Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 10-18-2017, 06:00   #31 (permalink)
Member: 307225
Thanks Meter: 49
It's Time To Post About (E5770s-320 O2 UK) Beta Test Report
    DC - Unlocker 2 Client 1.00.1388 beta
    Detecting modem :
    selection :
    manufacturer - Huawei modems
    model - Auto detect (recommended)
    Found Applications port COM305
    Found modem         : E5770S
    Model               : _Unknown Huawei modem_
    IMEI                : 867472020XXXXXX
    Serial NR.          : UCDDU15C25000960
    Firmware            : 21.200.19.01.405
    Dashboard version   : WEBUI_17.100.11.05.405_MRE5
    Web UI version      : WEBUI_17.100.11.05.405_MRE5
    SIM Lock status     : Locked (Card Lock)
    Wrong codes entered : 3 (unlock attempts left : 7)
    For unlock, may require firmware change, check tutorial or contact support
    Detecting modem :
    selection :
    model - Unknown Huawei router (AuthVer 4)
    Selected Applications port COM305
    Unlocking, please wait ...
    Waiting modem/phone to be ready ...
    Modem successfully unlocked !
    Credits left : 7
The Following 2 Users Say Thank You to Abid Hussain For This Useful Post:
Old 10-18-2017, 06:56   #32 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
DC - Unlocker 2 Client 1.00.1390
Detecting modem :
selection :
model - Huawei AuthVer 4 modem (New)
Selected Applications port COM70
Found modem : E5573Cs-322
Model : Huawei AuthVer 4 modem (New)
IMEI : 861791038647147
Serial NR. : DGF7S17715004690
Firmware : 21.323.01.00.1456
Dashboard version : WEBUI_17.100.15.05.306_MRE5
Web UI version : WEBUI_17.100.15.05.306_MRE5
Wrong codes entered : 0 (unlock attempts left : 10)
AT command error
Error code 37
unlock failed !
Old 10-18-2017, 08:27   #33 (permalink)
Member: 330490
Sonork: 100.1596361
Thanks Meter: 37
how can i unlock this modem
can i downgrade firmware and unlock
Found Applications port COM779
Found modem : E5577Cs-321
IMEI : 864695030363818
Serial NR. : D2LDW17311003759
Firmware : 21.316.01.00.1029
Dashboard version : WEBUI_17.100.13.02.1029_MRE5
Web UI version : WEBUI_17.100.13.02.1029_MRE5
Wrong codes entered : 4 (unlock attempts left : 6)
AT command error
Error code 37
unlock failed !
Old 10-18-2017, 09:13   #34 (permalink)
Member: 145399
Thanks Meter: 26
great update after a long long time. thanks
The Following User Says Thank You to taritm For This Useful Post:
Old 10-18-2017, 09:35   #35 (permalink)
Member: 2023196
Thanks Meter: 1,698
Originally Posted by nduka View Post
How to know customized modems
thanks
If you get error 37 during unlock then it's certainly customized
Detecting modem :
selection :
Selected Applications port COM704
Found modem : E5578s-932
IMEI : 866166020766384
Serial NR. : M3Y7N16607003326
Firmware : 21.316.01.00.334
Dashboard version : WEBUI_17.100.14.00.334_MRE5
Web UI version : WEBUI_17.100.14.00.334_MRE5
Warning! IMEI Log fail!
AT command error
Error code 37
unlock failed !
Only not customized versions available for unlock
Detecting modem :
selection :
AT command error
Error code 37
unlock failed !
Your modem is customized, therefore not available for unlock
AT command error
Error code 37
unlock failed !
