03-24-2021, 14:12 | #19 (permalink) |
Insane Poster Join Date: Sep 2012 Location: TOGO(Lome)
Member: 1813429 Status: Offline Thanks Meter: 11 | i finally figured out what to do. and now it worked thanks. now i have another question. possible to active dual-sim function with this new version on recent huawei phone like mate 20 pro and p30 lite? |
03-24-2021, 14:15 | #20 (permalink) | |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Quote:
04-27-2021, 15:44 | #25 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Your IMEI on mobile shows zeroes, have you repaired it? What do you see with *#06# two imeis or one? Your phone is set to double sim, and the problem may be related to firmware if it does not show double IMEI and from that may be network lock problem as well. You sure it is L21AF or you have rebranded it? |
04-27-2021, 17:53 | #26 (permalink) | ||
Junior Member Join Date: Apr 2019 Location: iran
Member: 2906470 Status: Offline Thanks Meter: 29 | Quote:
These files are correct, they contain the Preloader and Cust files, the flash file is burned properly, either with Dc Phoenix or with a memory card, when I get the information with hcu in Testpoint mode imei and model and other information is correct Quote:
I backed up the Oeminfo partition and burned it again later. Do you know another firmware? Can You Help Me For Write Bordsofware(how To Do) Last edited by Namelocked; 04-28-2021 at 16:13. | ||
04-28-2021, 16:15 | #27 (permalink) | |
04-29-2021, 13:16 | #29 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Please do this: 1. Restart HCU software. 2. Login with your account on software. 3. Right click on memo area make sure "enable debug logging" has a check mark. 4. Detect your device. Try to network/sim unlock, after attempt do rest of the steps 5. Right click on memo area and save "debug log file". 6. Send that file to me, please. |
04-30-2021, 09:36 | #30 (permalink) | |
The Following User Says Thank You to ghayoum1 For This Useful Post: |
