsfreemode before doing call by pressing left_down key v2
  • don't ask yes/no to toggle GPRS on/off
  • invert display
  • Show an icon "home/office/mobile" on incoming call with x-number of digits checked and Greek support.
  • Graphical Menu(Relocated)
  • Date Display Format : DD dd.mm in idle screen
  • HBP. Hourly_Beep
  • DIG. Digital_Clock_when_KeyLocked
  • ANIMATED OPERATOR LOGO AND DIGITAL CLOCK(Upd.v.0.4-Dec.17,2003)
  • Animated Operator Logo (always on screen)
  • profil logo: provider name -> profil name
  • CLC. Just_Another_Contrast_and_Light_Control
  • DKM. Disable_Keylocked_Message
  • KTM. Keylocked_auto_TimeOut_Modification
  • Do not allow to enter "112" in keypad locked mode.
  • AAA.Assign Any ringtone to Any number.(Upd.-Dec.18,2003)
  • BEW. Modify Battery Empty Warning Sound
  • ISK. Invert Softkey Display
  • NAM. Add New "Application" Menu
  • FLS. Flash SMS Directly from the Phone (vs Unicode Upd.-v3.1)
  • RKL. RED Longpressed Key Light
  • BLANK. Blank Screen when Keylocked
  • CLST. Call List via GREEN button (SME45)
  • MSC. More Shortcut (Upd.v.2.0-Dec.19,2003)
  • VIS. Vibra Toggle Shortcut (Upd.-Dec.17,2003)
  • VIN. Vibra Indicator
  • JAF. Just Another Funny Display
  • GPT. Just Another GPRS Toggle
  • Improved Net Indicator
  • Change layout of keys in the calculator
  • Modify * + Right SoftKey from Profiles to Phonebook
  • Change Info T9 to Language Selector
  • beep every minute during the call
  • Key 1 from VoiceMessage to other shortcut
Old 12-12-2003, 02:35   #3 (permalink)
Member: 46164
Thanks Meter: 1
;Increased FlexMemory (393,51kb)
; (probably by Jaelenicu)
;You should backup your whole contents of Flexmem using one of those
;applications to backup directly. Or you can use Data Exchange (for
;Flexmem files) and VisSie / Mobile Navigator (for Addressbook) to
;backup indirectly.
;after format is still increased
02BBF6: 0002 8000
3A5526: 66 E6
3A5528: FF 0C
3A554E: D4E00A00 E6FE2003
3A5771: 2C 1C
3A5796: D4C00200 E6FC2003
3A58D9: 2060 005A
Old 12-12-2003, 14:53   #4 (permalink)
Member: 46164
Thanks Meter: 1
Shortcuts patch
;Modify 0 [UpperRight] from "Select Line" to another shortcut
;Firmware : SME45iv04
;Author : RizaPN,Siudyk
;calculator
5644E2: 4840 CC00
564508: A802 EC01
564835: 87CE53 F64C5E
56483A: 2D 0D
;New Email
;5644E2: 4840 E014
;564508: A802 9700
;564835: 87CE53 E92496
;56483A: 2D 0D
;"New SMS"
;5644E2: 4840 CC00
;564508: A802 0002
;564834: DA87CE53 DAE96694
;56483A: 2D 0D
;Developer menu
;564508: A802 4201
;564835: 87CE53 F5B29F
;"Keypad locked"
;5644E2: 4840 CC00
;564508: A802 EE01
;564834: DA87CE53 DAC4ECFD
;56483A: 2D 0D
;"Illumination"
;5644E2: 4840 CC00
;564508: A802 4A07
;564834: DA87CE53 DAF50AE3
;56483A: 2D 0D
;Modify #[UpperRight] from "View CB" to another shortcut :
;Author : RizaPN
;Using this patch, we still have the ability to view
;the flash message by pressing # button when it is displayed.
;Currency
5645E8: AA02 2A02
5648A9: F17684 F6445E
;Explorer
5645E8: AA02 B208
5648A9: F17684 F53CE4
;Use * 0 # followed by [GREEN] as another shortcuts :
;Author : RizaPN
; * [GREEN] for "Inbox",
; 0 [GREEN] for "Write SMS",
; # [GREEN] for "Outbox".
