Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 10-11-2020, 13:51   #1 (permalink)
Member: 27383
DCPhoenix_v132 Problem still
2020/10/11 17:09:14 Starting to write device in FASTBOOT mode...
File size: 2,206,840,104 bytes
Current version(CURVER): H60-L04V100R001C999B500
Looking for a device in fastboot mode
Device found: T2FDU14821016868
Getting IMEI...
Getting build number...
Getting model ...
Getting model by product ...
Getting model by roduct ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
IMEI:864103022097700
Build number: L04
Vendor/Country: unicomelectric/cn
Battery state: 3835mv
OEM backdoor info:
FB LockState: LOCKED
USER LockState: LOCKED
OEM get bootinfo:
locked
Process identifier:27964886
Erasing ver .. .
Trying to unlock device...
Signing process may take few minutes
Trying to get data from server
Cannot get oem unlock code from server
Unlock process FAIL
Writing BOOT partition
BOOT partition update :FAIL Command not allowed
Device does not allow UPDATE
2020/10/11 17:09:52 Writing device finished - INCOMPLETE
I try many many models,but problem still.
Please check it,thanks.
The Following User Says Thank You to suntluk For This Useful Post:
Old 10-12-2020, 15:36   #2 (permalink)
Member: 2023196
Thanks Meter: 1,549
We are looking into this, thank you for your patience.
Old 10-15-2020, 14:16   #3 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 384
i also facing this isseu fro few days plz team solve this problem.
Old 10-19-2020, 11:18   #4 (permalink)
Member: 2023196
Thanks Meter: 1,549
Please try now, as this problem was on our side regarding bootloader unlock failure.
Old 10-20-2020, 15:24   #5 (permalink)
Member: 27383
Sure,Can not unlock bootloader. Something wrong maybe.
Old 10-20-2020, 16:39   #6 (permalink)
Member: 2023196
Thanks Meter: 1,549
You mean you face exact same problem on same device you had before in original post? It was reported as working again by others who had same problem.
Old 10-21-2020, 05:38   #7 (permalink)
Member: 27383
We flashed it completed after unlock bootloader by other software.
We try it many many model by DCPhoenix_v132 or v131, but same problem.
Old 10-21-2020, 14:05   #8 (permalink)
Member: 27383
DC Phoenix 0.0.0.132
user:szhcu202001
Advanced update
Not Reboot NOT cheked
Update Verlist to server on file load NOT checked
Try Rescue Recovery NOT checked
Bypass version check NOT checked
Old slow algo NOT checked
Looking for a device in upgrade mode
No devices detected in upgrade mode
Device found: TBSDU15212003986
2020/10/21 20:28:00 Starting to write device in FASTBOOT mode...
File size: 2,094,860,464 bytes
Current version(CURVER): PE-CL00V100R001C92EMUI31
Getting IMEI...
Getting model ...
SN:TBSDU15212003986
Build number: PE-V100R001C92B200
Model: PE-CL00
OEM backdoor info:
OEM get bootinfo:
unlocked
Process identifier:28146775
Erasing ver .. .
Unlock process finished successfully
Erasing ver .. .
Writing PTABLE partition
PTABLE partition update ...OK
Writing XLOADER partition
XLOADER partition update ...OK
Writing FASTBOOT partition
FASTBOOT partition update ...OK
Writing FW_LPM3 partition
FW_LPM3 partition update ...OK
Writing FW_HIFI partition
FW_HIFI partition update ...OK
Writing TEEOS partition
TEEOS partition update ...OK
Writing RECOVERY partition
RECOVERY partition update ...OK
Writing SENSORHUB partition
SENSORHUB partition update ...OK
Writing DTS partition
DTS partition update ...OK
Writing MODEMNVM_UPDATE partition
MODEMNVM_UPDATE partition update ...OK
Writing MODEM partition
MODEM partition update ...OK
Writing MODEM_DSP partition
MODEM_DSP partition update ...OK
Writing 3RDMODEM partition
3RDMODEM partition update ...OK
Erasing CUST partition
Partition CUST erased
Writing CUST partition
Waiting for answer...
CUST partition update ...OK
Writing SYSTEM partition
sending sparse file 463165924 bytes
send sparse file OK
sending sparse file 462615592 bytes
send sparse file OK
sending sparse file 469001624 bytes
send sparse file OK
sending sparse file 117369008 bytes
send sparse file OK
SYSTEM partition update ...OK
Erasing CACHE partition
Partition CACHE erased
Writing CACHE partition
CACHE partition update ...OK
Erasing USERDATA partition
Partition USERDATA erased
Writing USERDATA partition
USERDATA partition update ...OK
Software written
2020/10/21 20:34:18 Writing device finished OK
Good job! thanks for your help!
Page generated in 0.16837 seconds with 7 queries
