Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #92 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2004 Age: 47
Member: 65351 Status: Offline Thanks Meter: 16 | A question, I have been with this tool for a short time, is there any possibility of changing only the Vendor and the Country of the original OEMFILE of the phone, ? DC Phoenix works with the complete OEMINFO file and cannot modify the original? Thank you!! Last edited by Namelocked; 08-04-2020 at 13:19. Reason: Other |
![]() | #94 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: Sep 2012 Location: TOGO(Lome)
Member: 1813429 Status: Offline Thanks Meter: 11 | my test so exited bro. i fully tested this version of dc-phoenix and i confirm that downgrade work on all most hisillicon cpu. but pay attention some downgrade files will let you with bootloop or completly brick the phone to huawei 1.0. |
![]() | #95 (permalink) |
Member: 1813429 Status: Offline Thanks Meter: 11 | hi sir i have problem with EVA-L09 need help. here is log: DC Phoenix 0.0.0.132 user:abdoulgaf Standard update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery NOT checked Bypass version check NOT checked Old slow algo NOT checked Looking for a device in upgrade mode No devices detected in upgrade mode Device found: H3XDU17227001369 2020-08-10 09:26:54 Starting to write device in FASTBOOT mode... File size: 3*020*879*000 bytes Current version(CURVER): EVA_Global_5.0_oversea Looking for a device in fastboot mode Device found: H3XDU17227001369 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:H3XDU17227001369 IMEI:869827026285326 IMEI1:869827026285326 Build number: :HLEVAAL10M00A085 Model: HUAWEI Vendor/Country: hw/ru Battery state: 3935mv OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Process identifier:26605607 Erasing ver .. . Getting lock state info... Erasing ver .. . Writing XLOADER partition XLOADER partition update ...OK Writing FW_LPM3 partition FW_LPM3 partition update ...OK Writing FASTBOOT partition FASTBOOT partition update ...OK Writing MODEMNVM_UPDATE partition MODEMNVM_UPDATE partition update ...OK Writing TEEOS partition TEEOS partition update ...OK Writing TRUSTFIRMWARE partition TRUSTFIRMWARE partition update ...OK Writing SENSORHUB partition SENSORHUB partition update ...OK Writing FW_HIFI partition FW_HIFI partition update ...OK Writing BOOT partition BOOT partition update ...OK Writing RECOVERY partition RECOVERY partition update ...OK Writing RECOVERY2 partition RECOVERY2 partition update ...OK Writing DTS partition DTS partition update ...OK Writing MODEM partition MODEM partition update ...OK Writing MODEM_DSP partition MODEM_DSP partition update ...OK Writing 3RDMODEM partition 3RDMODEM partition update ...OK Erasing CACHE partition Partition CACHE erased Writing CACHE partition CACHE partition update ...OK Writing SYSTEM partition sending sparse file 467708484 bytes Waiting for answer... send sparse file OK sending sparse file 445452668 bytes Waiting for answer... send sparse file OK sending sparse file 373497748 bytes Waiting for answer... send sparse file OK sending sparse file 436721756 bytes Waiting for answer... send sparse file OK sending sparse file 284488172 bytes Waiting for answer... send sparse file OK SYSTEM partition update ...OK Writing MODEM_DTB partition MODEM_DTB partition update ...OK Erasing USERDATA partition Partition USERDATA erased Writing USERDATA partition USERDATA partition update ...OK Software written 2020-08-10 09:28:50 Writing device finished OK Waiting for fastboot device... USB Device REMOVAL Type: @oem103.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: H3XDU17227001369 USB Device INSERTION Type: @oem103.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: H3XDU17227001369 Device found: H3XDU17227001369 File size: 3*020*879*000 bytes Current version(CURVER): EVA_Global_5.0_oversea Writing rescue_recovery partition RESCUE_RECOVERY partition update ...OK Uptade recovery parttion OK USB Device REMOVAL Type: @oem103.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: H3XDU17227001369 USB Device INSERTION Type: @oem45.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: H3XDU17227001369 USB Device REMOVAL Type: @oem68.inf,%vfsusbdevicename0011%;Synaptics FP Sensors (WBF) (PID=0011) VidPid: VID_138A&PID_0011 Instance id: 17eef56fdd91 USB Device INSERTION Type: @oem68.inf,%vfsusbdevicename0011%;Synaptics FP Sensors (WBF) (PID=0011) VidPid: VID_138A&PID_0011 Instance id: 17eef56fdd91 USB Device REMOVAL Type: @oem45.