Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Direct Codes ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
12-14-2017, 17:15 | #1 (permalink) |
Crazy Poster Join Date: May 2013 Location: venezuela
Member: 1946869 Status: Offline Sonork: tonyx Thanks Meter: 7 | help hcu client Access denied (for using protocol monitoring software) Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode 2017.12.14 11:39:22.482 Checking account blackphone_06... 2017-12-14 11:39:22.490 Connecting to server... 2017-12-14 11:39:25.211 Connected! Access denied (for using protocol monitoring software) 2017.12.14 11:39:56.392 Checking account blackphone_06... 2017-12-14 11:39:56.401 Connecting to server... 2017-12-14 11:39:57.830 Connected! Access denied (for using protocol monitoring software) 2017.12.14 11:43:19.791 Checking account blackphone_06... 2017-12-14 11:43:19.799 Connecting to server... 2017-12-14 11:43:22.220 Connected! Access denied (for using protocol monitoring software) |
12-15-2017, 16:10 | #4 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Please uninstall al software that you use for share usb ports, wincap etc... then restart pc and try again... Best Regards Shensohau |
The Following User Says Thank You to Shensohau For This Useful Post: |
12-15-2017, 16:48 | #5 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | [QUOTE=tonyramire;12844844]Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again. Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block. |
12-26-2017, 17:24 | #6 (permalink) | |
Member: 1946869 Status: Offline Sonork: tonyx Thanks Meter: 7 | [QUOTE=Namelocked;12845112] Quote:
That's why the problem is coming to me now after 1 year of use | |
12-26-2017, 18:20 | #7 (permalink) |
Member: 1946869 Status: Offline Sonork: tonyx Thanks Meter: 7 | Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode 2017.12.26 12:49:47.997 Checking account blackphone_06... 2017-12-26 12:49:48.008 Connecting to server... 2017-12-26 12:49:49.685 Connected! Access denied (for using protocol monitoring software) |
12-28-2017, 16:16 | #8 (permalink) |
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, please uninstall all usb sharing ports software, wincap etc, all those will block your account, if you will continue use it your account will be blocked permantely please avoid it... uninstall them or use licence on a clean pc without monitoring software Best Regards Shensohau |
12-28-2017, 19:32 | #9 (permalink) | |
Member: 1946869 Status: Offline Sonork: tonyx Thanks Meter: 7 | Quote:
I use it on another clean PC and it throws me the same message they can not reset my account | |
Thread Tools | |
Display Modes | |
