Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #16 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Online Thanks Meter: 1,542 | i have try many times restore but not success when go restore phone automatic disconnect |
The Following User Says Thank You to kothamamun For This Useful Post: |
![]() | #17 (permalink) |
Junior Member ![]() Join Date: Sep 2018
Member: 2865098 Status: Offline Thanks Meter: 2 | I once had the same problem, my iPhone 5s stuck on white Apple logo unexpectedly. I know that I can use iTunes to restore the device, but the thing is I've got an amount of data on it that has never backed up before. My friend recommended me trying TunesKit iOS System Recovery and she said it will not cause the data loss. I tried and it just worked. Great iOS repair tool. Recommend. |
The Following User Says Thank You to Wlee2060 For This Useful Post: |
![]() | #19 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jan 2018
Member: 2797527 Status: Offline Thanks Meter: 4 | Your mentioned problem is actually common to happen and I have exactly experienced it last month. Do you mind data loss? If yes, you'd better fix the software crash using an iOS system recovery, which has ability to keep our data intact after the repair. If you don't mind, iTunes is also a good option to try! |
![]() | #25 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: Jul 2020 Location: China Age: 23
Member: 2964041 Status: Offline Thanks Meter: 2 | To fix iPhone 7 stuck on boot loop and apple logo, you can first try to force restart your iPhone. If the problem still exists, please applying a professional ios recovery tool to completely fix it without data loss. Of course, you could try to restore your iPhone via iTunes, but first you had better back data up before as it will delete them all. |
![]() | #26 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | i have strenge type of problem, with boot loop issue when i remove front camera flex mobile work ok,but if install front camera flex its come to boot loop. i check velue on whole connectors all pins velue are ok, now i am confused what to do next, so all my brothers pls guide me how to solw this problem permenantly |
![]() | #27 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: Chennai
Member: 1490564 Status: Offline Sonork: 100.1671685 Thanks Meter: 182 | Quote:
I have exact same problem in my iphone 7 any solution ? | |
![]() | #28 (permalink) |
Banned Join Date: Jan 2022 Location: Los Angeles Age: 26
Member: 3004691 Status: Offline Thanks Meter: 2 | You can put your phone in Recovery mode and fix it with iTunes. But if you're not able to enter that mode, TunesKit iOS System Recovery will be a good choice to fix with one click entering the Recovery mode. |
