i have two problem today....hcu don't connect to server and now i have downloaded dcphoenix but when i want run it show me disk not present in D: Can you help me? |
Do not quite understand the other problem, maybe could add screenshot? |
i try with DC_Phoenix_v32 but error Writing bootloader... Writing CHM-U01_MAA001057_Factory_firmware_Europe_Android_4.4. 2_EMUI_3.0_3.dtwork... Writing CHM-U01_MAA001057_Factory_firmware_Europe_Android_4.4. 2_EMUI_3.0_4.dtwork... 12/4/2017 2:12:04 PM Writing device finished - INCOMPLETE |
Hi, Cannot get this Version (0208) to run in Win 10 pro, latest updates. Besides Win Defender stopping it (Trojan Warning) even when I disable defender I get a message “The application was unable to start correctly (0xc0150002), Click OK to close the application.” Any suggestions, please? TIA |
i try already DC_Phoenix_v45 but phone not connect dead mode 12/4/2017 12:27:30 PM Starting to write device in FASTBOOT mode... File to update: CHM-U01_MAA001057_Factory_firmware_Europe_Android_4.4. 2_EMUI_3.0.dgtks No devices detected in force upgrade mode |
Anyway after update completed (eventually) and I also manually update C++ I am still getting the same error (0xc0150002), also Defender reports a trojan, but the strange thing is it will run on my old XP machine. Also some of the older versions (hard to find) run on my Win10 machine. Do you have a link for the old 0199 version, please? Just to see if that will run. TIA. |
with every update HCU works worse, changing the number of imei in the android system shows changed imei, but with the command fastboot shows the old imei. Typing for example at the end imei 1 changes to 5; / |
Install https://www.microsoft.com/en-us/down...n.aspx?id=5555 |
Look, change imei in Manufacture mode run factory reset, press *#06# imei has changed, shutdown phone disconnect usb kable, press vol - connect to pc, and read imei in HCU "Read phone info" imei is old but in android is new imei o.0 in fact, the imei number is not changed, after version 174 problems started, I wrote with your support, I got a range betatester but it has not been repaired |
