Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 02-04-2021, 10:07   #1 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
Dc phoenix error please help
https://imgur.com/zHqMOZFDC PHOENIX ERROR PLEASE HELP HOW TO SOLVE THIS
dc phoenix error runtime 217 at 00478509
THANKS IN ADVANCE
BR:Shazz
Old 02-05-2021, 09:34   #2 (permalink)
Member: 2023196
Thanks Meter: 1,891
Looks like dll files are missing. They must be in same folder where dc-phoenix exe.
If not there, try to redownload dc-phoenix.
Old 02-06-2021, 14:43   #3 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
i have redownload but same error sir
Old 02-08-2021, 14:41   #4 (permalink)
Member: 2023196
Thanks Meter: 1,891
Add screenshot of dc-phoenix directoy with files there visible.
Old 12-02-2021, 16:12   #5 (permalink)
Member: 2012088
Thanks Meter: 8
Same error, help!!!!
Old 12-02-2021, 16:17   #6 (permalink)
Member: 2023196
Thanks Meter: 1,891
Make sure the directory of DC-phoenix has only Latin letters/numbers. Also, try to launch it as administrator by Right click on DC-phoenix.exe -> run as administrator.
Write here your windows version if the problem remains.
Old 12-02-2021, 16:34   #7 (permalink)
Member: 2012088
Thanks Meter: 8
Thanks for quick answer!
Path is "F:\!SOFT_4_PHONES\HCU\DCPhoenix_v164". Run as admin didnt help. Win10 pro 20H2 64bit
Old 12-02-2021, 16:50   #8 (permalink)
Member: 2023196
Thanks Meter: 1,891
I've sent you a PM with a link to beta DC-phoenix, please check if the problem remains on it. If it does, make a screenshot and send it to us, with your user name/dongle id, thank you.
Old 03-13-2023, 21:32   #9 (permalink)
Member: 15521
Thanks Meter: 57
I have the same error anyone have solution for this runtime error 217?
Old 03-14-2023, 09:50   #10 (permalink)
Member: 2023196
Thanks Meter: 1,891
Could you make a screenshot of dc-phoenix folder contents as well as path in which it is placed, please?
Old 03-14-2023, 10:20   #11 (permalink)
Member: 15521
Thanks Meter: 57
I try use SFC and DISM and all is ok with windows files. Reinstal all visual c++redistributable. Disable Nod32 and firewall and all not help to solve this. DC Phoenix always give error with or without dongle and not run. dc-unlocker2client and HCU open and work good only problem with DC Phoenix.
Old 03-15-2023, 10:10   #12 (permalink)
Member: 2023196
Thanks Meter: 1,891
It is indeed linked to missing/corrupted visual c++ redistributable packages. More details on this error and possible solutions here: https://www.makeuseof.com/fix-runtim...20dialog%20box.
Old 03-16-2023, 19:16   #13 (permalink)
Member: 15521
Thanks Meter: 57
I try this but not solve problem. I try uninstall ativirus and disable firewall. Reinstall all visual c++ redistributable all new releases and all old releases. Fix windows files by SFC and DISM. Disable all programs from windows start and all loaded from msconfig. All this steps not solve problem. I found some solution. I create new Windows User with Admin rights. After login to new user DC Phoenix software start in the same Windows 10 system. After I disable admin reights for new user and try run DC phoenix software and enter my primary admin account password get the same rutime error 217. Anyone known how solve this for my primary Windows user? Where else can I look for the cause of this problem? I will be grateful for any suggestions.
Old 03-17-2023, 12:11   #14 (permalink)
Member: 2023196
Thanks Meter: 1,891
Launching software as administrator from the right-click menu gives the same error?
Old 03-18-2023, 10:46   #15 (permalink)
Member: 15521
Thanks Meter: 57
Yes, launching software as administrator from the right-click menu gives the same error. When I create standart new windows user withowut admin rights. Logout from my primary account and login to my new account and try right-click menu and run as admin the same error. But when I create new admin user an try open software normal without right-click software normal run without error.
Page generated in 0.21951 seconds with 10 queries
