Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 08-18-2021, 07:59   #1 (permalink)
Member: 1607814
Sonork: 100.1658107
Thanks Meter: 10
Huawei ID Remove P30 Pro ELE-AL00 Help
Hi, Need Help to Remove huawei ID.
Tried with Phoenix Testpoint and HCU and did not remove it.
Previously the phone was Stuck Logo "Your Device has failed verification and may not work properly"
After trying many times to be able to Flash it, I managed to turn it on.
FLASH
DC Phoenix 0.0.0.164
user:00
File size: 5.258.545.220 bytes
Current version(BASE_VER): ELE-LGRP1-CHN 10.1.0.165
Package Type: OFFLINE_UPDATE
TIME:2020-08-21 16:24:19
Revision: 1
Checking partition: BASE_VERLIST
With this update file it is necessary to select CUST file and if it exists, PRELOAD file.
File size: 9.632.780 bytes
Current version(CUST_VER): ELE-AL00-CUST 10.1.0(C00)
TIME:2020-08-21 15:07:36
Checking partition: CUST_VERLIST
File size: 1.014.719.888 bytes
Current version(PRELOAD_VER): ELE-AL00-PRELOAD 10.0.0(C00R1)
Checking partition: PRELOAD_VERLIST
user:00
Looking for a device in upgrade mode
No devices detected in upgrade mode
Device found: 8KE5T19626008176
Advanced update
Not Reboot NOT checked
Update Verlist to server on file load NOT checked
Enable testpoint NOT checked
Disable testpoint NOT checked
Try Rescue Recovery checked
Bypass version check NOT checked
Old slow algo NOT checked
Detecting recovery partition
ERECOVERY_KERNEL partition found
ERECOVERY_RAMDISK partition found
ERECOVERY_VENDOR partition found
18/8/2021 03:12:41 Starting to try Rescue Recovery...
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
Build number: :ELE-AL00 10.0.0.188(C00E85R2P11)
Model: ELE-AL00
Vendor/Country: all/cn
Battery state: 4382mv
OEM lock state info:
FB LockState: LOCKED
USER LockState: LOCKED
OEM get bootinfo:
locked
Getting base version...
Base Version: ELE-LGRP1-CHN 11.0.0.142
Getting cust version...
Cust Version: ELE-AL00-CUST 11.0.0.142(C00)
Getting preload version...
Preload Version: ELE-AL00-PRELOAD 11.0.0.5(C00R2)
Process identifier:32708663
Erasing ver .. .
Writing rescue_recovery_kernel partition
RESCUE_RECOVERY_KERNEL partition update ...OK
Writing rescue_recovery_ramdisk partition
RESCUE_RECOVERY_RAMDISK partition update ...OK
Writing rescue_recovery_vendor partition
RESCUE_RECOVERY_VENDOR partition update ...OK
Update recovery parttion OK
USB Device REMOVAL
Type: @oem33.inf,%hwfastboot%;Android Sooner Single ADB Interface
VidPid: VID_18D1&PID_D00D
Instance id: 8KE5T19626008176
Looking for device in upgrade mode...
USB Device INSERTION
Type: @oem37.inf,%busfilter.devicedesc%;USB Composite Device
VidPid: VID_12D1&PID_107E
COM7: DBAdapter Reserved Interface (COM7)
COM10: Android Adapter PCUI (COM10)
Enter recovery mode OK
18/8/2021 03:13:50 Starting to write device in UPGRADE mode...
Old slow algo NOT selected
18/8/2021 03:13:52 start to write update file
File to update: H:\Archivo Externos\Archivos de telefonos\HUAWEI\P30\P30 ELE-AL00\10.1.0.165 C00E165R2P11\Software\dload\update_sd_base\UPDATE. APP
Process identifier:32708692
Validating file...
Looking for attached port...
Preparing to write...
Writing file 1 of 52: SHA256RSA...
Writing file 1 of 52: SHA256RSA...OK
Writing file 2 of 52: CRC...