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: H3XDU17227001369 USB Device INSERTION Type: @usb.inf,%usb\device_descriptor_failure.devicedesc %;Unknown USB Device (Device Descriptor Request Failed) VidPid: VID_0000&PID_0002 Instance id: 5&23b1421d&0&3 USB Device REMOVAL Type: @usb.inf,%usb\device_descriptor_failure.devicedesc %;Unknown USB Device (Device Descriptor Request Failed) VidPid: VID_0000&PID_0002 Instance id: 5&23b1421d&0&3 Looking for device in upgrade mode... USB Device INSERTION Type: @oem45.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: H3XDU17227001369 COM270: Android Adapter PCUI (COM270) COM271: DBAdapter Reserved Interface (COM271) Enter recovery mode OK 2020-08-10 09:33:23 Starting to write device in UPGRADE mode... Device found: H3XDU17227001369 Old slow algo NOT selected 2020-08-10 09:33:26 start to write update file File to update: C:\Users\Abdoulgaf\Downloads\PHONE ZONE\HUAWEI FIRMARES\EVA-L09\dload\UPDATE.APP File size: 3*020*879*000 bytes Current version(CURVER): EVA_Global_5.0_oversea Process identifier:26605743 Validating file... Looking for attached port... Preparing to write... Writing file 1 of 27: SHA256RSA...OK Writing file 2 of 27: CRC...OK Writing file 3 of 27: CURVER...OK Writing file 4 of 27: VERLIST...OK Writing file 5 of 27: PACKAGE_TYPE...OK Writing file 6 of 27: EFI...OK Writing file 7 of 27: XLOADER...OK Writing file 8 of 27: FW_LPM3...OK Writing file 9 of 27: FASTBOOT...OK Writing file 10 of 27: MODEMNVM_UPDATE...OK Writing file 11 of 27: TEEOS...OK Writing file 12 of 27: TRUSTFIRMWARE...OK Writing file 13 of 27: SENSORHUB...OK Writing file 14 of 27: FW_HIFI...OK Writing file 15 of 27: BOOT...OK Writing file 16 of 27: RECOVERY...OK Writing file 17 of 27: RECOVERY2...OK Writing file 18 of 27: DTS...OK Writing file 19 of 27: MODEM... Trying update again(2) Exception: Access violation at address 0040B30E in module 'DCPhoenix_v132.exe'. Read of address C0000118 Error downloading file 19 of 27 Error writing software We recommend to repeat the update from fastboot mode with Version check bypass and rescue recovery options checked 2020-08-10 09:34:18 Writing device finished with ERROR |
![]() | #98 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2013
Member: 2023196 Status: Offline Thanks Meter: 1,849 | |
![]() | #104 (permalink) |
Junior Member ![]() Join Date: Oct 2009 Location: Indonesia
Member: 1145346 Status: Offline Thanks Meter: 8 ![]() | DC Phoenix 0.0.0.153 useraxxxxamxxx Device detected COM33 HUAWEI USB COM 1.0 (COM33) BOOTLOADER File to update Kirin980_P1_V1 2112021 13437 PM Starting to write device... Process identifier30091128 Writing bootloader... Step 2... Step 3... Step 4... Step 5... Step 6... Waiting for device REMOVALINSERTION... Waiting for fastboot device... USB Device REMOVAL Type @oem0.inf,%qcomdevice00%;HUAWEI USB COM 1.0 VidPid VID_12D1&PID_3609 Instance id 5&3671d603&1&1 Device found Fxxx Looking for a device in fastboot mode Device found Fxxx Getting IMEI... USB Device INSERTION Type @oem147.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid VID_18D1&PID_D00D Instance id Fxxx USB Device REMOVAL Type @oem147.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid VID_18D1&PID_D00D Instance id Fxxx Waiting for answer... USB Device INSERTION Type @oem147.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid VID_18D1&PID_D00D Instance id Fxxx Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number LYA-L09 10.1.0.319(C432E8R1P5) Model LYA-L09 VendorCountry hweu Battery state 0 OEM lock state info FB LockState LOCKED USER LockState LOCKED OEM get bootinfo locked Getting lock state info... Cannot get FBlock info from device Cannot get HW FBlock info from device Trying to unlock device... Signing process may take few minutes Trying to get data from server Unlocking FRP... Erasing frp... in order to restore phone back to normal you must select disable testpoint USB Device REMOVAL Type @oem147.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid VID_18D1&PID_D00D Instance id Fxxx 2112021 13656 PM Process finished OK Last edited by alldrive; 02-12-2021 at 19:55. |
