11-17-2020, 21:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: in the web Age: 41
Member: 630907 Status: Offline Thanks Meter: 127 | Error connecting to server ! (error code 62) Error connecting to server ! I have credits and account active, anyway helpme? thanks a lot Aniway can helpme please??? Last edited by Namelocked; 11-18-2020 at 16:50. |
11-18-2020, 16:50 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Do you get this error during service time or when you try to log in? Very little information to help you from. You should start from checking adapter binding settings/priority list for connections on computer maybe, but problem may be elsehwere as well. Check adapter binding settings https://www.dc-unlocker.com/adapter-binding-settings If adapters do not solve connection problem check metrics: control panel > network and internet > network connections > Right click on your device that you want to unlock connection > Properties > Internet protocol (TCP/IPv4) > Properties > Advanced > IP settings > Uncheck "Automatic metric". Set Interface metric as "10". OK > OK > Close |
11-18-2020, 18:45 | #3 (permalink) | |
Member: 630907 Status: Offline Thanks Meter: 127 | Quote:
11-18-2020, 19:06 | #4 (permalink) |
Member: 630907 Status: Offline Thanks Meter: 127 | Found modem : AirCard 779S Model : Netgear AirCard 779S IMEI : 01426000006xxxx Serial NR. : 45M1527C0xxxx Firmware : NTG9X15A_01.00.01.11 Voice feature : disabled SIM Lock status : unlocked Done, thanks a lot |
The Following User Says Thank You to erocelmaster For This Useful Post: |
