Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 7 / iPhone 7 Plus
Old 10-14-2021, 21:09   #1 (permalink)
Member: 1319762
Sonork: krisszmix
iPhone 7 no wifi after change WiFi ic
Hello Guys !
I had a problem with an iPhone 7. Had no WiFi and no Bluetooth (grey buttons). After i change the Wifi ic, the Bluetooth is coming back the life. But the wifi is no... (gray button) I change another ic, 2nd the 3nd, but nothing change... I used every times a new ic. I checked al ic pads with multimeter in diode mode, every pads resistance value is ok. Any useful idea ?
Old 10-15-2021, 06:07   #2 (permalink)
Member: 47236
Thanks Meter: 56
Originally Posted by krisszmix View Post
Hello Guys !
you have to unbind WIFI ic in nand via some tool like JC1000pro or other tool like this.
br
The Following 2 Users Say Thank You to vascof1 For This Useful Post:
Old 10-15-2021, 12:42   #3 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 204
needs software
Hello Guys !
if iphone 6/6+ its just plug and play but 6s and up you need to unbind id from nand..purple tools can do this also..they are cheaper than jc pro and you dont need to remove the nand..il recomend irepair box
The Following 2 Users Say Thank You to simpleprince49 For This Useful Post:
Old 10-15-2021, 20:42   #4 (permalink)
Member: 1319762
Sonork: krisszmix
Thank you for your answer !
I did not know about "unbind" from iphone 7 and newer necessary NAND programing.
I will read about from this. I do not nave any programmer to this, but i see that i need a good programmer for this, and any other works. I see the JC 1000pro, but see that is good up to iphone 7. If i buy any programmer, i want any higher, i would like that will be good to X/XS11, so i search any other and higher programmer. The JC1000pro is about 200$usd, i take more money and search any more modern programmer.
Thanks !
Old 10-15-2021, 20:43   #5 (permalink)
Member: 1319762
Sonork: krisszmix
jc1000pro
Thanks !
Old 10-15-2021, 20:54   #6 (permalink)
Member: 1319762
Sonork: krisszmix
I see the irepair box p10, yes it is cheaper than JC1000pro, but this untill ony iphone 8. If i buy, i want more better, untill X/XS/11, and i saw the P12 programmer, but it is too expensieve. So, i now see the programmers, i search the good buy...
The Following User Says Thank You to krisszmix For This Useful Post:
Old 12-22-2021, 11:25   #7 (permalink)
Crazy Poster
Member: 997558
Thanks Meter: 19
Find the DCSD cable, then on the MAC switch your iPhone 7 to Purple mode and unbind WiFi through the DCSD cable
Old 12-22-2021, 18:21   #8 (permalink)
Member: 975554
Thanks Meter: 204
its worth
yes but i where you il buy that p12 it supports both purple and nand removal..im having jc pro from iphon 4 to 11 pro max but its a deferend devices cost me lots of money to complete
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.14964 seconds with 7 queries
