Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Android Based Devices
BlackBerry Android Based Devices General Android phones discussion, firmwares, solution, root, help
Old 05-10-2017, 19:01   #1 (permalink)
Member: 2714785
Blackberry Priv Pattern Lock
Anyway to reset pattern lock for blackberry priv stv100-1?
Old 05-11-2017, 07:45   #2 (permalink)
Member: 2713606
Thanks Meter: 239
hi dear,without loss data?
Old 05-11-2017, 14:20   #3 (permalink)
Member: 2714785
i do not mind if data is lost...any solution?
Old 05-11-2017, 17:43   #4 (permalink)
Member: 2714785
no one able to help?
Old 05-11-2017, 18:58   #5 (permalink)
Member: 1890459
Sonork: 100.1627340
Thanks Meter: 149
How to Easily Master Format BLACKBERRY PRIV (STV100-1 / STV100-4) with Safety Hard Reset? : Hard Reset & Factory Default Community
JUST like other bb u can put 10 time wrong password and it will reset !
The Following User Says Thank You to abbasgh For This Useful Post:
Old 05-11-2017, 22:47   #6 (permalink)
Member: 2714785
i have tried putting 10 times ....no reset happening
Old 05-12-2017, 00:11   #7 (permalink)
Member: 1087347
Thanks Meter: 2
just reflash it with firmware. Go to fastboot: (VOL-) + PWR, connect cable and run flash all
u can use google to find links for firmware. just input "stv100-1 firmware" and see official bb website links.
The Following User Says Thank You to cdma-ru For This Useful Post:
Old 05-12-2017, 00:21   #8 (permalink)
Member: 1087347
Thanks Meter: 2
or see sticky thread. there are some links for firmware inside. But check your version first. There are at&t and international versions. Most probably u have at&t if it is stv100-1
Old 05-15-2017, 14:06   #9 (permalink)
Member: 2714785
thanks cdma-ru for your help
Old 05-16-2017, 17:53   #10 (permalink)
Member: 1612872
Sonork: 1613495
Thanks Meter: 178
I have a problem
I receive this message failled remote:failed to set wipe for all required fs and nu partition
the cellular does not accept the software
Old 10-17-2018, 08:20   #11 (permalink)
Member: 2614003
i tried to flash it its stv100-4 and now its showing green led blinking it dont want to on anymore anyone have solution for it?
Old 10-17-2018, 08:51   #12 (permalink)
Member: 2667139
use blackberry desktop software
Old 10-19-2018, 13:58   #13 (permalink)
Member: 2614003
it even doesnt want to connect
Old 10-19-2018, 14:13   #14 (permalink)
BCcommunication's Avatar
Member: 76456
Sonork: 100.1678368
Thanks Meter: 60
flash via fast flasher
Old 08-12-2020, 12:31   #15 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 247
Red face blackberry stv100-1
blackberry stv100-1 is having a password but tried even putting the wrong password more times no reset possible. any help?
Page generated in 0.17688 seconds with 8 queries
