Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 12-19-2021, 21:43   #1 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
Hcu client is not installed on my windows 10 showing dll error
Old 12-20-2021, 09:02   #2 (permalink)
Member: 2023196
Thanks Meter: 1,891
vcredist_x86 2008 windows update: https://www.microsoft.com/en-us/down....aspx?id=26368 install this windows update and try again.
Old 12-20-2021, 11:36   #3 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
Please check the attachment for error when installing hcu software on my window 10
Thanks any Please check the attachment for error when installing hcu software on my window 10
File Type: jpg 16399962647203758035437535903503.jpg (157 Bytes, 79 views)
Old 12-20-2021, 14:53   #4 (permalink)
Member: 2023196
Thanks Meter: 1,891
Can't see anything attached.
Old 12-20-2021, 19:10   #5 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
File Type: jpg IMG_20211220_113028.jpg (157 Bytes, 76 views)
Old 12-21-2021, 09:52   #6 (permalink)
Member: 2023196
Thanks Meter: 1,891
Same, nothing visible in your attachments, maybe possible to send a link to the picture/screenshot if you upload it somewhere?
Old 12-30-2021, 13:31   #7 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
The procedure entry point META_MISC_GetMEIValue_ could not be located in the dynamic link library meta_dll.dll.. this is error am gotten on window 10 64bit
Old 01-01-2022, 07:27   #8 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
Please kindly check the above details
Old 01-03-2022, 14:08   #9 (permalink)
Member: 2023196
Thanks Meter: 1,891
Please check provided solution above. You must install certain windows update pack.
Old 01-04-2022, 11:26   #10 (permalink)
bast3800's Avatar
Member: 731596
Thanks Meter: 164
Search and install BlackBerry Desktop Software for Windows7.1.0-B42
Old 01-04-2022, 15:49   #11 (permalink)
Member: 2023196
Thanks Meter: 1,891
No, vcredist_x86 2008 windows update: https://www.microsoft.com/en-us/down....aspx?id=26368 install this windows update and try again.
Old 01-07-2022, 07:40   #12 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
Instal already still same problem
Old 01-07-2022, 09:02   #13 (permalink)
Member: 2023196
Thanks Meter: 1,891
Means you have installed x64 version and not the x84 which I told to. This helps 100% of people with this problem so it will for you as well once you do it correctly.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 01-08-2022, 09:41   #14 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
thank you very much sir is work for me now
Old 01-08-2022, 09:41   #15 (permalink)
Member: 1909105
Sonork: simple453
Thanks Meter: 2
Page generated in 0.19607 seconds with 9 queries
