Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #48 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2013
Member: 2023196 Status: Offline Thanks Meter: 1,646 | You need to enter menu with vol+ and power button, select wipe data/factory reset, after this select option "safe mode" from same menu. Phone will boot into home screen, can check if everything you want, restart phone for it to be unlocked and boot into normal mode. |
![]() | #50 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2014 Location: Algeria
Member: 2287326 Status: Offline Thanks Meter: 39 | The "VERLIST" part got me confused! Can anybody make it clearer please? I'd kindly appreciate if you explain the function & the content of the VERLIST partition as well. |
![]() | #51 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,646 | No You do not quite need to understand it, you just need to select original firmware files on dc-phoenix while upload option is checked. That is only if flashing ends with an error of Base Verlist part. |
The Following 2 Users Say Thank You to Namelocked For This Useful Post: |
![]() | #52 (permalink) |
Junior Member ![]() ![]() Join Date: Sep 2012 Location: TOGO(Lome)
Member: 1813429 Status: Offline Thanks Meter: 10 | iam came back with another problem. need to unbrand hornor 8x max(ARE-AL00C) from chinese rom to global it is possible with DC and HCU. but it is in support list |
![]() | #53 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,646 | It depends on android version and security patch running in it. But yes, if you repair model/vendor/country correctly and then flash suitable firmware files then unbranding should be possible. Always bare in mind risk that follows it. |
![]() | #54 (permalink) | |
Crazy Poster ![]() ![]() ![]() Join Date: Apr 2012 Location: Russia/Moscow
Member: 1748637 Status: Offline Thanks Meter: 4 | Quote:
![]() | #55 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 307 | |
The Following User Says Thank You to solgeo For This Useful Post: |
![]() | #57 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,646 | All latest software versions are always available on support area which is accessed from any software https://www.dc-unlocker.com/file-list Temp link: https://files.dc-unlocker.com/share....D05DE6586FB89C Last edited by Namelocked; 05-18-2020 at 12:51. |
The Following User Says Thank You to Namelocked For This Useful Post: |
![]() | #58 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 276432 Status: Offline Thanks Meter: 65 | stk-l21mdv Standard update Not Reboot NOT cheked Update Verlist to server on file load checked Try Rescue Recovery checked Bypass version check checked Old slow algo NOT checked Looking for a device in upgrade mode COM28: DBAdapter Reserved Interface (COM28) COM30: Android Adapter PCUI (COM30) 5/18/2020 4:06:48 PM Starting to write device in UPGRADE mode... User has selected to continue without CUST file Device found: 78KVB19B25000418 Old slow algo NOT selected 5/18/2020 4:06:53 PM start to write update file File to update: D:\john working\Y9s Bricked\STK-L21MDV 9.1.0.336(C185E3R2P1)_Firmware_EMUI9.1.0_05016JQJ File By (Support.**************)\Software\dload\update_sd_ base\UPDATE.APP File size: 3,913,283,008 bytes Current version(BASE_VER): STK-LGRP3-OVS 9.0.1.170 Process identifier:24525879 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 44: SHA256RSA...OK Writing file 2 of 44: CRC...OK Writing file 3 of 44: BASE_VERLIST... Error downloading file 3 of 44 Error writing software 5/18/2020 4:07:04 PM Writing device finished with ERROR |
![]() | #59 (permalink) | |
Member: 2023196 Status: Offline Thanks Meter: 1,646 | Quote:
![]() | #60 (permalink) |
Member: 276432 Status: Offline Thanks Meter: 65 | Already tried no sucess same error Can you post screen shots for steps may be i do something wrong by mistake because i tried all you told me but same error Sent from my INE-LX1r using Tapatalk |
