Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 06-20-2020, 17:49   #1 (permalink)
-=P.F.U=-'s Avatar
Member: 2825953
Thanks Meter: 209
LDN-L01 8.0.0.149(C185) Error checking VERLIST
Standard update
Not Reboot NOT cheked
Update Verlist to server on file load NOT checked
Try Rescue Recovery checked
Bypass version check checked
Old slow algo NOT checked
Looking for a device in upgrade mode
No devices detected in upgrade mode
Device found: 8XEBB18626152785
Detecting recovery partition
File size: 3,572,000,480 bytes
AMSS version: LDN-L22 8.0.0.122(C900)
ERECOVERY_KERNEL partition found
ERECOVERY_RAMDISK partition found
ERECOVERY_VENDOR partition found
6/20/2020 6:41:18 PM Starting to try Rescue Recovery...
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
SN:8XEBB18626152785
IMEI:867239031831270
Build number: LDN-L01 8.0.0.149(C185)
Model: LDN-L01
Vendor/Country: hw/meafnaf
Battery state: 3638mv
OEM lock state info:
user Lock state is lock
fbLock state is lock
OEM get bootinfo:
Image is origin
Verify mode is enforcing
Check root info is safe
Lock state is lock
Root State: UNROOT
Process identifier:25350616
Erasing ver .. .
Cannot get FBlock info from device
Trying to unlock device...
Signing process may take few minutes
Trying to get data from server
Unlock process finished successfully
Erasing ver .. .
Writing rescue_recovery_kernel partition
RESCUE_RECOVERY_KERNEL partition update ...OK
Writing rescue_recovery_ramdisk partition
RESCUE_RECOVERY_RAMDISK partition update ...OK
Writing rescue_recovery_vendor partition
RESCUE_RECOVERY_VENDOR partition update ...OK
Uptade recovery parttion OK
Looking for device in upgrade mode...
USB Device REMOVAL
Type: @oem66.inf,%hwfastboot%;Android Sooner Single ADB Interface
VidPid: VID_18D1&PID_D00D
Instance id: 8XEBB18626152785
USB Device INSERTION
Type: @oem70.inf,%busfilter.devicedesc%;USB Composite Device
VidPid: VID_12D1&PID_107D
COM60: Android Adapter PCUI (COM60)
Enter recovery mode OK
6/20/2020 6:42:09 PM Starting to write device in UPGRADE mode...
No devices detected in fastboot mode
Old slow algo NOT selected
6/20/2020 6:42:10 PM start to write update file
File to update: C:\Users\hp\Desktop\Software\dload\UPDATE.APP
Process identifier:25350631
Validating file...
Looking for attached port...
Preparing to write...
Bypass version checked
6/20/2020 6:42:25 PM Writing device finished with ERROR
Old 06-22-2020, 14:37   #2 (permalink)
Member: 2023196
Thanks Meter: 1,794
Need to know your username/dongle id.
Old 06-22-2020, 15:05   #3 (permalink)
-=P.F.U=-'s Avatar
Member: 2825953
Thanks Meter: 209
my dongle user:0132501E
Old 06-23-2020, 14:47   #4 (permalink)
Member: 2023196
Thanks Meter: 1,794
File you are using doesn't have verlist part therefore it won't work for flashing it. Use valid full stock roms.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 09-27-2020, 17:55   #5 (permalink)
-=P.F.U=-'s Avatar
Member: 2825953
Thanks Meter: 209
Same problem with another phone.
DC Phoenix 0.0.0.132
user:0132501E
Standard update
Old slow algo checked
Device found: 8XEBB18C05401427
File size: 3,603,465,484 bytes
AMSS version: LDN-L21 8.0.0.100(C432)
9/27/2020 6:01:11 PM Starting to try Rescue Recovery...
Getting IMEI...
Getting model ...
SN:8XEBB18C05401427
IMEI:865802042129307
Build number: LDN-L01 8.0.0.155(C02)
Model: LDN-L01
Vendor/Country: vodafone/za
Battery state: 4037mv
OEM get bootinfo:
Image is origin
Lock state is lock
Root State: UNROOT
Process identifier:27707760
Erasing ver .. .
Erasing ver .. .
USB Device REMOVAL
Type: @oem117.inf,%hwfastboot%;Android Sooner Single ADB Interface
Instance id: 8XEBB18C05401427
Type: @oem112.inf,%busfilter.devicedesc%;USB Composite Device
COM168: Android Adapter PCUI (COM168)
9/27/2020 6:01:57 PM Starting to write device in UPGRADE mode...
9/27/2020 6:01:58 PM start to write update file
File to update: C:\Users\hp\Desktop\London _L21A 8.0.0.130(C432CUSTC432D2)\update_sd\UPDATE.APP
Process identifier:27707772
Validating file...
9/27/2020 6:02:14 PM Writing device finished with ERROR
Old 09-28-2020, 15:27   #6 (permalink)
Member: 2023196
Thanks Meter: 1,794
Problem is not the phone, its the file you are using.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.15365 seconds with 7 queries
