Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 11-25-2016, 18:48   #1 (permalink)
Member: 1712680
Thanks Meter: 27
dongle bloked
Hello support, I need your help. I was traying to unlock a modem devices but now my dongle is bloked. Could you help me please?
Thanks in advance
Old 11-26-2016, 15:33   #2 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,194
Hi, could you please post image or log screen??
The Following User Says Thank You to Shensohau For This Useful Post:
Old 11-26-2016, 18:42   #3 (permalink)
Member: 1712680
Thanks Meter: 27
Hello, this is the problem.
best regards
Old 11-27-2016, 12:56   #4 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,194
Hi, please wait for support answer... post your SN or contact them by Provate with your S/N for detailed reasons....
Old 11-27-2016, 17:15   #5 (permalink)
Member: 2080580
Thanks Meter: 42
same poision here ......cm2 plzzzzzzz solved my problem
Old 11-27-2016, 22:43   #6 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,194
Hi, just post S/N and problem here in order to wait for team answer.... or contact them with S/N for check by Private
Old 11-28-2016, 14:00   #7 (permalink)
Member: 2023196
Thanks Meter: 1,813
Thanks in advance
Provide your dongle id so we can check.
Old 12-08-2016, 09:58   #8 (permalink)
Member: 2477800
Thanks Meter: 5
how do we post the serial number if the dongles blocked?
Old 12-08-2016, 11:56   #9 (permalink)
Member: 2023196
Thanks Meter: 1,813
If you do not have anywhere saved your dongle id/sn then write us email to which it is registered to.
Old 12-08-2016, 14:11   #10 (permalink)
Member: 2477800
Thanks Meter: 5
[QUOTE=Namelocked;12209181]If you do not have anywhere saved your dongle id/sn then write us email to which it is registered to.[/QU
messaged you
Old 12-19-2016, 10:15   #11 (permalink)
Member: 2385357
Sonork: 100.002837
Thanks Meter: 9
Dc Unlocker Detected Monitoring Software Error
now dongle block please help
serial 0000B654
Old 12-19-2016, 12:18   #12 (permalink)
Member: 2023196
Thanks Meter: 1,813
[QUOTE=derekh48;12209490]
messaged you
If you still getting blocked then your problem same as below, need to locate and delete service/software that provides usb sharing/scanning services on pc.
serial 0000B654
Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again.
Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block.
Old 12-20-2016, 05:49   #13 (permalink)
Member: 2385357
Sonork: 100.002837
Thanks Meter: 9
[QUOTE=Namelocked;12229986]
ok thanks i think its the flexi hub software causing my problem
after uninstall all is good
thanks for fast solution
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.18686 seconds with 8 queries
