Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-22-2019, 11:04   #1 (permalink)
Member: 1514899
Thanks Meter: 49
Iphone 7 doesn't switch on and no power
Hello,
I have an iphone 7 here that was dropped, cracked screen but not bad, just a few cracks.
I try to fix it.
Phone doesn't switch, no power.
Changed the lcd, battery, usb flex, no sign of life.
When plug the usb and run 3utools phone can be switched to DFU mode.
When trying to restore it can't swich to recovery mode and fails at 11%.
Probe in hands and checking for short at c1823, but it is not shorted.
Just thinking if that could be the tristar failure, but phone is detected in DFU mode, so doubt it could be the reason.
I checked other capacitors in that place where the c1823 is on the right hand side and some of them are shorted.
Do You think that this still could be caused by sdram/cpu ?
I've seen some movies showing how to fix the sdram but it is really complex and beyond my skills.
I bought this phone for just over 54 quid hoping that it could be fixed.
Can someone help me with that?
Please
Old 02-19-2020, 08:48   #2 (permalink)
Member: 2730637
Thanks Meter: 101
The problem may be caused by a software crash or a complicated hardware issue. For hardware solution you can check this guide here.
Fix iPhone 7 Won’t Turn On – CPU Repair
Old 04-05-2020, 19:01   #3 (permalink)
Member: 2947355
Thanks Meter: 4
reheat cpu may be it will help you
Old 04-21-2020, 14:42   #4 (permalink)
Member: 2950243
Sonork: NA
Unlock your phone IMEI number.
Old 04-21-2020, 17:20   #5 (permalink)
Member: 2273262
Thanks Meter: 5
That’s the dumbest answer ever. Cpu has plenty underfill and rehot or reflow will end up in a shorted cpu, two or more balls will surely melt together.
The Following User Says Thank You to fozzo For This Useful Post:
Old 05-27-2020, 07:36   #6 (permalink)
Member: 1986680
Sonork: 7210
Thanks Meter: 21
Originally Posted by worldwideunlock View Post
Hello,
I try to fix it.
Please
hello
change tristar and check it will solve for sure
Old 06-04-2020, 12:13   #7 (permalink)
Member: 2910059
Check the voltage of Nand.
1.8v and 3.0v. good luck
Old 06-06-2020, 19:54   #8 (permalink)
Member: 2959127
Take off the board and reheat power IC
Page generated in 0.17287 seconds with 8 queries
