GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   DC Unlocker (https://forum.gsmhosting.com/vbb/f1004/)
-   -   HCU-Client v..130 Unlock 2K models added & info how get Free license (https://forum.gsmhosting.com/vbb/f1004/hcu-client-v-130-unlock-2k-models-added-info-how-get-free-license-2204325/)
alsa754 03-21-2017 19:09
this is the screen shots of the operation , you can't find this solution in ALL THE WEB apart from here.
alsa754 03-23-2017 20:12
please sir i have CANC432B100, how to repair to become CAN-L01C432...
alsa754 03-24-2017 17:21
when i flash factory firmware the fone become caz-al10 CDMA, and after flash can-l01 fone become canc432 but without gsm mode, he ask for meid and esn not like gsm
Namelocked 03-27-2017 12:13
Flash update.app file in fastboot mode, then in upgrade mode, see if it makes any difference.
alsa754 03-27-2017 12:48
i did it, but fone become CANC432 without L01, and in HCU fone detected as CDMA, with 2 imei
alsa754 03-27-2017 13:24
and with *#06# it gives 3 line: MEID00000000, AESN:OOOOOO AND IMEI:0
alsa754 03-27-2017 18:23
1 Attachment(s)
when i try upgrade it stops at file 3
alsa754 03-27-2017 18:55
3 Attachment(s)
more screen shots to describe the problem
Namelocked 03-28-2017 16:45
Please try to flash your UPDATE.app file in fastboot first only then in upgrade mode.
alsa754 03-28-2017 16:48
that what i have did sir, update.app in fastboot mode, then the same file in upgrade mode and it stops at file 3, i have tried can-l01c432b100 and b140 and b300
Namelocked 03-28-2017 16:51
Then we will check if another factory firmware file available for this phone model, will inform on this topic.
alsa754 03-28-2017 16:59
thank you verry much sir, also i have activated CHU for one year, how can i use it in another PC please
alexey333 03-29-2017 09:22
Huawei_P9_Lite_VNS-TL00 backup send [email protected]
Namelocked 03-29-2017 16:25
Sadly but only 2 version of this phone factory firmwares are availble, both of them are on our support area. Maybe later will come up more for it. You may try to repair numbers via HCU for mobile, if hardware is capable it may function as it is.
You need to wait for 48h before can use HCU on another PC.
alsa754 03-29-2017 17:50
ok, thank you sir i will try all updat.app in all different ways, and hope that you will find another factory firmware, in HCU simlock is unknown and only one imei can be repaired,factory firmware is unlocked and rooted so i will try twrp ..... thank you again
Page generated in 0.25896 seconds with 5 queries