Can not confirm if flashing will work on it. Can try 21.180.99.03.00 maybe will work, keep in mind the risk that comes along with flashing.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 10-18-2017, 09:59   #36 (permalink)
.:Towhid:.'s Avatar
Member: 304260
Sonork: 100.1593127
Thanks Meter: 355
Exclamation Huawei Router E5577s-932 Unlock Done (Cost 1 Cr) but Still Device Locked
Detecting modem :
selection :
Found Applications port COM225
Found modem : E5577s-932
IMEI : 866852022455593
Serial NR. : X8BDU15B11005050
Firmware : 21.200.09.00.76
Compile date / time : Oct 9 2015 15:36:49
Hardware ver. : CL1E5577SM
Dashboard version : WEBUI_17.100.09.01.76_MRE5
Web UI version : WEBUI_17.100.09.01.76_MRE5
Check account status
User : 0000EABC
Credits left : 21
Support till : 04-Sep-18
Activated features:
DC-Unlocker
Huawei CDMA modem unlocker
ZTE Qualcomm and Huawei Hisilicon modems Flasher
Unlimited FRP Unlock
Software debugger
Unlock Huawei AuthVer 4 modem (New) (866852022455593) cost 1 cr
Detecting modem :
selection :
Selected Applications port COM177
Credits left : 20
Old 10-18-2017, 10:09   #37 (permalink)
Member: 1271694
Thanks Meter: 15
Do you support these via IMEI ONLY as wel?
thanks
The Following User Says Thank You to charikaar For This Useful Post:
Old 10-18-2017, 10:09   #38 (permalink)
Member: 2023196
Thanks Meter: 1,698
Detecting modem :
selection :
User : 0000EABC
Credits left : 21
Activated features:
DC-Unlocker
Software debugger
Detecting modem :
selection :
Credits left : 20
http://forum.gsmhosting.com/vbb/f100...ocked-2276346/ try to stick to one topic if you post about problem, thank you.
Old 10-18-2017, 10:31   #39 (permalink)
.:Towhid:.'s Avatar
Member: 304260
Sonork: 100.1593127
Thanks Meter: 355
Thanks for cr. refund dear @Namelocked
Old 10-18-2017, 11:29   #40 (permalink)
omairlee01's Avatar
Member: 2068959
Thanks Meter: 246
Huawei E5577c where is she
Old 10-18-2017, 12:07   #41 (permalink)
unlock phones's Avatar
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,362
Cool
Originally Posted by CONCORDIA GSM View Post
whats wrong with this modem i tried on many. same failed
Detecting modem :
selection :
Selected Applications port COM91
Selected Diagnostics port COM22
Found modem : E8372
IMEI : 866280027577338
Serial NR. : R7EDU17807004765
Firmware : 21.327.62.00.1460
Dashboard version : WEBUI_17.100.18.01.1460_RE5
Web UI version : WEBUI_17.100.18.01.1460_RE5
Failed read NVitem
Error code 75
unlock failed !
Detecting modem :
selection :
Found Applications port COM91
Found modem : E8372
IMEI : 866280027577551
Serial NR. : R7EDU17807004787
Error code 376
unlock failed !
i think drivers issue or customized firmware not supported
Old 10-18-2017, 12:08   #42 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 2,602
Good day DC-UNLOCKER Team, though I'm not user yet but I wish if Team can add UNLOCK by IMEI hope it more reliable and add more profit for user....
We believe in you.
We know you people can do that...
Please work on that...
I'm also interest in DC-Unlocker Tool.
Thanks in advance....
Old 10-18-2017, 12:09   #43 (permalink)
Member: 579694
Thanks Meter: 72
Detecting modem :
selection :
Found Applications port COM75
Found modem : 501HW
IMEI : 867381024296697
Serial NR. : 2BB7N16726003282
Firmware : 21.313.01.01.643
Dashboard version : UTPSTOOL_WIN1.12.13.643
Wrong codes entered : 69 (unlock attempts left : 197)
AT command error
Error code 37
unlock failed !
Old 10-18-2017, 12:25   #44 (permalink)
Member: 2023196
Thanks Meter: 1,698
Detecting modem :
selection :
Found modem : 501HW
AT command error
Error code 37
unlock failed !
What's your username or dongle id please?
Old 10-18-2017, 12:49   #45 (permalink)
Kashif Khan's Avatar
Member: 88016
Thanks Meter: 314
Selected Applications port COM174
Selected Diagnostics port COM176
Found modem : R216
IMEI : 357119081211010
Serial NR. : B4JDW17427011084
Firmware : 21.315.03.00.11
Dashboard version : THIRD_PARTY_VDF_PCSVV8.1
Web UI version : THIRD_PARTY_VDF_2.035.8384
SIM Lock status : unlocked
unlock option is not highlited??? showing unlocked bot not working when i put simcard
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.24898 seconds with 8 queries