Writing file 2 of 52: CRC...OK
Writing file 3 of 52: BASE_VERLIST...
Writing file 3 of 52: BASE_VERLIST...OK
Writing file 4 of 52: BASE_VER...
Writing file 4 of 52: BASE_VER...OK
Writing file 5 of 52: PACKAGE_TYPE...
Writing file 5 of 52: PACKAGE_TYPE...OK
Writing file 6 of 52: HISIUFS_GPT...
Writing file 6 of 52: HISIUFS_GPT...OK
Software written
18/8/2021 03:14:13 start to update cust file
File to update: H:\Archivo Externos\Archivos de telefonos\HUAWEI\P30\P30 ELE-AL00\10.1.0.165 C00E165R2P11\Software\dload\update_sd_cust_ELE-AL00_all_cn\UPDATE.APP
Process identifier:32708704
Validating file...
Writing file 1 of 7: SHA256RSA...
Writing file 1 of 7: SHA256RSA...OK
Writing file 2 of 7: CRC...
Writing file 2 of 7: CRC...OK
Writing file 3 of 7: CUST_VERLIST...
Writing file 3 of 7: CUST_VERLIST...OK
Writing file 4 of 7: CUST_VER...
Writing file 4 of 7: CUST_VER...OK
Writing file 5 of 7: PACKAGE_TYPE...
Writing file 5 of 7: PACKAGE_TYPE...OK
Writing file 6 of 7: PTABLE_CUST...
Writing file 6 of 7: PTABLE_CUST...OK
Software written
18/8/2021 03:14:36 start to update preload
File to update: H:\Archivo Externos\Archivos de telefonos\HUAWEI\P30\P30 ELE-AL00\10.1.0.165 C00E165R2P11\Software\dload\update_sd_preload_ELE-AL00_all_cn_R2\UPDATE.APP
Process identifier:32708716
Validating file...
Writing file 3 of 7: PRELOAD_VERLIST...
Writing file 3 of 7: PRELOAD_VERLIST...OK
Writing file 4 of 7: PRELOAD_VER...
Writing file 4 of 7: PRELOAD_VER...OK
Writing file 6 of 7: PTABLE_PRELOAD...
Writing file 6 of 7: PTABLE_PRELOAD...OK
Software written
18/8/2021 03:15:01 start to write update file
Process identifier:32708733
Validating file...
Writing file 7 of 52: XLOADER...
Writing file 7 of 52: XLOADER...OK
Writing file 8 of 52: FASTBOOT...
Writing file 8 of 52: FASTBOOT...OK
Writing file 9 of 52: DTS...
Writing file 9 of 52: DTS...OK
Writing file 10 of 52: DTO...
Writing file 10 of 52: DTO...OK
Writing file 11 of 52: VECTOR...
Writing file 11 of 52: VECTOR...OK
Writing file 12 of 52: FW_LPM3...
Writing file 12 of 52: FW_LPM3...OK
Writing file 13 of 52: HHEE...
Writing file 13 of 52: HHEE...OK
Writing file 14 of 52: VBMETA...
Writing file 14 of 52: VBMETA...OK
Writing file 15 of 52: TEEOS...
Writing file 15 of 52: TEEOS...OK
Writing file 16 of 52: TRUSTFIRMWARE...
Writing file 16 of 52: TRUSTFIRMWARE...OK
Writing file 17 of 52: SENSORHUB...
Writing file 17 of 52: SENSORHUB...OK
Writing file 18 of 52: FW_HIFI...
Writing file 18 of 52: FW_HIFI...OK
Writing file 19 of 52: KERNEL...
Writing file 19 of 52: KERNEL...OK
Writing file 20 of 52: MODEMNVM_UPDATE...
Writing file 20 of 52: MODEMNVM_UPDATE...OK
Writing file 21 of 52: MODEMNVM_CUST...
Writing file 21 of 52: MODEMNVM_CUST...OK
Writing file 22 of 52: MODEM_DRIVER...