55DB62: E6FC5B24E6FD5B00 D7405B00F3FC5BE4
55DB71: 16 07
56444C: F0ED70EC2D0BDC4D E01427FC23003D03
564454: A92C47F230002D06 DAF5C2E30D0929C7
56445C: 47F22A002D0347F2 3D03DAF5BAE30D04
564464: 23003D02E004DB00 29C63D03DAF5EAE2
56446C: E014 E004
Use RIGHT Arrow key as a "Favourite" shortcut :
;Author : RizaPN
;!DONT USE WITH Graphical Menu
5607E6: FA08 1209
56090E: F0C4DAF91629EA00620D EA005C0DDAF5CAE30D03
;Use Upper Left Side as an "Illumination" shortcut :
;Author : RizaPN
56095D: FD66D6 F50AE3
560960: 4840EA20660DE01CDAFC E6FC6C00DACCF8FF0DF7
;*** Shortcuts on left key ***
;Firmware : S/ME45i-v04
;Author : ACiD [mrp]
;homepage: www.gsm-dev.com
;please select one item
;560932: DAF55846 DAF68E25 ;Tastensperre Einschaltbox
;560932: DAF55846 DAF30CB9 ;Race Ace
;560932: DAF55846 DAF288FF ;Balloon Shooter
;560932: DAF55846 DAF34CE9 ;Stack Attack
;560932: DAF55846 DAE96694 ;new SMS
;560932: DAF55846 DAE92496 ;new eMail
;560932: DAF55846 DAE9F697 ;SMS inbox
;560932: DAF55846 DAE9CE99 ;SMS outbox
;560932: DAF55846 DAF6145E ;adress book
;560932: DAF55846 DAF6205E ;telefon book
;560932: DAF55846 DAF6445E ;money calcultor
;560932: DAF55846 DAF64C5E ;calculator
;560932: DAF55846 DAF0CCD8 ;dictating machine
;560932: DAF55846 DAF55846 ;GPRS Info
;560932: DAF55846 DAF6285E ;organizer
;560932: DAF55846 DAF6305E ;clock
;560932: DAF55846 DAF6385E ;visiting card
;560932: DAF55846 DAF6505E ;voice control
;560932: DAF55846 DAF62660 ;SAT
;560932: DAF55846 DAF62E60 ;surf & fun
;560932: DAF55846 DAF63660 ;favorits
;560932: DAF55846 DAF63E60 ;help
;560932: DAF55846 DAF64660 ;messages
;560932: DAF55846 DAF66260 ;office
;560932: DAF55846 DAF66A60 ;profile
;560932: DAF55846 DAF67A60 ;divert
;*** More Shortcuts for Left_Side down_key & up_key ***
5607FE: 48C6EA20 DAFDB0FF
560802: 3A09 CC00
5DFFB0: FFFFFFFF 46FC2200 ;Cursor hoch
5DFFB4: FFFFFFFF EA20C8FF
5DFFB8: FFFF 48C6
5DFFBA: FFFFFFFF EA20CEFF
5DFFBE: FFFFFFFF 46FC0D00 ;linke Seitentaste nach unten
5DFFC2: FFFFFFFF EA20D4FF
5DFFC6: FFFF DB00
5DFFCC: FFFF DB00
5DFFCE: FFFFFFFF FAF63A09
5DFFD2: FFFF DB00
5DFFD8: FFFF DB00
5DFFC8: FFFFFFFF FAF6205E ;up key (telefon book)
5DFFD4: FFFFFFFF FAC4ECFD ;left side down key (keylock)
;copy one of this values to 5DFFC8 (up key) or 5DFFD4 (left side down key)
;CC00CC00 ;nothing
;FAC4ECFD ;keylock
;FAF30CB9 ;Race Ace
;FAF288FF ;Balloon Shooter
;FAF34CE9 ;Stack Attack
;FAE96694 ;new SMS
;FAE92496 ;new eMail
;FAE9F697 ;SMS inbox
;FAE9CE99 ;SMS outbox
;FAF6145E ;adress book
;FAF6205E ;telefon book
;FAF6445E ;money calcultor
;FAF64C5E ;calculator
;FAF0CCD8 ;dictating machine
;FAF55846 ;GPRS Info
;FAF6285E ;organizer
;FAF6305E ;clock
;FAF6385E ;visiting card
;FAF6505E ;voice control
;FAF62660 ;SAT
;FAF62E60 ;surf & fun
;FAF63660 ;favorits
;FAF63E60 ;help
;FAF64660 ;messages
;FAF66260 ;office
;FAF66A60 ;profile
;FAF67A60 ;divert
;FAF65260 ;calling lists
;FAF50AE3 ;toggle illumination
;*** calling lists on right key ***
;Homepage: www.gsm-dev.com
5607E4: EA20FA0848C3EA20 3D04DAF652600D01
;if you want to have another shortcut on right_key
;replace the DAF65260 with any other shortcut value
;listed in my "more shortcuts" patch.
