need Huawei Y7P test point ART-L29 hello guys i need cert Huawei Y7P test point ART-L29 hardware i cant bypass enable software testpoint via dc phoenix log: File size: 3,635,374,944 bytes Current version(BASE_VER): ARTH-LGRP1-OVS 10.1.0.60 Revision: 1 Checking partition: BASE_VERLIST DC Phoenix 0.0.0.153 user:tn-bouXXXX File size: 3,635,374,944 bytes Current version(BASE_VER): ARTH-LGRP1-OVS 10.1.0.60 Package Type: OFFLINE_UPDATE TIME:2020-03-28 12:33:38 Revision: 1 Checking partition: BASE_VERLIST DC Phoenix 0.0.0.153 user:tn-bouXXXX Doing job: Enable software testpoint Looking for devices... Looking for devices by ports devices found: Android Adapter PCUI (COM218) Number of devices found: 1 Number of devices found: 1 Device authorized Base Version:ART-LGRP2-OVS 10.1.0.159 Cust Version:ARTH-L29-CUST 10.1.0.2(C185) Preload Version:ARTH-L29-PRELOAD 10.1.0.1(C185R3) Name:ART-L29 Model:ART-L29 Board:ART-L29 IMEI:86318404207XXXX IMEI1:8631840420XXXX MEID:00000000000000 SN:DUJ6R2070700519 Looking for device in upgrade mode... COM218: Android Adapter PCUI (COM218) COM217: DBAdapter Reserved Interface (COM217) Devices detected in UPDATE mode 2/18/2021 02:31:40 AM Starting to write device in UPGRADE mode... USB Device REMOVAL Type: @oem55.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: DUJ6R20707005191 Device found: DUJ6R20707005191 2/18/2021 02:31:45 AM start to update enable testpoint File to update: ENABLE_TESTPOINT.dtwork USB Device INSERTION Type: @oem55.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: DUJ6R20707005191 Process identifier:30196045 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Extracting partition SHA256RSA... Writing partition: SHA256RSA... Writing partition: SHA256RSA...OK Extracting partition CRC... Writing partition: CRC... Writing partition: CRC...OK Extracting partition BASE_VERLIST... Writing partition: BASE_VERLIST... Error downloading file ENABLE_TESTPOINT_2.dtwork, partition: BASE_VERLIST Error writing software 2/18/2021 02:32:10 AM Writing device finished with ERROR USB Device REMOVAL Type: @oem55.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: DUJ6R20707005191 Process FAIL. Please, try with device in Update mode and selecting a compatible firmware file |
Software testpoint works only up to Android 10.0 sadly. |
