Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 09-10-2018, 10:54   #91 (permalink)
Member: 288521
Thanks Meter: 685
Namelocked can u reply to the PMs i sent you please?
Old 09-10-2018, 12:07   #92 (permalink)
Member: 352880
Sonork: 100.1609545
Thanks Meter: 554
Check account status
User : 0012*****
Credits left : 0
Support till : 1/19/2038
Activated features:
DC-Unlocker
Huawei CDMA modem unlocker
ZTE Qualcomm and Huawei Hisilicon modems Flasher
DC Phoenix activation
Unlimited FRP Unlock
HCU activation for dongle
Software debugger
now how can i use HCU
Old 09-10-2018, 12:18   #93 (permalink)
Member: 2023196
Thanks Meter: 1,891
User : 0012*****
Credits left : 0
Activated features:
DC-Unlocker
Software debugger
you launch HCU, select dongle user and use it...
Old 09-10-2018, 14:13   #94 (permalink)
Member: 352880
Sonork: 100.1609545
Thanks Meter: 554
hcu clint did not recognized the dcunlocker dongle while the other features are working dc phoenix working dc unlocker working but hcu not worked
Old 09-10-2018, 17:51   #95 (permalink)
Member: 169896
Thanks Meter: 323
You need to close DC U and DC P to use HCU
Sent from my SM-G965W using Tapatalk
The Following User Says Thank You to ashahzad_pk For This Useful Post:
Old 09-10-2018, 18:00   #96 (permalink)
Member: 2501288
Thanks Meter: 328
i have same problem activation hcu done but when i tried to change account to dongle still same request user and pass!!
User : 03210*****
Credits left : 0
Support till : 19/1/2038
Activated features:
DC-Unlocker
Software debugger
Old 09-10-2018, 20:51   #97 (permalink)
Member: 2043695
Thanks Meter: 2
i have nck pro dongle and i have UltimateNCKHuawei which have the same interface as hcu
can i take advantage of the offer
Old 09-10-2018, 21:17   #98 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
On HCU no, it won't require credits for these operation after activation.
This price list is for users with user account.
where is HCU unlimited activation for infinity dongle? pls don't tell.me.we have to activate dc and then....
Old 09-11-2018, 03:20   #99 (permalink)
Member: 2632366
Thanks Meter: 2
Error in ACTIVATION Dongle not found
Old 09-11-2018, 06:47   #100 (permalink)
Member: 381241
Thanks Meter: 13
same problem
need help
Old 09-11-2018, 06:50   #101 (permalink)
Member: 381241
Thanks Meter: 13
problem is can't select change account type to dongle user
only username and password need
Old 09-11-2018, 07:20   #102 (permalink)
Member: 381241
Thanks Meter: 13
problem solved
HCU exe doesn't ask to choose infinity dongle or username and password, simply because you need to install the correct Alcro smart card drivers. Or just uninstall the smart card drivers, then update manually into Microsoft default drivers...make sure all other dongles are disconnected. follow the pics below..good luck
credits go to lyes_albert
thank you
The Following User Says Thank You to phitsawarn For This Useful Post:
Old 09-11-2018, 08:52   #103 (permalink)
Member: 2023196
Thanks Meter: 1,891
Meands dongle being used by another software probably. Make sure every other tool is closed.
Means dongle not detected in by software, either not installed correctly or not visible due to it being used by another tool.
You must contact infinity if your dongle is not activated for DC-unlocker yet.
Too little information to help you from it, need to kow at least dongle id...
Old 09-11-2018, 11:05   #104 (permalink)
Member: 2501288
Thanks Meter: 328
problem solved after reinstall ALCORE drivers
Old 09-11-2018, 13:56   #105 (permalink)
Member: 352880
Sonork: 100.1609545
Thanks Meter: 554
is that work on infinity slim plus which is activated dc unlocker and dc phonix and hcu clint
Page generated in 0.26990 seconds with 10 queries