;*** Shortcuts on right cursor key ***
5607E0: 46FC2300 FAFDCCFF
5DFFCC: FFFFFFFF 46FC2300
5DFFD0: FFFF 2D02
5DFFD2: FFFFFFFF FAF6E807
5DFFD6: FFFFFFFF DAF65260 ;<--right jump adress here
5DFFDA: FFFFFFFF FAF6620D
;*** incoming sms menu on left_down_key ***
560974: DC579886 DAE9CA94
560978: A896DACC FAF6660D
;*** Shortcut on GREEN key & Down Arrow key***
;Author : Siudyk
;Down Arrow Key
5607F4: 18 9A ; Calls dialled
;Green
560830: 9A 18 ; Adress or telefon book
;9A ; Calls dialled
;18 ; Adress or telefon book
;3A ; Sim location
;86 ; Voicedialling
;74 ; Voicedialling [longpress]
;5C ; Profiles
Old 12-12-2003, 14:57   #5 (permalink)
Member: 46164
Thanks Meter: 1
;*** Speach Commando "Notes" -> "Dictating Machine" ***
59D7C0: DAF6ACC1 DAF0CCD8
06793A: 7005 8F00
;***Speach Commando "Notes" -> "Keypad locked"***
;59D7C0: DAF6ACC1 DAC4ECFD
;06793A: 7005 EE01
;***Speach Commando "Notes" -> "Illumination"***
;59D7C0: DAF6ACC1 DAF50AE3
;06793A: 7005 6C00
Old 12-12-2003, 14:59   #6 (permalink)
Member: 46164
Thanks Meter: 1
;Use Explorer without sim card:
;Author : RizaPN
05A656: C504 5905
Old 12-12-2003, 18:01   #7 (permalink)
Member: 46164
Thanks Meter: 1
;Disable Aero Check
;Author : RizaPN
590EDC: 3D 0D
Old 12-12-2003, 18:02   #8 (permalink)
Member: 46164
Thanks Meter: 1
;*** Hide SIM Application Menu ***
;Author : RizaPN
05AA66: 5905 0502
05AA78: 5905 0502
05AB3E: 5905 0502
05AB50: 5905 0502
Old 12-12-2003, 18:03   #9 (permalink)
Member: 46164
Thanks Meter: 1
; *** Get AddressBook for phone without SIM card
;Modified : dspmobile
;Replaces GPRS menu entry which is useless without SIM card !
05A65C: A904D104 10000F00
05A692: E25CF6 145EF6
04A4CA: 5905 CC04 ; hide "Options" not needed without SIM...
