dig-l03 no flash anymore with dc phoenix hi dc phoenix... i have some phones dig-l03 hang logo, not enter in upgrade mode...
older times i flashed with older versions and same flash via fastboot... the soft unlock automatically bootloader... flash dload and after reboot upgrade mode and flash via upgrade mode and done.
but with latest version dc phoenix i see that SW never unlock boot for flash via fastboot... I think that team change algo or i don't know...
but with some pcs I have same problem in exactly percercent of process Quote:
DC Phoenix 0.0.0.132
user:00044A55
Advanced update
Not Reboot NOT cheked
Update Verlist to server on file load NOT checked
Try Rescue Recovery checked
Bypass version check NOT checked
Old slow algo NOT checked
Looking for a device in upgrade mode
No devices detected in upgrade mode
Device found: XPN9X17325G06071
Detecting recovery partition
File size: 3.970.702.328 bytes
OEMSBL version: DIG-L23C00B003_BOOT
AMSS version: DIG-L23C00B003
RECOVERY partition found
ERECOVERY partition found
30/12/2020 01:43:33 p.m. Starting to try Rescue Recovery...
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
SN:XPN9X17325G06071
IMEI:862995030593139
BT:30749620079E
WIFI:30749620079F
Build number: Diego-L03C25B103
Model: DIG-L03
Vendor/Country: claro/la
Battery state: 3519mv
OEM lock state info:
user Lock state is lock
fbLock state is lock
OEM get bootinfo:
Image is origin
Verify mode is enforcing
Check root info is safe
Lock state is lock
Root State: UNROOT
Process identifier:29348336
Erasing ver .. .
Cannot get FBlock info from device
Trying to unlock device...
Signing process may take few minutes Trying to get data from server
Cannot get oem unlock code from server
Unlock process FAIL
Writing rescue_recovery partition
RESCUE_RECOVERY partition update ...OK
Uptade recovery parttion OK
USB Device REMOVAL
Type: @oem36.inf,%singleadbinterface%;Android ADB Interface
VidPid: VID_18D1&PID_D00D
Instance id: XPN9X17325G06071
Looking for device in upgrade mode...
USB Device INSERTION
Type: @oem32.inf,%busfilter.devicedesc%;USB Composite Device
VidPid: VID_12D1&PID_107D
COM113: Android Adapter PCUI (COM113)
Enter recovery mode OK
30/12/2020 01:44:33 p.m. Starting to write device in UPGRADE mode...
No devices detected in fastboot mode
Old slow algo NOT selected
30/12/2020 01:44:35 p.m. start to write update file
File to update: D:\GSMUNL~1\HUAWEI\DIG-L03\DIEGO-~1._CL\Software\DIEGO-~1\Upgrade\SD upgrade\dload\UPDATE.APP
Process identifier:29348354
Validating file...
Looking for attached port...
Preparing to write...
Writing file 1 of 24: SHA256RSA...OK
Writing file 2 of 24: CRC...OK
Writing file 3 of 24: OEMSBL_VERLIST...OK
Writing file 4 of 24: AMSS_VERLIST...OK
Writing file 5 of 24: RPM...OK
Writing file 6 of 24: TZ...OK
Writing file 7 of 24: SBL1...OK
Writing file 8 of 24: MODEM...OK
Writing file 9 of 24: OEMSBL_VER...OK
Writing file 10 of 24: AMSS_VER...OK
Writing file 11 of 24: DSP...OK
Writing file 12 of 24: CMNLIB...OK
Writing file 13 of 24: KEYMASTER...OK
Writing file 14 of 24: CMNLIB64...OK
Writing file 15 of 24: DEVCFG...OK
Writing file 16 of 24: LKSECAPP...OK
Writing file 17 of 24: ABOOT...OK
Writing file 18 of 24: RECOVERY...OK
Writing file 19 of 24: ERECOVERY...OK
Writing file 20 of 24: SYSTEM...
Exception: Stream read error
Error downloading file 20 of 24
Error writing software
We recommend to repeat the update from fastboot mode with Version check bypass and rescue recovery options checked
30/12/2020 01:50:32 p.m. Writing device finished with ERROR
| I remember that in .63 version the sw work fine...
what can I DO??? |
