06-26-2019, 11:41 | #1 (permalink) |
Junior Member Join Date: May 2019 Location: HongKong
Member: 2909862 Status: Offline Thanks Meter: 6 | Fix iPhone 7 home button not working Interduce three iPhone 7 home button replacement part for iPhone 7 home button not working repair. REWA Customized Charging Port Flex Cable Function: The lightning earphone is not available. We can’t here voice with the earphone plugged-in. The hand feel of the home button is not so comfortable as the original. No vibrate alert when returning to home. Touch ID function is not available. upgraded version of Customized Charging Port Flex Cable Restore return-to-home function Support PD fast charging Support different type of charger adapters from 0.5A-2.4A Be able to take screenshots on all iOS versions More comfortable touch feeling What Can HX 2nd iPhone Universal Home Button Do? 1. Pair Bluetooth directly 2. Restore return-to-home function 3. Take screenshot 4. Open Siri successfully 5. Reveal running apps Hot-selling 2nd Gen Universal Home Button It can solve iPhone 7- iPhone 8 plus home button not working issue. Which one will you choose for your repair? |
The Following 2 Users Say Thank You to Joyee Zhang For This Useful Post: |
08-01-2019, 20:09 | #3 (permalink) |
Junior Member Join Date: Apr 2019 Location: England
Member: 2903725 Status: Offline Thanks Meter: 0 | You can find the button at: https://www.elitecellparts.com/iphon...lex-black.html Hope it will help you. |
09-16-2019, 07:47 | #4 (permalink) |
Freak Poster Join Date: Aug 2018 Location: China
Member: 2861866 Status: Offline Thanks Meter: 71 | The iPhone 7 home button will only work with the original home button that it was shipped with; if it breaks and needs to be replaced, it means that the replaced home button would be a non-functional home button. No Touch ID and no return-to-home functionality. It can restore the return-to-home function of your home button through use customized charging port flex cable. |
05-16-2022, 07:43 | #5 (permalink) |
Junior Member Join Date: Oct 2006
Member: 379652 Status: Offline Thanks Meter: 0 | Any solution for Universal Home Button replaced still no function on iphone7. The home button brand is YF. Touch ID will will not work but need the return to home function only. |
08-23-2022, 05:13 | #6 (permalink) |
Junior Member Join Date: Oct 2020 Location: Sacramento, CA, USA
Member: 2971749 Status: Offline Thanks Meter: 1 | I've used the newer revision aftermarket home buttons found on Amazon with good results, it'll return the use of the home button function but nothing can bring back touch ID. Just make sure it's the newer revised ones, those are just a direct install |
10-13-2022, 11:51 | #7 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | does it works on ios15 devices? i use YT universal home button on a normal (original home button and fingerprint functioning normal) iPhone 7 iOS15, i just wanted to test that the fake universal home button is working. its not working on ios15, so i put back the original home button, it says my button is broken, and fingerprint is not available, now this is bad, how can i regain access to my original home button on iPhone 7, ios15? do i need to restore it using itunes? the universal home button i tested on ios13 and it works fine, only on ios14 & ios15 i tested not working |