04A4DC: 5905 CC04
04A4EE: CC04 5905 ; unhide "Send/Print ( via IrDA )
04A500: CC04 5905
04A512: 5905 CC04
Old 12-12-2003, 18:04   #10 (permalink)
Member: 46164
Thanks Meter: 1
;*** changes "Help" menu item into "SAT" menu item ***
;Firmware: S/ME45i-v04
5A9B4: 3E60F600 2660F600
5AB20: 06020502 B113B213
DAAE8: 00000F00000F00000F1FFFCF1F87CF1F03CF1E31 000F8F00104F00202F002FAF0028AF0028AF0028
DAAFC: CF1E79CF27F9CF1FF1CF1FE3CF1FC7CF1FCFCF1F AF002FAF00202F002FAF00222F00202F002AAF00
DAB10: CFCF1FFFCF1FCFCF27CFCF1FFFCF07E00F0FE00F 202F002AAF00202F00104F000F8F000F8F00104F
DAB24: 1EE00F3C7FCF3B604F3B604F3E604F3EE04F4CE0 00202F002FAF0028AF0028AF0028AF002FAF0020
DAB38: 4F3DE04F3FE04F3EE04F3CC04F3FA04F3F404F3E 2FF02FAFA8222FD4202FAC2AAFD4202FAC2AAFD4
DAB4C: 804F4D004F3A004F1C000F1C000F3C000F3FFFCF 202FAC104FFC0F8F000F8F00104F00202F002FAF
DAB60: 3C004F3C004F3C304F3C304F4C004F3C704F3C70 2028AF7028AFF828AF202FAF20202FF02FAFA822
DAB74: 4F3C304F3C304F3C304F3C784F3C784F48004F38 2FD4202FAC2AAFD4202FAC2AAFD4202FAC104FFC
DAB88: 004F60000F60000F60000F7FFFCF60004F60004F 0F8F000F8F00104F08202F0C2FAF3E28AF2C28AF
DAB9C: 60304F60304F58004F60704F60704F60304F6030 2828AF202FAF20202FF02FAFA8222FD4202FAC2A
DABB0: 4F60304F60784F60784F58004F60004F80000FC0 AFD4202FAC2AAFD4202FAC104FFC0F8F000F8F00
DABC4: 000FE0000FFFFFCFE0004FE0004FE0004FE1FE4F 104F00A02F00EFAF3FE8AF20E8AF20A8AF202FAF
DABD8: D9FE4FE0004FE0004FE1FE4FE0004FE0004FE000 20202FF02FAFA8222FD4202FAC2AAFD4202FAC2A
DABEC: 4FE0004FD8004FE0004F00000F80000FC0000FFF AFD4202FAC104FFC0F8F000F8F001FCF00BFEF00
DAC00: FFCFE0004FE0004FE0004FE1FE4FD8004FE0004F F06F3FF76F20F76F20B76F20306F203FEFF0306F
DAC14: E1FE4FE1FE4FE0004FE0004FE1FE4FE0004FD800 A83DEFD43FEFAC356FD43FEFAC356FD43FEFAC1F
DAC28: 4FE0004F00000F00000F00000FFFFFCFE0004FE0 CFFC0F8F000F8F001FCF00BFEF00F06F3FF76F20
DAC3C: 004FE0004FE1FE4FD8004FE0004FE1FE4FE0004F F76F20B76F20306F203FEFF0306FA83DEFD43FEF
DAC50: E0004FE1FE4FE1FE4FE0004FD8004FE1FE4F AC356FD43FEFAC356FD43FEFAC1FCFFC0F8F
Old 12-12-2003, 18:06   #11 (permalink)
Member: 46164
Thanks Meter: 1
;*** Enabling "Band Selection" Menu (Until turn-off phone)***
;Author : RizaPN
Under Menu - Setup - Network - Configuration ...
056FC6: 0502 FA01
Old 12-12-2003, 18:07   #12 (permalink)
Member: 46164
Thanks Meter: 1
;*** delete RaceAce Splash Screen ***
56A8D0: FAF3E6C2 FAF30CB9
Old 12-12-2003, 18:08   #13 (permalink)
Member: 46164
Thanks Meter: 1
;*** Disable "Do you want to copy all..." message at phone startup ***
note: this don't disable the selection of the standard phone book.
maybe i'm gonna do this next time.
593188: 3D 0D
Old 12-12-2003, 18:09   #14 (permalink)
Member: 46164
Thanks Meter: 1
;***Left_Side down button voice control "hold" -> "press"***
56082A: 7409 8609
Old 12-12-2003, 18:10   #15 (permalink)
Member: 46164
Thanks Meter: 1
;*** don't ask "yes/no" before activate handsfree-mode ***
55C83A: E01CE6FD DAC54400
55C83E: AB08E00E FAF54EC8
S/ME45i-v04: Flash Patching ... rizapn x4x, x5x Flashpatching 1282 07-05-2015 12:16
821sc flash patch cid3 dead after flash cetech Z3X-Team Products 26 07-17-2009 12:12
L760 flashing patched flash problem Steph NSPRO 4 12-05-2008 11:04
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Need flash patched with Spanish lang for Neptune ! Kilowat Mitsubishi 4 05-21-2002 07:24
Page generated in 0.27224 seconds with 10 queries