Writing file 22 of 52: MODEM_DRIVER...OK
Writing file 23 of 52: RECOVERY_RAMDISK...
Writing file 23 of 52: RECOVERY_RAMDISK...OK
Writing file 24 of 52: RECOVERY_VENDOR...
Writing file 24 of 52: RECOVERY_VENDOR...OK
Writing file 25 of 52: RECOVERY_VBMETA...
Writing file 25 of 52: RECOVERY_VBMETA...OK
Writing file 26 of 52: PREAS...
Writing file 26 of 52: PREAS...OK
Writing file 27 of 52: PREAVS...
Writing file 27 of 52: PREAVS...OK
Writing file 28 of 52: PRETS...
Writing file 28 of 52: PRETS...OK
Writing file 29 of 52: PRETVS...
Writing file 29 of 52: PRETVS...OK
Writing file 30 of 52: ERECOVERY_KERNEL...
Writing file 30 of 52: ERECOVERY_KERNEL...OK
Writing file 31 of 52: ERECOVERY_RAMDISK...
Writing file 31 of 52: ERECOVERY_RAMDISK...OK
Writing file 32 of 52: ERECOVERY_VENDOR...
Writing file 32 of 52: ERECOVERY_VENDOR...OK
Writing file 33 of 52: ERECOVERY_VBMETA...
Writing file 33 of 52: ERECOVERY_VBMETA...OK
Writing file 34 of 52: ENG_VENDOR...
Writing file 34 of 52: ENG_VENDOR...OK
Writing file 35 of 52: ENG_SYSTEM...
Writing file 35 of 52: ENG_SYSTEM...OK
Writing file 36 of 52: HDCP...
Writing file 36 of 52: HDCP...OK
Writing file 37 of 52: CACHE...
Writing file 37 of 52: CACHE...OK
Writing file 38 of 52: RAMDISK...
Writing file 38 of 52: RAMDISK...OK
Writing file 39 of 52: SUPER...
Writing file 39 of 52: SUPER...OK
Writing file 40 of 52: SUPER...
Writing file 40 of 52: SUPER...OK
Writing file 41 of 52: VBMETA_SYSTEM...
Writing file 41 of 52: VBMETA_SYSTEM...OK
Writing file 42 of 52: VBMETA_VENDOR...
Writing file 42 of 52: VBMETA_VENDOR...OK
Writing file 43 of 52: VBMETA_ODM...
Writing file 43 of 52: VBMETA_ODM...OK
Writing file 44 of 52: VBMETA_HW_PRODUCT...
Writing file 44 of 52: VBMETA_HW_PRODUCT...OK
Writing file 45 of 52: VBMETA_CUST...
Writing file 45 of 52: VBMETA_CUST...OK
Writing file 46 of 52: ISP_FIRMWARE...
Writing file 46 of 52: ISP_FIRMWARE...OK
Writing file 47 of 52: MODEM_FW...
Writing file 47 of 52: MODEM_FW...OK
Writing file 48 of 52: HISEE_IMG...
Writing file 48 of 52: HISEE_IMG...OK
Writing file 49 of 52: PATCH...
Writing file 49 of 52: PATCH...OK
Writing file 50 of 52: KPATCH...
Writing file 50 of 52: KPATCH...OK
Writing file 51 of 52: USERDATA...
Writing file 51 of 52: USERDATA...OK
Writing file 52 of 52: UFSFW...
Writing file 52 of 52: UFSFW...OK
Software written
18/8/2021 03:22:40 start to update cust file
Process identifier:32708910
Validating file...
Writing file 7 of 7: VERSION...
Writing file 7 of 7: VERSION...OK
Software written
18/8/2021 03:23:04 start to update preload
Process identifier:32708923
Validating file...
Writing file 7 of 7: PRELOAD...
Writing file 7 of 7: PRELOAD...OK
Software written
18/8/2021 03:24:52 Writing device finished OK
DC PHOENIX TESTPOINT
user:00
Revision: 1
user:00
bootloader file download successfully
Doing job: Unlock Huawei ID by TestPoint
Looking for devices...
