02-19-2021, 11:04 | #1 (permalink) |
Product Manager Join Date: Jan 2020 Location: Balkan
Member: 2942751 Status: Offline Thanks Meter: 305 | Mina Patch 3.0 Free for all But If you need fmi off After patch only minas soft can make fmi off If pass is changed its autoreject from server If need only for pass bypass then you can have it free now check picture for more detials https://prnt.sc/100oqnk |
The Following User Says Thank You to I_Bo For This Useful Post: |
07-16-2021, 21:45 | #5 (permalink) | |
Freak Poster Join Date: Oct 2014
Member: 2277735 Status: Offline Thanks Meter: 215 | Quote:
It’s possible, with old versions.. If you JB in diagnosis mode you can get token etc then! minaUSB.pkg | |
07-16-2021, 21:49 | #6 (permalink) | |
Use the original versions, don’t may Mina anything, will be a waist of money once he decides he wants to burn the exploit. minaUSB.pkg Last edited by P3T3; 07-16-2021 at 21:59. | |
07-16-2021, 22:01 | #8 (permalink) |
Member: 2277735 Status: Offline Thanks Meter: 215 | Error 20 on a11? It’s possible, with old versions.. If you JB in diagnosis mode you can get token etc then! minaUSB.pkg |
08-03-2021, 22:59 | #12 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | thank you for the link, but I have this error when putting phone in DFU mode using Mina loader, and the iphone doesn't power on when I push volume butons to go to diagnostic mode (it's iPhone 7 iOS 13.3) any idea to solve it ? Last edited by equinoks; 08-03-2021 at 23:07. |
08-05-2021, 12:07 | #13 (permalink) |
Member: 2277735 Status: Offline Thanks Meter: 215 | Don’t use Mina loader, you JB as normal but then hold vol up button to get in to diagnostic mode. Then run patcher, Run jb when in diagnostic mode and should JB without error 20. |
The Following User Says Thank You to P3T3 For This Useful Post: |
08-08-2021, 11:09 | #15 (permalink) |
Member: 21508 Status: Offline Thanks Meter: 186 | I have been able to patch iOS 13.x before using mina usb patcher 1.1, but after installing mina usb 3.0, now I always have "Failed to patch this device", with all min usb patcher versions.. anything to do to solve this please? |
