12-05-2019, 13:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2011
Member: 1560569 Status: Offline Thanks Meter: 100 | Unbrick Honor 8X Max ARE-AL00 only qualcomm mode ( Works ) if you have dead ( qualcomm mode 9008 ) mode in device manager of Honor 8X Max ( ARE-AL00 ) so this is the soultion, needed Flasher tools, 1- Qfil 2- Huawei Download tool IDT 3- hcu to repair IMEI and oeminfo. otherwise the Sd updrage Methoud will not Flash the Phone, and the Upgrade booting will stop on 5% ( must correct oeminfo as the Firmware you will Flash it Later ). 4- you need Official Firmware and Flash the Phone via SD Update methoud. ( Huawei Official Way ). Attached files in the Download link are:- 1- (bootloaderimage) Folder = use it with Qfil to Unbrick the Phone Boorloader. after you flash it with Qfill the Phone Go now to Fastboot Mode. 2- (fastbootimage) Flash this Boardsoftware via ( Huawei Download tool IDT ). after that the phone will boot with Softkeys Boardfirmare and now you can Fix oeminfo if messed. after that you can Flash your Phone to the Original Official Phone Stock Firmware. That is all. good luck to you all. Download files here https://www.4shared.com/s/fErB3cRmRiq Last edited by mobilefactor; 12-05-2019 at 20:46. |
The Following 3 Users Say Thank You to mobilefactor For This Useful Post: |
