Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 11-09-2018, 10:44   #1 (permalink)
Member: 2669781
Thanks Meter: 1,839
B310s-927_{Network Lock}_Successfully Removed ...
Full logs of the operation/
DC - Unlocker 2 Client 1.00.1403
Detecting modem :
selection :
manufacturer - Huawei modems
model - Auto detect (recommended)
Found Applications port COM487
Found modem         : B310s-927
Model               : Huawei B310
IMEI                : 869341022633216
Serial NR.          : F5S8W16302016673
Firmware            : 21.300.01.00.00
Compile date / time : Feb  6 2015 23:44:35
Hardware ver.       : WL1B310TM
Dashboard version   : 00.00.00.000.00
Web UI version      : WEBUI_17.100.09.00.03_CPE
SIM Lock status     : unlocked
Wrong codes entered : 0 (unlock attempts left : 10)
Enabling all bands ... OK !
The Following User Says Thank You to lyes_albert For This Useful Post:
Old 11-09-2018, 18:39   #2 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
Long story short please, all the steps, how did you soldered wires, downgraded software and so on.
BR,
Old 11-09-2018, 21:27   #3 (permalink)
Member: 2669781
Thanks Meter: 1,839
BR,
Hi sir,
Pinouts and Wire soldering stuff is not that hard to achieve. Make sure you’re using an original cable to avoid, unknown device errors.
Short the two points as shown in the pic below, When all that is done, plug your USB, followed by plugging the routers charger, the computer will recognize it and begins installing the necessary drivers.
Old 11-09-2018, 21:45   #4 (permalink)
Member: 2669781
Thanks Meter: 1,839
Flashing and downgrading steps:
After the computer has finished installing the drivers, you should get a comport like: «*«HUAWEI Mobile Connect - 3G PC UI Interface*». This is the bootmode.
In that case, if the firmware version is higher, you should use HIsilicon DC flasher, to write the firmware (21.300.01.00.00) both available at support area.
When all that is done, download the following script which would reboot your router to download mode, Where more drivers, including the modem one, will pop up.
Open Dc client, click scan, it should then read the basic info of your device. Hit network unlock. I hope I was clear, if you still have any ambiguities, don’t hesitate to ask .
https://mega.nz/#!ywxlGaSQ!Ui5a2BLIK...raDETUa77PXkUY
Old 11-09-2018, 21:51   #5 (permalink)
Member: 2669781
Thanks Meter: 1,839
Describing how the script functions:
Download the file attached above, extract it. You find an app. Click and open the content.
Inside, hold Shift button on your keyboard, and click the right button with your mouse, then click open a new command.
Copy the command inside the text file which is: balang_usbdload -p42 usbloader-b310.bin then paste it in the Cmd window, leave it as it is, except change the port number to correspond with the port of your router on boot mode, open device manager you can see it.
Best of lucks.....
Old 05-09-2022, 11:48   #6 (permalink)
Member: 1545613
Sonork: 0022508578916
Hello sir there is another way to unlock my B310s -927 modem ?
Old 05-09-2022, 15:27   #7 (permalink)
Member: 2023196
Thanks Meter: 1,891
Successful unlock for it posted by the user above.
Page generated in 0.16844 seconds with 8 queries