Looking for devices in testpoint mode
Device detected:
COM6: HUAWEI USB COM 1.0 (COM6)
BOOTLOADER selected to update:Kirin980_P1_V3
user:00
Device detected:
BOOTLOADER File to update: Kirin980_P1_V3
18/8/2021 03:43:16 Starting to write device...
Process identifier:32709505
Writing bootloader...
Step 2...
Step 3...
Step 4...
Step 5...
Step 6...
Waiting for device REMOVAL/INSERTION...
Waiting for fastboot device...
USB Device REMOVAL
Type: @oem41.inf,%qcomdevice00%;HUAWEI USB COM 1.0
VidPid: VID_12D1&PID_3609
Instance id: 6&11dab44f&0&1
Getting IMEI...
Getting model ...
Build number: :ELE-AL00 10.1.0.165(C00E165R2P11)
Model: ELE-AL00
Battery state: 0
OEM get bootinfo:
locked
Cannot get FBlock info from device
Cannot get HW FBlock info from device
Trying to unlock device...
Signing process may take few minutes
Trying to get data from server
Unlocking FRP...
unlocking Huawei id...
Erasing frp...
in order to restore phone back to normal you must select disable testpoint
USB Device REMOVAL
18/8/2021 03:44:31 Process finished OK
HCU
18/8/2021 03:40:17
HCU Client v1.0.0.0378
Account: 00
Before operation turn phone to TestPoint mode:
Turn off phone, then short TestPoint on phone pcb
and plug USB cable
Wait for device "HUAWEI USB COM 1.0" in Ports
Repair
Unlock downgrade/customization limitations
Erase Huawei ID
Selected Cpu/Bootloader - Kirin980_P1_V3
2021-08-18 03:40:17.928 Connecting to server...
2021-08-18 03:40:18.571 Connected!
2021-08-18 03:40:19.984 HUAWEI device in Test Point mode Not found!
2021-08-18 03:40:20.103 Reading info...
2021-08-18 03:40:26.168 Done!
Fastboot provided info:
CPU: kirin980
Model: ELE-AL00
Firmware: ELE-AL00 10.1.0.165(C00E165R2P11)
Vendor: all
Country: cn
SN: 8KE5T19626008176
PCB SN: 5T6CTC196U056318
WIFI MAC: 143CC3DF9709
Theme color: black
Device color: lightblue
FBLOCK: 1
Bootloader FB lock: unlocked
Bootloader User lock: locked
Found signed IMEI:
Key: 0x6000
IMEI1: 86756304252XXXX
IMEI2: 86756304290XXXX
IMEI3: 86756304317XXXX
SIM NW_LOCK status: UNLOCKED
Found OEM data:
Model: ELE-AL00
Vendor: all
Country: cn
Version limitation: OFF
Phone ID: EFC8E51E7B79110
2021-08-18 03:40:31.592 Repairing...
2021-08-18 03:40:31.608 Write partition oeminfo...
2021-08-18 03:40:34.827 Write partition oeminfo success!
2021-08-18 03:40:34.859 Unlocking restrictions...
2021-08-18 03:40:34.928 Unlock restrictions success!
2021-08-18 03:40:34.942 Erase Huawei ID...
2021-08-18 03:40:34.965 Erase Huawei ID success!
2021-08-18 03:40:34.975 Done!
Memo log saved to H:\Archivo Externos\Archivos de telefonos\HCU\HCU_378\Logs\20210818_034035_HCU_Xlo aderRepair_EFC8E51E7B79110.txt
Old 08-18-2021, 15:42   #2 (permalink)
Member: 2023196
Thanks Meter: 1,891
At the moment these phones not supported. We are currently looking to buy Kirin710 or Kirin980 mobile with locked Huawei ID. If you are willing to sell your unit please contact us via support chat from website or leave us a letter/message here https://www.dc-unlocker.com/contacts with your country and price you request for device.
Page generated in 0.20831 seconds with 9 queries
