Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 04-15-2021, 08:40   #1 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 123
Unhappy Ane-lx2 stuck on logo
DC Phoenix 0.0.0.132
user:013257DB
Standard update
Not Reboot NOT cheked
Update Verlist to server on file load NOT checked
Try Rescue Recovery checked
Bypass version check NOT checked
Old slow algo checked
Looking for a device in force upgrade mode
Device detected:
COM46: HUAWEI USB COM 1.0 (COM46)
4/15/2021 12:31:59 PM Starting to write device in FASTBOOT mode...
File to update: D:\Firmwares\Huawei\ANE-LX2_9.1.0.201(ZAFC185E4R1P8T8)_Firmware_9.0.0_r3_E MUI9.1.0_05015AJT File By (Support.HalabTech.Com)\BD\ANE-BD_1.0.0.39_Board_Software_Android_8.0_EMUI_8.0_05 022JKP.dgtks
Device detected:
Process identifier:31056237
Writing bootloader...
Step 1...
Step 2...
Waiting for device REMOVAL/INSERTION...
USB Device REMOVAL
Type: @oem146.inf,%qcomdevice00%;HUAWEI USB COM 1.0
VidPid: VID_12D1&PID_3609
Instance id: 6&1ab5e341&0&6
USB Device INSERTION
Type: @oem141.inf,%hwfastboot%;Android Sooner Single ADB Interface
VidPid: VID_18D1&PID_D00D
Waiting for fastboot device...
Device found: 0123456789ABCDEF
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
Build number: :ANE-LX2 9.1.0.353(ZAFC185E4R1P8)
Model: ANE-LX2
Vendor/Country: hw/meafnaf
Battery state: 0
OEM lock state info:
FB LockState: UNLOCKED
USER LockState: LOCKED
OEM get bootinfo:
unlocked
Erasing ver .. .
Erasing nvme partition
Partition nvme erased
Erasing cust partition
Waiting for answer...
ERASE partition cust : FAIL failed to erase partition
Erasing product partition
ERASE partition product : FAIL failed to erase partition
Erasing version partition
ERASE partition version : FAIL failed to erase partition
Erasing misc partition
ERASE partition misc : FAIL failed to erase partition
Erasing userdata partition
ERASE partition userdata : FAIL failed to erase partition
Writing xloader partition
XLOADER partition update :FAIL flash write prim vrl failure
Writing ptable partition
PTABLE partition update ...OK
Writing fastboot partition
FASTBOOT partition update :FAIL flash write prim vrl failure
Writing dts partition
DTS partition update :FAIL flash write prim vrl failure
Writing fw_lpm3 partition
FW_LPM3 partition update :FAIL flash write prim vrl failure
Writing sensorhub partition
SENSORHUB partition update :FAIL flash write prim vrl failure
Writing fw_hifi partition
FW_HIFI partition update :FAIL flash write prim vrl failure
Writing teeos partition
TEEOS partition update :FAIL flash write prim vrl failure
Writing recovery_vbmeta partition
RECOVERY_VBMETA partition update :FAIL flash write prim vrl failure
Erasing cache partition
ERASE partition cache : FAIL failed to erase partition
Writing cache partition
CACHE partition update :FAIL failed to erase partition when sparse img flash
Writing nvme partition
NVME partition update :FAIL flash write failure
Writing trustfirmware partition
TRUSTFIRMWARE partition update :FAIL flash write prim vrl failure
Writing modem_fw partition
MODEM_FW partition update :FAIL flash write prim vrl failure
Writing modemnvm_update partition
MODEMNVM_UPDATE partition update :FAIL flash write failure
Writing modem_om partition
MODEM_OM partition update :FAIL failed to erase partition when sparse img flash
Writing modemnvm_img partition
MODEMNVM_IMG partition update :FAIL failed to erase partition when sparse img flash
Writing userdata partition
USERDATA partition update :FAIL failed to erase partition when sparse img flash
Writing system partition
sending sparse file 413714128 bytes
send sparse file ERROR
SYSTEM partition update :FAIL failed to erase partition when sparse img flash
Writing vendor partition
sending sparse file 459899448 bytes
VENDOR partition update :FAIL failed to erase partition when sparse img flash
Writing product partition
PRODUCT partition update :FAIL failed to erase partition when sparse img flash
Writing version partition
VERSION partition update :FAIL failed to erase partition when sparse img flash
Writing splash2 partition
SPLASH2 partition update :FAIL failed to erase partition when sparse img flash
Writing frp partition
FRP partition update :FAIL flash write failure
Writing secure_storage partition
SECURE_STORAGE partition update :FAIL failed to erase partition when sparse img flash
Writing modem_secure partition
MODEM_SECURE partition update :FAIL failed to erase partition when sparse img flash
Writing kernel partition
KERNEL partition update :FAIL flash write prim vrl failure
Writing ramdisk partition
RAMDISK partition update :FAIL flash write failure
Writing recovery_ramdisk partition
RECOVERY_RAMDISK partition update :FAIL flash write failure
Writing recovery_vendor partition
RECOVERY_VENDOR partition update :FAIL flash write failure
Writing vbmeta partition
Writing odm partition
ODM partition update :FAIL failed to erase partition when sparse img flash
Software written
4/15/2021 12:38:12 PM Writing device finished - INCOMPLETE
am try to flash BD firmware but not write...how can solve this problem..phone stuck on logo
Old 04-15-2021, 16:49   #2 (permalink)
Member: 2023196
Thanks Meter: 1,703
You should use temp bootloader unlock from tp tab, and then flash full stock rom.
Old 04-16-2021, 07:20   #3 (permalink)
AhsanNawaz's Avatar
Member: 2081860
Sonork: 100.1608350
Thanks Meter: 123
Standard update
Not Reboot NOT checked
Enable testpoint NOT checked
Disable testpoint NOT checked
Old slow algo NOT checked
Detecting recovery partition
File size: 5,482,687,612 bytes
Current version(CURVER): ANE_GLOBAL_CUST 9.1.0(C185)
ERECOVERY_KERNEL partition found
ERECOVERY_RAMDISK partition found
ERECOVERY_VENDOR partition found
4/16/2021 11:19:37 AM Starting to try Rescue Recovery...
Getting IMEI...
Getting model ...
Model: ANE-LX2
Battery state: 0
OEM get bootinfo:
unlocked
Process identifier:31068974
Erasing ver .. .
Writing rescue_recovery_kernel partition
RESCUE_RECOVERY_KERNEL partition update :FAIL image verification error
Update recovery parttion FAIL
Cannot enter in Recovery mode
Old 04-16-2021, 13:23   #4 (permalink)
Member: 2023196
Thanks Meter: 1,703
I strongly advice you to update dc-phoenix to latest version if you haven't yet and connect battery or replace with new one, as this won't work with no battery or if it's drained.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.23463 seconds with 7 queries
