Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
Junior Member Join Date: Jun 2023 Location: IT
Member: 3040447 Status: Offline Thanks Meter: 0 | Need Help FRP Lock P20 Lite I'm trying to fix a Huawei P20 Lite (ANE-LX1) with some sw (or hw) problem and I'm struggling to unlock FRP to be able to re-write a firmware on it. With the testpoint mode I was able to unlock BL but not the FRP lock. These are the info by HCU: Bootloader FB lock: unlocked Bootloader User lock: locked 2023-06-13 15:21:37.853 Repairing... 2023-06-13 15:21:37.862 Erase Huawei ID success! 2023-06-13 15:21:37.889 Write partition oeminfo... 2023-06-13 15:21:51.070 Write partition oeminfo fail! , Fastboot command fail! 2023-06-13 15:21:51.081 Write partition fail! What I'm wrong? |
![]() | #4 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Doing FRP unlock won't change the FRP lock status on fastboot screen it just removes the Google account from the device. You may try to flash nv partition backup from support area for your phone and then attempt the same service otherwise you may need to flash it from scratch with the board software. |
![]() | #5 (permalink) | |
Member: 3040447 Status: Offline Thanks Meter: 0 | Quote:
![]() | #6 (permalink) |
Member: 2023196 Status: Offline Thanks Meter: 1,891 | If flashing stock rom does not work then you can only attempt to flash board software, if the phone boots into the factory home screen with a few work apps then it's okay and the phone surely can be revived, otherwise it may be a board replacement. |
