06-03-2020, 11:06 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Türkiye Age: 44
Member: 341207 Status: Offline Thanks Meter: 14 | EML-L29 imei repair cpu not support ?? MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode Repair 2020-06-03 11:21:46.669 Autodetect COM port and phone type start! 2020-06-03 11:21:47.336 Found COM port: COM211 2020-06-03 11:21:47.340 Found phone type: Huawei Android phone (HiSilicon CPU) New IMEI 1 : 3552470******** New IMEI 2 : 3582060******** 2020-06-03 11:21:47.486 Open COM port COM211 (Android Adapter PCUI (COM211))... 2020-06-03 11:21:47.632 Connecting to server... 2020-06-03 11:21:47.947 Connected! 2020-06-03 11:21:49.344 ERROR! Not supported/unknown chipset!!!!!!!!!!!!!!! Memo log saved to C:\Users\guest1\Desktop\HCU_358\Logs\20200603_1121 49_HCU_RepairUmts_456789012345678.txt problem solve ? EML-L29 8.1.0 |
06-03-2020, 11:44 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Please check HCU update info and repair tutorial for your phone: https://forum.gsmhosting.com/vbb/f10...-more-2840749/ |
06-04-2020, 09:26 | #3 (permalink) |
Member: 341207 Status: Offline Thanks Meter: 14 | HCU Client v1.0.0.0362 Account: ********** Before operation turn phone to TestPoint mode: Turn off phone, then short TestPoint on phone pcb and plug USB cable Wait for device "HUAWEI USB COM 1.0" in Ports Read phone info 2020-06-04 11:22:53.175 Connecting to server... 2020-06-04 11:22:54.300 Connected! 2020-06-04 11:22:54.891 Not found HUAWEI device in Test Point mode! 2020-06-04 11:22:55.017 Found fastboot device: 0123456789ABCDEF 2020-06-04 11:22:55.163 Reading info... 2020-06-04 11:22:56.401 Read signed IMEI FAIL! 2020-06-04 11:22:59.129 Missing signed files in secure partition! 2020-06-04 11:22:59.136 Done! Fastboot provided info: Model: EML-L29 Firmware: EML-L29 8.1.0.128(C432) MEID: A000008C368DFE Bootloader FB lock: unlocked Bootloader User lock: locked CPU: kirin970 Found NV data: Modems: 3 IMEI1: 860303046****** IMEI2: 8603030---------- IMEI3: 8603030******** PESN: 80ABB0F5 MEID: A000009556AED7 Found OEM data: IMEI:86712803******* IMEI1:8671280******* MEID:A000008C368DFE Model: EML-L29 Firmware: EML-L29 8.1.0.107D(EUC652) Rescue: rescue:Chipset-boston 8.1.0.001(00PR) Vendor: hw Country: eu Version limitation: OFF RD mode: OFF Memo log saved to C:\Users\guest1\Desktop\HCU_358\Logs\20200604_1122 59_HCU_ReadInfo_860303046481484.txt hcu latest update ok but repaır not work |
06-04-2020, 09:44 | #5 (permalink) |
Member: 341207 Status: Offline Thanks Meter: 14 | imei 00000000000000 sn 1234567890 I could not fix it sir how the fix 04.06.2020 11:43:00 HCU Client v1.0.0.0362 Account:******** Before operation turn phone to TestPoint mode: Turn off phone, then short TestPoint on phone pcb and plug USB cable Wait for device "HUAWEI USB COM 1.0" in Ports Read phone info 2020-06-04 11:43:00.660 Connecting to server... 2020-06-04 11:43:01.669 Connected! 2020-06-04 11:43:02.216 Not found HUAWEI device in Test Point mode! 2020-06-04 11:43:02.338 Found fastboot device: 0123456789ABCDEF 2020-06-04 11:43:02.464 Reading info... 2020-06-04 11:43:03.583 Read signed IMEI FAIL! 2020-06-04 11:43:06.204 Missing signed files in secure partition! 2020-06-04 11:43:06.209 Done! Fastboot provided info: Model: EML-L29 Firmware: EML-L29 8.1.0.128(C432) MEID: A000008C368DFE Bootloader FB lock: unlocked Bootloader User lock: locked CPU: kirin970 Found NV data: Modems: 3 IMEI1: 860303046481484 IMEI2: 860303046520331 IMEI3: 860303046652381 PESN: 80ABB0F5 MEID: A000009556AED7 Found OEM data: IMEI:867128030722145 IMEI1:867128030732151 MEID:A000008C368DFE Model: EML-L29 Firmware: EML-L29 8.1.0.107D(EUC652) Rescue: rescue:Chipset-boston 8.1.0.001(00PR) Vendor: hw Country: eu Version limitation: OFF RD mode: OFF Memo log saved to C:\Users\guest1\Desktop\HCU_358\Logs\20200604_1143 06_HCU_ReadInfo_860303046481484.txt Last edited by Namelocked; 06-04-2020 at 10:48. |
06-04-2020, 10:50 | #6 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Probably need modem_secure partition to be reflashed for imei repair to work. This process could further damage the device, and even if flash successful phone may not work normally/fully functional. if you would like to try flashing it regardless here is the guide with file in it https://www.dc-unlocker.com/modem-secure-flash |
The Following User Says Thank You to Namelocked For This Useful Post: |
06-07-2020, 11:50 | #8 (permalink) |
Freak Poster Join Date: Jan 2008 Location: HH +4940
Member: 686560 Status: Offline Thanks Meter: 68 | https://forum.dc-unlocker.com/forum/...l29-no-service I have the same problem, I think whether it is worth buying this program without help |
